Shroud and Forestay Tension #5886
04/01/02 01:29 PM
04/01/02 01:29 PM
Ohio
cb1919 Offline OP
cb1919  Offline OP
Ohio
How tight should the rigging be on a H16 . Should there still be some play or should the shrouds and forestay be tight (when at rest) . This is my first hobie, in case you cant tell, I used to sail on bigger monohulls and am more familiar with the way they are rigged.
Chris Bond
Re: Shroud and Forestay Tension [Re: cb1919] #5887
04/01/02 05:26 PM
04/01/02 05:26 PM
Go to www.nahca.org/hobies/hobie16_specifications.htm there is a tuning guide in pdf format you can download. I believe it has the info your looking for.
H16
Re: Shroud and Forestay Tension #5888
04/01/02 07:44 PM
04/01/02 07:44 PM
Ohio
cb1919 Offline OP
cb1919  Offline OP
Ohio
Thank You, Now will there still be some play in the shrouds. I used that guide on the nahca site but my shruods were still loose. I guess how much play is ok before the mast falls off under way.
Re: Shroud and Forestay Tension [Re: cb1919] #5889
04/02/02 07:59 AM
04/02/02 07:59 AM
Virginia USA
CMerrell Offline
CMerrell  Offline
Virginia USA
Shroud/forestay tension is subject of much debate among racers, particularly in light/heavy air. 1 to 2 inch shroud deflection when tensioned should get you started.
Re: Shroud and Forestay Tension [Re: CMerrell] #5890
04/02/02 08:40 AM
04/02/02 08:40 AM
Ohio
cb1919 Offline OP
cb1919  Offline OP
Ohio
Thank You
0 registered members (), 318 guests, and 464 spiders.
