| Re: mast help needed
[Re: Rolf_Nilsen]
#58512 10/07/05 09:37 AM 10/07/05 09:37 AM |
Posts: 12,310 South Carolina | The problem with bonding anything to aluminum is that it 'corrodes' practically immediately when in contact with air. This tiny corrosion layer actually helps protect the internal aluminum (I'm NOT talking about anodizing) but it doesn't bond with anything well. SOoooo...if you can abrade the surface while keeping it from coming in contact with air (i.e. using epoxy?) then you might have something. I've never heard of using epoxy between the sandpaper and the aluminum before the idea certainly has merit. The sanding 'dust' might be considered a problem in the epoxy - but as long as it's minimal it shouldn't be much of a problem. Besides, if you add aluminum powder to epoxy, it helps it resist abrasion.
Jake Kohl | | | Re: mast help needed
#58513 10/07/05 10:34 AM 10/07/05 10:34 AM |
Posts: 47 | I recommend at the hound add a wear plate using 18 guage stainless. Attach with 4 small rivets and bed with 4200. 18 guage can be form bent by hand to fit the mast. the suggestion about using a pigtail is good but the wear plate will protect the mast and remedy the current problem. The black marks are the result of how the boat was trailered in the past. Clean up the best you can and live with it.
Mark
C28R no. 140
Houston, TX
[Re: Mark Meis]
#58514 10/07/05 11:00 AM 10/07/05 11:00 AM |
Joined: Mar 2005 Posts: 2,074 Northfield,NH USA bullswan OP
Posts: 2,074 Northfield,NH USA | Damn. I was hoping no-one said to drill into the mast..... I HATE to drill into the mast. For any reason. And what is 4200? Sounds like a 3M product?
Greg
The nice part about being a pessimist is that you are constantly being either proven right or pleasantly surprised. - George Will "It's not that liberals aren't smart, it's just that so much of what they know isn't so" -Ronald Reagan | | | Re: mast help needed
[Re: bullswan]
#58515 10/07/05 12:07 PM 10/07/05 12:07 PM |
Posts: 12,310 South Carolina | It's a 3m product. 4200 is 5200's younger brother. 4200 is not quite as permanent as 5200 and is prescribed for bonding to plastics to anything else. 5200 is not prescribed for plastics but works great between gelcoat, fiberglass, and metal.
Jake Kohl | | |
701
guests, and 468
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online7,715 Sep 13th, 2025 | | | |
