| Re: Prindle 18-2 or Nacra 5.5SL
[Re: royaluser]
#55434 08/18/05 09:28 AM 08/18/05 09:28 AM |
Posts: 833 St. Louis, MO, | They are both good boats. I owned the P18-2 as my first cat. The main difference is the kickup centerboard on the 18-2 vs. daggerboards on the 5.5. The 18-2 can handle extra weight a little easier than the 5.5. I like the rudder system on the 5.5 a little better.
If I were you I would pick the boat that is in the best condition. Little items really add up when you buy a used boat. Make sure all the parts are there to sail it. No missing sails or booms or rudders.... If it's missing one item it's going to be a no sale because it's so expensive to replace items.
Keep One Hull Flying, Mike Hill
Mike Hill N20 #1005
[Re: royaluser]
#55435 08/22/05 03:52 PM 08/22/05 03:52 PM |
Posts: 74 Maryland, USA | Steve,
I have a Nacra 5.5SL. In short, I think its a great boat. I do take my family on it (wife, kids 8 & 4) but would not consider it to be a family boat. It was designed as a racer so has quite a bit of complexity. That said you can ignore most of the finer settings and it will work just fine. The wire across the tramp will get in the way. I removed mine - details at nacramania.com. The boards could be an issue if the lakes are shallow or rocky. But it is boomless which is good with a lot on board. Most parts are pretty standard and available at murrays.com (or the catsailor.com store!). The manufacture (performancecat.com) has big ticket items if needed as I think it's still in (limited) production. Re-righting is pretty normal and will take 2 persons without some other aid such as a righting poll. I can't compare it to the Prindle 18-2 but from what I have heard and seen, the Prindles were OK boats.
Patrick Ragen Taipan 4.9 USA 274
2,968
guests, and 164
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
