| Hobie-18 spin again! #5916 04/02/02 09:52 AM 04/02/02 09:52 AM |
Posts: 1,459 Annapolis,MD | I had posted earlier about adding a spinnaker to my H-18, and got some good posts, and I was refering to those for reference in my quest. But then the evil database problem came to be, and though it was valiantly defeated, the H-18 spin thread (yes, and others...) was lost! So... Wouter, you had some good links, could you post them again? Todd from Connecticut, you had provided some good info too. Anybody else feel like re-posting info they provided? I ended up buying the SX spinnaker from Todd from Texas, and am getting ready to do some test fits and "engineering"!
Thanks!
| | | Re: Hobie-18 spin again!
[Re: Keith]
#5917 04/02/02 12:16 PM 04/02/02 12:16 PM |
Posts: 9,582 North-West Europe | Keith here you go ! [url=http://www.geocities.com/f16H...f16HPclass/Tech_genaker_mast_setups.html [/url] All the links I supplied are given on that webpage. I have tried option 4 of the mast hound system at the Spring Fever regatta on Bill's boat and I must say that I think that that is the best option out of the four alternatives given. The double loop system has another advantage that I didn't expect and that is that this system results in the little block moving through a more horinzontala plane than is the case with option 1. If your TheMightyHobie18 has a comp tip than I would strongly advice option 4 where the vertical loop is lead to the masthook. This way you will load-up the palstic masttrack of the competip the least. The horinzontal loop can well be fixed on the masttrack for option 4 intrduces only very small loads on the horinzontal loop. I woul drill two holes on both sides of the track right through the reinfored webbing of the plastic masttrack. AND tie the knots on the outsside of the track so that the loop rather compresses the track together than pulling it apart. The first will definately be the more durable setup. I hope this helps and good luck. BTW, don't forget to inquire about spi's made abroad, you will save money. Regards, Wouter BTW ; this particular F161 webpage dealing with how to make your genaker mastsetup will be updated soon with pictures of option 4 and the document will be updated also. SO check back in a few weeks time.
| | | Ohh yeah ...
[Re: Wouter]
#5918 04/02/02 12:18 PM 04/02/02 12:18 PM |
Don't forget to use a small but rounded shackle. This won;t wear down the line as the sharped edges of tape like shackles and the pully block itself would.
[Re: wildtsail]
#5921 04/03/02 12:19 AM 04/03/02 12:19 AM |
Posts: 1,459 Annapolis,MD | Hi Todd,
I haven't had tremendous success in trying to find what the "stock" SX mounting locations and pole lengths are. I've been in email contact with folks from NAHCA, lots of good info but no definitive word on SX kites. The sail is actually from UK Sailmakers (there is no Hobie patch), although it measures just like an SX spin and it is the black with pink stripes seen in SX pictures. I tried email contacting the local UK loft to no avail. From the IHCA rules page I've gotten some maximums for the SX, and I figure I'll start with those as the ballpark for a fitting session.
As far as I can tell from the NAHCA site, the SX mast is 1'6" taller than the regular 18. That length seems to be carried in the metal section of the mast up to the hounds - I've deduced this from the fact that the SX and 18 seem to share the same comptip, but not the same diamond wires. The 18 comptip attaches just above the hounds. The 18 mast is 20' to the hounds. The 2 foot above the hounds you mention would then correspond to 23' 6" from the SX base, which I believe is about what the IHCA SX rules state. That means my ballpark is 3'6" above the hounds - close to the 4' you mention. I think the IHCA rules state 11'6" for the pole - I was thinking 12 to 13 feet - interesting that Smyth says 12'6" for yours!
I figured it would be common knowledge as to the preferred mounting for the spin sheet blocks for the SX, but I only get the standard answer that some people when mounting kites mount them to the stays, some to the rear beam. I kinda figured I'd get a more definitive answer for this one... My guess is that with a 16' foot on the sail with a a 12' pole, I'll be sheeting from the rear beam - a trial fit will tell, the cut of the sail will ultimately determine it I guess.
The thing that is driving me crazy thinking about it is the pole mounting. The shape of the 18 crossbeam seems to defeat most ideas. How are you mounting yours? You mentioned before that you mounted it to the striker, but then changed. What's your new method? Are you running the guy lines for the end of the pole from the bridal tangs, or did you drill holes through the hull lip near the bow?
Also, and this is getting ahead of myself as the boat is not together yet, how do you store the sail on the tramp? It would seem that the fact that the jib overlaps quite a bit makes for one more thing to get it tangled in with the halyard, sheets, and tack line having to go over or under the jib and sheets. Any hints there?
[Re: wildtsail]
#5923 04/03/02 01:55 PM 04/03/02 01:55 PM |
Posts: 196 San Diego, CA | Hi guys...the above photo from whitecaps.net>http://www.
whitecaps.net shows the installation of a hooter pole on my previous Prindle 19. This should be quite similar to what you are doing with the spinnaker pole on your boats. As for sail sheeting point, it works quite well on the I20 and other modern spinnaker boats to have a spinnaker with a smaller foot and sheet it to the shroud. Of course, the sail has to be sized/shaped for whatever sheeting point you use. Several P19 sailors in SoCal have had spinnakers made like this for their boats with great results. They also use the snuffer system rather than a tramp bag, which is very user friendly, even solo. Sail fast and have fun, Alan Thompson I20 - San Diego | | | Pole mounting...
[Re: wildtsail]
#5926 04/22/02 10:18 AM 04/22/02 10:18 AM |
Posts: 1,459 Annapolis,MD | Todd,
I think I have come up with something using a spare wing mount beam track slug. I had a spare one, you need to use the one for the rear mount, as they are a bit longer than the front. It fits into the opening in the front cross beam, and it's just long enough to hold (at least on my boat). Used with all the hardware - the threaded stud, and the v-shaped brace (? don't really know what to call that piece), it puts a strong stud in the middle of the front cross beam (well, almost middle, it's offset a little to one side or the other, but close enough). This can either be used as the pin in a pin and hole method (hole in end of pole, simply fits over the pin), or like I'm trying - an old boom vertex fits over the stud, a nut on the end of the stud holds it in place. On the end of the pole I drilled a hole through. The end of the pole fits over the stud/vertex and a bolt goes the hole and through the vertex. I need to put something inside the end of the pole to limit side-to-side movement, but so far it looks very promising. No holes to drill in the cross beam, and although it's a little tight with the inside edges of the tramp halves it fits well.
I post the pics of it soon.
517
guests, and 100
