Video with gps overlay, (A-cat sailing) #57940
09/25/05 10:59 AM
09/25/05 10:59 AM
North Europe, Sweden, Uppsala
Hakan Frojdh Offline OP
I added another gismo on my headcam setup, a device that reads the gps NMEA text and displays it realtime on the video.
The video shows spi sailing with A-cat, some upwind and
manouvers. The speed is in knots.
Link:
http://www.acat.vallagruppen.com/bilder/video/spi_with_gps.wmv
/hakan
Re: Video with gps overlay, (A-cat sailing) [Re: Hakan Frojdh] #57941
09/25/05 01:57 PM
09/25/05 01:57 PM
US Western Continental Shelf
hobiegary Offline
hobiegary  Offline
[color:"red"]BRAVO! BRAVO! BRAVO! [/color]
Santa Monica Bay
Re: Video with gps overlay, (A-cat sailing) [Re: hobiegary] #57942
09/25/05 02:19 PM
09/25/05 02:19 PM
Excellent Video.
Whats the most wind you have had the kite up in ?
Bitten by the spi virus Hakan !? [Re: Hakan Frojdh] #57943
09/25/05 02:48 PM
09/25/05 02:48 PM
Welcome to the club !
Re: Video with gps overlay, (A-cat sailing) [Re: Hakan Frojdh] #57944
09/25/05 06:17 PM
09/25/05 06:17 PM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
Fantastic! Thanks..Can you post information on how you overlaid the GPS info?
Thanks,
Dave
Re: Video with gps overlay, (A-cat sailing) [Re: pitchpoledave] #57945
09/26/05 12:39 PM
09/26/05 12:39 PM
Yes Wouter, I am addicted to spi sailing now....
My current setup is an old M20 snail and a spi pole from a Tornado. The support rods a ski poles in carbon where I added fittings for the bow and the pole.
I'm trying to convince Marstrom to build a spi kit designed for the A-cat. I should be similar to the M20 but with a smaller snail that can handle up to 18 m2 of spi and a lighter spi pole and streamlined support rods between the bows and the spi pole. The halyard should be internal similar to the M20 to reduce the drag.
We are 6 A-cats in Sweden that are interested in this kit and if we can find some more sailors that I think we could convince them to make a kit!
Pictures of my current spi setup:
http://www.webbo.dyndns.org/a-cat_sailing/spi/
Some technical data about the film:
The film is taken with a sony bullet cam using a wide angle lens. The video signal from the bullet cam is connected to the video overlay unit which adds the gps data. The video overlay unit has a video out which is connected to the analogue in of the dv cam. I use a 80 minutes tape which runs in LP-mode so I get 2 hours of recording.
The gps needs 5 volt, the video overlay needs 5 volts and the bullet cam needs 12 volts. I used to have a pack with 10 AA batteries but they where not reliable, it is no fun to get 2 hours of darkness after a terrific sailing trip!!!
I use a soldered battery pack with 10 AAA batteries instead which is smaller and gives me 2 hours of power. I use a small switched dc-dc converter to get 5 volts.
The video overlay unit:
http://www.blackboxcamera.com/Stv5730a/STV5730A.htm
/hakan
Re: Video with gps overlay, (A-cat sailing) [Re: Hakan Frojdh] #57946
09/26/05 04:11 PM
09/26/05 04:11 PM
Having sailed on an A-cat for the first time this past weekend (Nacra A2) I can't IMAGINE adding a spinnaker to the thing. It's so incredibly sensitive and accelerates so fast as it is - I can't imagine lake sailing with a chute on one. Granted, I was on a lake with a very gusty wind condition that day. That being said; what an incredible ride!
Re: Video with gps overlay, (A-cat sailing) [Re: Jake] #57947
09/26/05 04:23 PM
09/26/05 04:23 PM
it would be nice to get a ride on one of those. I plan on trying to continue to race after I leave Fl but the crew issue might be a problem- so maybe an A cat would be nice - but I don't think I really like sailing/racing alone all the time. as for the spin, looks sweet, but I think Jake is probably right... especially if you are on the lighter side.
