mast step #58348
10/01/05 07:57 PM
10/01/05 07:57 PM
Thunder Bay ON CAN
M
mmadge Offline OP
mmadge  Offline OP
M
Thunder Bay ON CAN
Is it normal to see the top of the post( from the dolphin striker) on the bottom of the mast step?
Re: mast step [Re: mmadge] #58349
10/01/05 09:59 PM
10/01/05 09:59 PM
California
mmiller Offline
mmiller  Offline
California
as posted on the Hobie forums...
Yes you should see the top of the striker post in the cup. The striker post threads into the H16 step casting. The top of the post should be flush with the bottom of the cup.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: mast step [Re: mmadge] #58350
10/02/05 07:40 AM
10/02/05 07:40 AM
Thunder Bay ON CAN
M
mmadge Offline OP
mmadge  Offline OP
M
Thunder Bay ON CAN
Thanks Matt.I was a little worried as I notce my post has a little play in it.
Re: mast step [Re: mmadge] #58351
10/02/05 06:49 PM
10/02/05 06:49 PM
California
mmiller Offline
mmiller  Offline
California
Play? I would be concerned. If the post is working loose in the step casting it might end up pushing up and through.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: mast step [Re: mmiller] #58352
10/02/05 08:15 PM
10/02/05 08:15 PM
Thunder Bay ON CAN
M
mmadge Offline OP
mmadge  Offline OP
M
Thunder Bay ON CAN
Seems like the play is more down where the post and dolphin striker meet.The post seems pretty tight in the mast step.
Re: mast step [Re: mmadge] #58353
10/03/05 05:03 PM
10/03/05 05:03 PM
California
mmiller Offline
mmiller  Offline
California
Then you likely need to tighten up the striker rod. Nuts are on the ends at the corner castings. Should be snug, but not overly tight on a 16.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: mast step [Re: mmiller] #58354
10/03/05 05:49 PM
10/03/05 05:49 PM
Thunder Bay ON CAN
M
mmadge Offline OP
mmadge  Offline OP
M
Thunder Bay ON CAN
I am a little apprehensive about doing that.I have never adjusted them or heard of anyone adjusting them before.What are the reprocussions of too tight.How do you know when it is too tight or too loose?
Re: mast step [Re: mmadge] #58355
10/03/05 09:13 PM
10/03/05 09:13 PM
It's easy to do, Mike. Just take a turn or two on each side, then hit the dolphin striker rod with your hand. When it makes a "thummm" sound (instead of a "clang"), it's tight enough.
Make sure to tighten it evenly (same number of turns on each side). Unless you really torque on it, it's hard to get it too tight.
0 registered members (), 2,100 guests, and 208 spiders.
