Does anyone mind a sailing question? #56811
09/08/05 09:09 PM
09/08/05 09:09 PM
Northfield,NH USA
bullswan Offline OP
bullswan  Offline OP
Northfield,NH USA
Today I sailed in very light winds for about an hour and noticed that the mast ball post was bent slightly....bent directly back towards the rear beam. What could have caused that?
My father in law speculated that the mast might have over rotated but I can't begin to understand why that might have caused it. It is a brand new post less than 1 month old. The only thought I had was that when I installed the new post I didn't cut the length down at all and perhaps it is too high? It probably stands up maybe 1.5 to 2 inches from the ball down to the beam. I thought that is about what I needed to give it the necessary clearance when I turn the mast on its side during stepping and unstepping.
So once you help me figure out what caused it, what should I do now? Cut it down /Shorten it?? I don't want to straighten it, right? Replace it AGAIN?
Thanks guys. I can give you a picture if you think it would help.
Re: Does anyone mind a sailing question? [Re: bullswan] #56812
09/08/05 09:23 PM
09/08/05 09:23 PM
Mike2210 Offline
Mike2210  Offline
What kind of boat is it and pictures would help!
Re: Does anyone mind a sailing question? [Re: Mike2210] #56813
09/08/05 09:38 PM
09/08/05 09:38 PM
Northfield,NH USA
bullswan Offline OP
bullswan  Offline OP
Northfield,NH USA
Nacra 5.5SL I can give you a Pictures tomorrow post bend but here is one pre-bend.. Is it too high?
Re: Does anyone mind a sailing question? [Re: bullswan] #56814
09/08/05 09:40 PM
09/08/05 09:40 PM
Northfield,NH USA
bullswan Offline OP
bullswan  Offline OP
Northfield,NH USA
Picture didn't come through the first time I'll try again
57152-nacra patch2.jpg (282 downloads)
Re: Does anyone mind a sailing question? [Re: bullswan] #56815
09/08/05 10:07 PM
09/08/05 10:07 PM
that does look pretty high.
What would help even more is a picture of the post with the mast properly seated on it.
Re: Does anyone mind a sailing question? [Re: bullswan] #56816
09/08/05 10:20 PM
09/08/05 10:20 PM
I agree that it does look a little high - weird. But I notice that the picture didn't have it fully assembled.
Re: Does anyone mind a sailing question? [Re: Jake] #56817
09/09/05 10:30 AM
09/09/05 10:30 AM
Cape May, NJ
SailWalker Offline
SailWalker  Offline
Cape May, NJ
Hey Bull, I replaced my ball and post at about the same time you did and I noticed the same thing happend to mine. I also had the speculation that I left the post too long. I have a very slight bend aft in the post and crease or dent in the ball, I suspect that it was from when I was attempting to step the mast and had the mast rotated to the side and basically hanging on the capitve pin and resting on the aft beam. Seems like that would be the only way I could get enough leverage on the post to bend it. I figured I would cut it down after this season. I am finally rigged and on the beach and have actually been out a few times; so I will be darned if I am going to de-step to cut the post down now!
Dave Nacra 5.2
Re: Does anyone mind a sailing question? [Re: SailWalker] #56818
09/09/05 11:20 AM
09/09/05 11:20 AM
Salt Lake City, UT
utahsailor Offline
utahsailor  Offline
Salt Lake City, UT
I have a Nacra 5.5u - and my ball is about half an inch lower than that.
It took me a while to get used to stepping the mast on my boat. In my ignorance, I tried to mount the mast oriented vertically (not lying on its side), with more than a few demastings resulting (even snapped my captive pin in half!) My mast and ball escaped unscathed, but I can imagine the pressure from the mast being great enough to bend a longer post.
Good luck!
Aaron
Re: Does anyone mind a sailing question? [Re: bullswan] #56819
09/09/05 11:38 AM
09/09/05 11:38 AM
Norfolk, VA
Dan Berger Offline
Dan Berger  Offline
Norfolk, VA
It looks like the post is not connected to the dolphin striker support. Look at where the post sits on top of the aluminum support for the striker--it looks like it is pushed back.
I have a few Nacra front crossbars and they are either 'welded' (screwed in from the bottom?) to the support or they have a plastic/ruberized metal piece that holds them in place.
