| If happened so peacefully too.... #55471 08/18/05 07:52 AM 08/18/05 07:52 AM |
Posts: 72 Montreal , QC | Sailing last Tues Lake Champlain, nice 10-12 knts in my H16 '82 (will all new rigging last spring), beautiful sunny day, beam reach, just decided whether to trap out and ...."snap"....the little 6 inch section of the forestay between the mast tang and the jib sheet block broke. As the sun shone brightly, my rig just fell backwards. Then all was quiet on this peaceful day.... I packed up, rowed for 30 min with my little extendable paddled before finding a ride 2 miles back to home. Home safe and sound.  Anyone else with similar stories.
H16 '82
Tornado '88
| | | Re: If happened so peacefully too....
[Re: CatRon]
#55472 08/19/05 12:56 AM 08/19/05 12:56 AM |
Posts: 493 Minnesota | If nothing else got damaged, but your pride, I'd consider you had a sucessful day! A little paddling never hurt no-one.-But a bent mast would be a major HURT!
I had a side shroud come loose. I didn't realize anything was wrong, until I tacked and the mast fell over. -No damage. Captain and crew floated with beers in hand to the nearby shore, and promptly re-masted and continued sailing.
No damage, then no drama.
[Re: Jeff Peterson]
#55473 08/19/05 08:46 AM 08/19/05 08:46 AM |
Posts: 72 Montreal , QC |  It just so happens that I had been trailoring my H16 back adn forth between Montreal and South Hero, VT alot over the summer and always keep a few extra bungies on the tramp "just in case". Once the rig came down, it took less than 10 minutes to remove and roll the sails, remove the 4 trap lines and stretch/bungy them to the base of the mast, remove the side shrouds and also bungy them to the mast base and voila! All was "neatly" arranged on the tramp. I suppose this curious sense of "a job well done" would have been better placed if I was standing beside my boat on a trailor and not in the middle of the lake. That being said, for those of you who dread such an occurance, it was rather easy doing the above and the 3 or 4 extra bungies that were available (stretched on central tramp lines, out of the way) came in very handy to pack everything away so nicely. To round out the story, my rescue boat was a pleasant couple in an older Zodiac-type rig with an even older motor. Once hooked up and ready for tow, their motor wouldn't start!! (you know - let's help rescue this guy in trouble and wait, motor doesn't work!). Anyway, the motor wouldn't idle so once finally started (10 min later), I had the ride of my life back home at somewhere arouand 20 mph, struggling to keep the boat straight and the mast float out of the water.  All 'n all - a nice story over gin/tonic an hour later Ron
H16 '82
Tornado '88
[Re: JaimeZX]
#55476 08/23/05 01:21 AM 08/23/05 01:21 AM |
Joined: Mar 2005 Posts: 66 Durban, KwaZulu-Natal, South A... Clint_SA
Posts: 66 Durban, KwaZulu-Natal, South A... | Well I had my first 'mast drop' this weekend. The wind was great, just around 15knots, both out on the wire  A friend had decided we should race to a bouy out near to where the ships wait offshore. On the last tack to make the bouy all was good until...'peacefully' the mast decided to take a break.. The swell was small, and packing up everything took 20min. Luckily a 40ft cat was motoring past, and towed us back in light drizzle to the beach. Nothing appears broken and no-one got hurt..so I'd put in the 'experience' chapter and look back on it with a smile The cause: the threaded pin below the 'toggle twist' that goes through the lipped hull to the small bar under the lip sheared completely. Think I'll just replace both now in case
Dubulamanzi
[Re: CatRon]
#55477 08/23/05 01:23 PM 08/23/05 01:23 PM |
Posts: 15 | Not exactly a diamasting but similar nevertheless. While single handing my H16 on a beautiful day with about 8 knots of wind, my trapeze wire snapped. I managed to hold on to the mainsheet, using hobiegary's "DUMBASS" (Dragging Under My Boat Automatic Sheeting System) technique. | | | Re: If happened so peacefully too....
[Re: Starmarx18]
#55478 08/24/05 03:04 AM 08/24/05 03:04 AM |
Posts: 27 | Hello Mark, check out http://www.ohyc.com/html/tbone.htmfor an example of a major hull repair. Perhaps you can fix your cat, too. H77 | | | Re: If happened so peacefully too....
[Re: Starmarx18]
#55480 08/25/05 10:33 AM 08/25/05 10:33 AM |
Posts: 27 | Hey Mark, the link I posted was some information I came across when I was looking for Hobie-16 repair instructions on the web. Afraid I can't claim the credit for having done the repair myself  Happy sailing to you, too. H77 | | |
2,610
guests, and 297
