| Locating serial number on H16 / age of boat #5972 04/04/02 08:29 PM 04/04/02 08:29 PM | Anonymous OP
| Anonymous OP
Unregistered | Several years ago, somebody donated a H16 to a scout troop. It was missing a number of things and sat around until the scoutmaster decided he wanted to get rid of it. My sister adopted it and than traded it to me.
It is a very old H16 and the current laws require that I register it before I can sail it. So, I called the Parks & Wildlife Department, and they want to know the hull serial number so they can locate the previous registered owner, if any (to fill out all the registrations, etc.).
Actually, at one point the PWD rep told me it is probably not worth my while going through all the legal hoops - that I would spend more on registrations, etc. than the boat is worth. I hope not, I spent a small bundle buying spare parts and fixing things already.
Anyway, I can't find a serial number anywhere. Where should I be looking? I have seen a number of posts on the model year, is there a way to determine the age of the boat?
Thanks,
TGR | | | Re: Locating serial number on H16 / age of boat #5973 04/04/02 09:54 PM 04/04/02 09:54 PM | Anonymous OP
| Anonymous OP
Unregistered | It should be located on the rear of the hulls by the rudder pins. | | | Re: Locating serial number on H16 / age of boat #5974 04/04/02 10:44 PM 04/04/02 10:44 PM | Anonymous OP
| Anonymous OP
Unregistered | Thanks for the help.
The transoms are flat and smooth. Is it a metal plate or molded into the fibreglass? Is it on both hulls or just one (if so, which)?
This boat has light blue decks with white hulls. Do you know what year they started serializing them? Maybe it is just older than that.
Thanks,
TGR | | | Re: Locating serial number on H16 / age of boat #5975 04/05/02 01:52 AM 04/05/02 01:52 AM | Anonymous OP
| Anonymous OP
Unregistered | Well, Mine are engraved into the back. it's on both hulls.
Yours have probably been painted over a few to many times, so you can't see it anymore.
I thought they Serializing boats was just for insurence. So can't they just give you a new code? Sail numbers will give you a rough year when it was made. | | | Re: Locating serial number on H16 / age of boat
[Re: CMerrell]
#5977 04/05/02 12:17 PM 04/05/02 12:17 PM | Anonymous OP
| Anonymous OP
Unregistered | Thanks for the info.
I looked and didn't see anything near the front pylons. According to the TPWD, in 1972 the Coast Guard required all hulls to be serialized near the transom with specific requirements.
I don't see anything. There is a lot of expoxy and marine caulk back there (whoever filled the drain plug holes with caulk also), but it looks smooth where the numbers should be.
The procedure here is to fill out a form and sign an affadavit saying it is yours, how long you had it, etc. Then it has to be inspected by a game warden, they issue a new serial number and registration. I have no idea how old the boat is though and I am really worried they will come back and say, "oh you need a bill of sale, transfer, etc.". They don't have to accept the affadavit as proof of ownership, it is at the discretion of the game warden.
The rep on the phone was telling me I would need to have each previous owner register the boat, pay the fees, and then pay a transfer to the next owner.
I will call and make an appointment on Monday, and then drive the boat over to the game warden and see what happens.
In the worse case, I can part it out and try to buy a complete boat.
Thanks again,
[Re: PSAILOR]
#5980 04/06/02 01:58 AM 04/06/02 01:58 AM | Anonymous OP
| Anonymous OP
Unregistered | They do have a provision for "homebuilt" boats, but you have to show materials invoices, etc., and you still have to get it inspected by a game warden. I don't think they would be fooled. | | | Re: Locating serial number on H16 / age of boat
[Re: tx246]
#5981 04/06/02 02:05 AM 04/06/02 02:05 AM | Anonymous OP
| Anonymous OP
Unregistered | This is pretty close to what I will do, although I can't just make up the serial number because the game warden will inspect the boat.
What I can do is fill out an affidavit declaring I own it and seeking a state-issued serial number because the existing number is obliterated/not present.
I would like a reasonable approximation of the age before I take it to the warden.
Somebody said the numbers on the sails are indicative of the age, can anyone elaborate on that, or point me to a resource that indicates the numbering scheme?
Are there any other large model year differences? For example, I know the masthead was changed at one point, does anyone know what year? Are there any other noticeable design changes I could look for that would give me a rough idea of the age?