Re: Video with gps overlay, (A-cat sailing) [Re: Hakan Frojdh] #57948
09/26/05 04:44 PM
09/26/05 04:44 PM
Looks good Hakan !
Re: Video with gps overlay, (A-cat sailing) [Re: PTP] #57949
09/26/05 04:44 PM
09/26/05 04:44 PM
... as for the spin, looks sweet, but I think Jake is probably right... especially if you are on the lighter side. ...
No, Jake isn't right. These boats get better with a set spinnaker. And I do mean better in the way of control !
But your will find that out in time on your own I wager.
Re: Video with gps overlay, (A-cat sailing) [Re: PTP] #57950
09/26/05 05:03 PM
09/26/05 05:03 PM
I'm on the lighter side, 72 kg (158.5 lbs). You don't need to be a heavy guy to handle a spi on the A-class. ...
/hakan
Re: Video with gps overlay, (A-cat sailing) [Re: Hakan Frojdh] #57951
09/26/05 06:20 PM
09/26/05 06:20 PM
Scotty Offline
Scotty  Offline
Now that's the stuff! Wow so what's the chance A class eventually going spi? Hakan, is the improved balance from the CE being moved forward some? I'm sure it would be possible to retrofit other A class cats to go spi in the future. 18knts in 6 to 12knts is fast, about what a fast course slalom windsurf board with a 7.5-8.5 does off the wind in 12knts. Anyway you've got me hooked and I've never even sailed a cat!!!
I love the videos, the Rammstein clip was pretty cool. Anyway can't wait to see some videos of sailing in 20knts, how about some shoreline shots when you do!
Scott
Re: Video with gps overlay, (A-cat sailing) [Re: Scotty] #57952
09/27/05 03:04 PM
09/27/05 03:04 PM
Some other nice catsailing video here:
http://www.adventureonline.tv/flv/sailing/video.cfm
Re: Video with gps overlay, (A-cat sailing) [Re: waterbug_wpb] #57953
09/27/05 03:14 PM
09/27/05 03:14 PM
Waterbug, there is something wrong with the coding, page is not displaying properly. I am using firefox.
edit: IE works fine.
Re: Video with gps overlay, (A-cat sailing) [Re: Robi] #57954
09/27/05 03:31 PM
09/27/05 03:31 PM
If you're having trouble, try:
and select "Channel 2" for the sailing stuff.
Re: Video with gps overlay, (A-cat sailing) [Re: waterbug_wpb] #57955
09/27/05 04:24 PM
09/27/05 04:24 PM
Re: Video with gps overlay, (A-cat sailing) [Re: Tony_F18] #57956
09/27/05 07:04 PM
09/27/05 07:04 PM
Westport, Ma. U.S.A.
Brian_Mc Offline
Brian_Mc  Offline
Tony, Thanks for the tip about Firefox. I do have trouble sometimes with videos. Seems I can't play a fair number, including several on the Beachcats video page. Any advice?
Re: Video with gps overlay, (A-cat sailing) [Re: Brian_Mc] #57957
09/27/05 07:09 PM
09/27/05 07:09 PM
Brian_Mc Offline
Brian_Mc  Offline
Hakan, Sorry I forgot to say, you are hipper than hip! Keep upt the great work! Thanks for sharing it with us!
Re: Video with gps overlay, (A-cat sailing) [Re: Brian_Mc] #57958
09/27/05 07:17 PM
09/27/05 07:17 PM
Kickass video Hakan that is a sweet setup and the video is even better!
Re: Video with gps overlay, (A-cat sailing) [Re: Robi] #57959
09/28/05 07:52 AM
09/28/05 07:52 AM
I am using firefox.
0 registered members (), 2,816 guests, and 517 spiders.
Yesterday at 10:10 AM
