I believe the ORMA 60 main hull has a daggerboard that also has a "T" foil to help lift the boat out.
BTW, there are smaller designs using similar, but much more affordable, systems. Antrim's Trimaran's and the Catri Tri (both built in the US by
Aegean Marine use bruce foils on the ama's. The Catri also has winglets on the ama transoms and a "T" foil rudder on the main hull. These act as the feathers/flights on a dart or arrow to stabilze the forward bruce foil without the need to get into attitude-responsive adjustable foils.
Mike.
