| Re: Winter storage
[Re: culverk]
#59023 10/12/05 12:59 PM 10/12/05 12:59 PM |
Posts: 105 Bloomington, IN | What I've done with an TheMightyHobie18 in the past is to remove everything possible - trampoline, jib blocks, sheets, shrouds, halyards, etc., and store all that stuff inside. With the tramp off you don't need to worry about snow loads. This also gives you a chance to inspect everything and order replacement parts over the winter. Then cut a long tarp for each hull and cover the hulls to prevent sun damage. Leave the tarp open at the bottom so moisture won't accumulate. Make sure inside the hulls is as dry as possible before covering.
Jeff Tiger 849
| | | Re: Winter storage
[Re: wyatt]
#59025 10/12/05 08:22 PM 10/12/05 08:22 PM |
Joined: Mar 2005 Posts: 2,074 Northfield,NH USA bullswan
Posts: 2,074 Northfield,NH USA | For the weather Wyatt and I get in the Northeast, I am not going to let my Nacra sit outside in the winter. Waking up to 1/2 inch of ice on everything would break my heart. I have found indoor space for it in a neighbors barn. I think it's worth it to get it out of the UV alone. If you are going to go with the tarp idea I would purchase again the material (Yard Softouch By Odyssey)I got from www.rochfordsupply.com. It has a soft side and a durable vinyl-like side and made great cheap covers for my hulls to transport cross country with no damage. Good luck, Greg
The nice part about being a pessimist is that you are constantly being either proven right or pleasantly surprised. - George Will "It's not that liberals aren't smart, it's just that so much of what they know isn't so" -Ronald Reagan | | |
259
guests, and 93
