small pipe on forward post of Hobie 14 pylon #60650
11/10/05 10:53 AM
11/10/05 10:53 AM
Frozen Offline OP
Frozen  Offline OP
I noticed when I was taking my H14 apart for the winter that there is a small open pipe going through the foam plug in the forward pylon on both hulls. It looks like a vent pipe.. Is it?
If it is a vent pipe then why do you have to loosen the hull drains to equalize the pressure in the hulls after you're finished for the day?
Alan F
Tiger
Re: small pipe on forward post of Hobie 14 pylon [Re: Frozen] #60651
11/10/05 11:01 AM
11/10/05 11:01 AM
Ontario, Canada
Captain_Dave Offline
Ontario, Canada
I believe it is a vent tube, though I am not %100 certain on the H14 - I have an H16. Also, opening the drain plugs is necessary to drain water - not for pressure equalization. If you are hearing the swoosh of air when opening your drains, I suspect those vent tubes have become clogged.
Dave
Re: small pipe on forward post of Hobie 14 pylon [Re: Frozen] #60652
11/10/05 11:39 AM
11/10/05 11:39 AM
It is a vent, but they do have a tendency to get clogged. It's usually not necessary to clear them if you leave the plugs out when the boat's not the water.
My '98 H-16 has held air pressure since the day I bought it new. I never leave the plugs in unless I'm sailing it. The Tiger doesn't have vents, but it does have a warning sticker on the transom saying that you need to remove the plugs when it's not in the water to prevent pressure build-up.
Re: small pipe on forward post of Hobie 14 pylon [Re: mbounds] #60653
11/10/05 03:17 PM
11/10/05 03:17 PM
Minnesota
Jeff Peterson Offline
Minnesota
Yes, it is a vent; and if you are looking at it, you might as well clean it. Get a thin single strand wire, and run it in-and-out of the vent til you think its clean.-Its probably OK, but if you assemble the boat and THEN find it needs to be cleaned out...well...I'll let you be your own best critic.
Jeff Peterson
H-16 Sail #23721
Big Marine Lake, MN
0 registered members (), 420 guests, and 50 spiders.
