Taking Hobie16 Apart #5700
03/22/02 06:31 PM
03/22/02 06:31 PM
Anonymous OP
Anonymous OP
I'm trying to take my Hobie 16 Apart, so that I can Paint it in my garage. (I live in Canada, and it's only 9-13 degrees Celcius. I need to have at least 18 for it to dry well.)
When I took the Bolts out of the corner posts, i tried pulling them apart, but it wouldn't budge. Is there anything that will get rid of the dried up silicone that is keeping my boat together? Or should I just wait until summer for it to be warm enough because it's too much of a hassel?
Re: Taking Hobie16 Apart #5701
03/22/02 09:33 PM
03/22/02 09:33 PM
Branford, CT
rhodysail Offline
rhodysail  Offline
Branford, CT
a hammer
Re: Taking Hobie16 Apart [Re: rhodysail] #5702
03/22/02 09:38 PM
03/22/02 09:38 PM
Anonymous OP
Anonymous OP
Ya. I tried that. I also got 2 of my friends down there. we got around one of the posts and tried tugging at it, but it wouldn't budge. Yes I did take out the bolts. [Linked Image]
Re: Taking Hobie16 Apart #5703
03/23/02 07:53 PM
03/23/02 07:53 PM
swampy Offline
swampy  Offline
Use a hair dryer/heat gun to soften up the silicone, just be careful not to heat up the fiberglass on your hulls.
Re: Taking Hobie16 Apart [Re: swampy] #5704
03/24/02 09:37 AM
03/24/02 09:37 AM
heavyair14 Offline
heavyair14  Offline
Here is what I'd suggest doing. Flip the boat upside down, and hit the rear crossbar with a 4 by 4 to try and tap it off. Don't hit it to hard, just keep tapping it. Eventually it should come off.
Hobie 16 sail #102653
Re: Taking Hobie16 Apart #5705
03/27/02 07:38 AM
03/27/02 07:38 AM
West Texas
Hobie Dave Offline
Hobie Dave  Offline
West Texas
Some folks glue the pylons...it may be difficult to get apart. A hair dryer is a good idea; it may be better to get a heat gun. Some epoxies may not turn loose with heat...at least with the amount of heat you can apply without damaging the fiberglass. If you cannot get it to turn loose, you probably should consider leaving them alone, and refinishing with the frame attached.
David
Re: Taking Hobie16 Apart [Re: Hobie Dave] #5706
03/27/02 11:09 PM
03/27/02 11:09 PM
Anonymous OP
Anonymous OP
well, It hasn't come out yet. I tried heating it up, it was still rock solid. I eventually tried chipping away some of whatever's in there. didn't do much though. [Linked Image]
Re: Taking Hobie16 Apart #5707
03/29/02 09:39 AM
03/29/02 09:39 AM
Anonymous OP
Anonymous OP
Yeah I tried everything under the sun and I couldn't get my rear cross bar off, So I drilled out the rivets ine the corner castings and removed the beam between the castings instead of taking the castings off the pylons. What a nightmare! But it all went back together nice and tight. Note I did have to pry the hulls apart, oxidation got the best of the fittings. Good luck!
Re: Taking Hobie16 Apart #5708
03/29/02 10:31 AM
03/29/02 10:31 AM
Bogie Offline
Bogie  Offline
If you haven't taken the Tramp off, you might try that to reduce tension on the frame. A propane torch should supply enough heat (used carefully) to remove the casting with a rubber mallet.
0 registered members (), 4,472 guests, and 838 spiders.