I bet that when you are sailing that rod 'walks' off the support piece and that probaly lends to your post getting bent because it allows it to go through the beam at an angle. I would also try to figure out how to secure it so it has some support and actually does its job, which is to support the front beam.
Dan Berger
Norfolk, VA
A Cat USA139
Supercat 15
Re: Does anyone mind a sailing question? [Re: Dan Berger] #56820
09/09/05 11:40 AM
09/09/05 11:40 AM
Dan,
That was another thread and that is why the beam has the large welded aluminum plate on it - post slipped off the striker. If I remember, he took that picture just before the base piece (it's alumninum) was expected to arrive.
Re: Does anyone mind a sailing question? [Re: Jake] #56821
09/09/05 11:42 AM
09/09/05 11:42 AM
Norfolk, VA
Dan Berger Offline
Dan Berger  Offline
Norfolk, VA
fine--burst my bubble. I thought I actually had something relevant to add for once!
Dan Berger
Norfolk, VA
A Cat USA139
Supercat 15
Re: Does anyone mind a sailing question? [Re: Jake] #56822
09/09/05 12:13 PM
09/09/05 12:13 PM
Northfield,NH USA
bullswan Offline OP
bullswan  Offline OP
Northfield,NH USA
Sorry Dan, Jakes right on the money. I know how you feel though, there are lots of times I wish I had the knowledge to help out like these guys do!
Here are the current photos.... Sorry but I have to send them one at a time. I haven't had time to step the mast and take a picture yet but I will. The direction of the bend bothers me. I could understand it more if it bent forward rather than aft, figuring it happened while stepping the mast but .........
57209-Bent shaft 2.jpg (85 downloads)
Re: Does anyone mind a sailing question? [Re: bullswan] #56823
09/09/05 12:14 PM
09/09/05 12:14 PM
Northfield,NH USA
bullswan Offline OP
bullswan  Offline OP
Northfield,NH USA
Picture Two of my bent shaft
57211-Bent shaft 3.jpg (83 downloads)
Re: Does anyone mind a sailing question? [Re: bullswan] #56824
09/09/05 12:16 PM
09/09/05 12:16 PM
Northfield,NH USA
bullswan Offline OP
bullswan  Offline OP
Northfield,NH USA
And finally Picture 3 (opposite view of Pic 1)
57212-Bent shaft1.jpg (64 downloads)
Re: Does anyone mind a sailing question? [Re: bullswan] #56825
09/09/05 12:17 PM
09/09/05 12:17 PM
I'd say that's a combination of not enough mast rake and too long a mast support. The threaded post has clearly developed a bend, and that bend is going to continue until the post fails if you try to sail with it as is....
Re: Does anyone mind a sailing question? [Re: bullswan] #56826
09/09/05 12:42 PM
09/09/05 12:42 PM
Hey..hey...hey....there'll be none of that.
Re: Does anyone mind a sailing question? [Re: Jake] #56827
09/09/05 12:51 PM
09/09/05 12:51 PM
Northfield,NH USA
bullswan Offline OP
bullswan  Offline OP
Northfield,NH USA
Sorry. It slipped out.
Re: Does anyone mind a sailing question? [Re: bullswan] #56828
09/09/05 12:55 PM
09/09/05 12:55 PM
looks like your mast post needs to hit puberty and get a ball-drop.
Re: Bent Mast Post Picture [Re: bullswan] #56829
09/10/05 09:33 AM
09/10/05 09:33 AM
Northfield,NH USA
bullswan Offline OP
bullswan  Offline OP
Northfield,NH USA
Is the ball too high? By 1/2 inch? 1 inch?
Is the point to have it as low as possible but still have clearance enough to step it?
Finally, What is your opinion about continuing to use this post? Replace? Bend back straight? Leave it alone?
Thanks
Greg
57255-mast stepped.jpg (31 downloads)
Re:Bent mast post Picture 2? [Re: bullswan] #56830
09/10/05 09:35 AM
09/10/05 09:35 AM
Northfield,NH USA
bullswan Offline OP
bullswan  Offline OP
Northfield,NH USA
Picture two different angle.
57256-Stepped mast 2.jpg (40 downloads)
0 registered members (), 2,715 guests, and 503 spiders.
Yesterday at 10:10 AM
