| 5:1 versus 6:1 main blocks? #58596 10/07/05 10:51 AM 10/07/05 10:51 AM |
Joined: Apr 2005 Posts: 292 Ontario, Canada Captain_Dave OP
Posts: 292 Ontario, Canada | Since there has been a lull in posts this week, I figured - what da heck - I`ll ask another question that has been on my mind. Is there an appreciable/noticable difference in the sheeting EFFORT required when comparing the 5:1 and 6:1 setup.?? I already understand the low-profile benefit of the 6:1 setup. I am just concerned with the ease of sheeting. I have found the 5:1 blocks to be pretty tough to sheet down hard after a number of repetitions. As I mentioned in my last post, through the season I`ve had to do a lot of tacking and jibing on small bodies of water - in and out on the mainsheet constantly. After a few hours of flying my hulls, I can feel some strain in the bicepts tendons and some strain in the muscles between the ribs. I am no weakling (used to arm-wrestle semi-pro) and I still find this can be a real workout. Does the 6:1 (with a %20 advantage over the 5:1) help much? Dave | | | Re: 5:1 versus 6:1 main blocks?
[Re: hrtsailor]
#58598 10/07/05 11:41 AM 10/07/05 11:41 AM |
Posts: 306 St. Louis, MO | I used the 6:1 on my H16 and I now use a 7:1 on my TheMightyHobie18. Big difference on the H16 with the 6:1. I would sail for about 8-10 hrs on a good day and my arms were no more fatigued than the rest of my body. On medium to heavy air I would use the ratchet on the main block. If you have it reaved correctly when you sheet in the ratched wheel will spin. When you sheet out the ratchet wheel will not spin (hence the ratchet). Applying a slight force (by pulling) on the main sheet will "lock" it into the block without cleating off. This makes a huge difference after a few hours on the water. Being able to hold the main sheet in your hand so you can sheet out when you need to is great.
Go for the 6:1 set up.
Nick
Current Boat Looking for one
[Re: hrtsailor]
#58599 10/07/05 11:55 AM 10/07/05 11:55 AM |
Posts: 292 Ontario, Canada | Howard,
I have used the rachet both ways, but have never paid much attention to it or the difference it makes. Lately though, I usually have it turned off. I always sheet with one hand against the resistance. The only time I use both hands is to gather lots of lazy sheet quickly.
If I understand you correctly, it is easier sheeting (over time) with the rachet on? And, the 6:1 IS a noticable improvement over the 5:1?
As for fatigue on the mainsheet, one lake I sail is 14 miles long and ranges from about 200 yards to about 3/4 mile wide. When a good wind blows straight down the lake, I can tack upwind (about 10 miles) hiked out in a few hours. But, I`ll bet (guess) I am tacking 50 times to do it. After that, my arms are definitely sore and tired. The next morning is no peach either, but "by George" I can hardly wait to unclaw my hands and do it again.
[Re: mmiller]
#58602 10/07/05 12:54 PM 10/07/05 12:54 PM |
Posts: 292 Ontario, Canada | I get it now! The rachet is my friend. Jokes aside, I am clearly NOT taking full advantage of this feature... Oh my achy breaky (all fer nuthing!) arms and ribs. Thanks guys, Dave | | | Re: 5:1 versus 6:1 main blocks?
[Re: JaimeZX]
#58606 10/10/05 07:17 AM 10/10/05 07:17 AM |
Posts: 306 St. Louis, MO | Jamie,
Think twice before wrapping any running rigging around your hand. It is universally a bad idea on any sailboat. The reason is if a sudden gust of wind comes up and the sheet begins to move it will take your hand and anything attached to it, with it. If your hand is near a block it will not feel good. And no, you cannot get your hand unwoud fast enough all the time.
That is the reason why we use the cam cleats. So we don't have to jam our finders into the block to hold the line.
Nick
[Re: hobienick]
#58607 10/10/05 09:35 AM 10/10/05 09:35 AM |
Posts: 251 beaufort, sc | 6:1 is a big improvement especially when flying a hull, i am constantly trimming to maintain 'flight'. my friend's 7:1 is even better!
marsh hawk
[Re: JaimeZX]
#58610 10/11/05 08:33 AM 10/11/05 08:33 AM |
Posts: 306 St. Louis, MO | Maybe my paranoia comes from seeing broken hands on people who took a wrap with the sheets. This is without the fingers going through the blocks too. I guess I have too much time on the large mono hulls.
Nick
[Re: mmadge]
#58612 10/11/05 11:25 AM 10/11/05 11:25 AM |
Posts: 1,884 Detroit, MI | [snicker] That's exactly the technique I use on the 17. Upwind technique on the 17 is to honk it in tight (using both hands and your legs to get it in that last bit), then steer through the waves / gusts. After nearly loosing the tiller off the back of the wing (=instant capsize when the boat heads up while you're still trapping off the wing), I started holding the tiller in between my toes when getting that last bit in. The only problem is that you have to sail barefoot. I've got a bunch of nicks on my feet from doing that for seven days straight in Rehoboth. | | |
13,708
guests, and 708
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online14,249 9 seconds ago | | |