As long as I could be sure it was 1988 or earlier, that would be great.
Thanks,
TGR | | | Re: Locating serial number on H16 / age of boat #5982 04/06/02 12:18 PM 04/06/02 12:18 PM | Anonymous OP
| Anonymous OP
Unregistered | My sail # is 30252 and I know that it's at least from 1985. | | | Re: Locating serial number on H16 / age of boat #5983 04/07/02 05:13 AM 04/07/02 05:13 AM | Anonymous OP
| Anonymous OP
Unregistered | Maybe I can give you a little help.
My first H16 was a 1977 and had a sail number of 25345.
My bros' 1981 was 66205.
The current 1984 is 86949.
Why not make up a serial number. Buy or borrow an engraving tool and engrave the serial number on both transoms.
| | | How old is sail # 12100 / year of masthead change? #5984 04/07/02 11:05 PM 04/07/02 11:05 PM | Anonymous OP
| Anonymous OP
Unregistered | I looked at the sails and the number is 12100. Based on the numbers the other guys gave, I would say that puts it in the early '70s. Can anybody help me narrow it down?
So, maybe I should be looking more closely at the front pylon. Where exactly should I be looking on the front pylon? The metal, the fiberglass deck or hull, is there a metal plate?
It also has the old style mast head - does anyone know what year it changed? | | | Re: Locating serial number on H16 / age of boat
[Re: CMerrell]
#5985 04/07/02 11:07 PM 04/07/02 11:07 PM | Anonymous OP
| Anonymous OP
Unregistered | There is no decal gum for registration. Based on the sail number, it might be early 70's. When you say stamped into the front pylon, where exactly? Into the metal? ...or into the fairing?
It has the older style masthead.
Thanks,
TGR | | | Re: How old is sail # 12100 / year of masthead change?
[Re: jmhoying]
#5987 04/08/02 06:52 PM 04/08/02 06:52 PM | Anonymous OP
| Anonymous OP
Unregistered | I called Hobie today. I asked if they could give me an idea of the age of boat based on the sail number. She told me 'no.' So then I asked if they were issued sequentially or at random, she said 'yea, uh-huh," to random.
She knew even less about cats than I do (she didn't know what a pylon, stern, or transom was 'back part of the boat'). So, that doesn't seem to be real useful.
I could have asked about the masthead change, but I doubt she would know.
Thanks,
TGR | | | Re: Locating serial number on H16 / age of boat #5989 04/09/02 01:08 AM 04/09/02 01:08 AM | Anonymous OP
| Anonymous OP
Unregistered | Hey Tex,
My H16 is a 1972 Coast Cat. The 4 digit serial # is stamped on both front aluminum pylons and are readable from the sides.
Hope this helps
Tom | | | Re: How old is sail # 12100 / year of masthead change? #5990 04/09/02 09:18 AM 04/09/02 09:18 AM |
Posts: 1,459 Annapolis,MD | Hobie sail numbers are not assigned to the boat like other one-design classes. For instance, in Flying Scots you register with the class association and are then assigned a sail number. Whenever you get sails you're supposed to use your class assigned number. Lots of one-design classes work this way. Hobie sail numbers are sequential, but apparently sequential in the sail making process only. You might be able to figure out what year your sail was made (if you're lucky) but that will only mean anything about the boat if you are certain it is the original sail, or if the sail was replaced by someone who requested the original sail number be put on it. For instance, when I bought my '79 Hobie-18 in about '93 (man, I need a new boat!) it had a sail number of 14863, on newish sails. I'm pretty darn sure that was not the original number for an 18 that old. I recently bought a new sail from Hobie for it, wasn't even asked about sail # preference (I was figuring I'd be putting the numbers on) and it came through nicely numbered 16744. My guess is that whenever they make a main they just put the next number on it and ship it. One item: The sail is very nice, well made, and has enabled me to kick some butt in the local Fleet - if you're feeling sluggish, try new rags from Hobie.
So here's another serial number and year of manufacture thing - if you see an "R" after the number, it means that you have a replacement hull. Both of my hulls have "R" on them, so even though the number indicates it's a 1979, I have no real idea as to when the hulls were actually built or why they were replaced! I've always figured I could call Hobie and get some answers, but it sounds like that might not be the case if they don't know which end of a boat is which!
2,735
guests, and 677
