| Re: Raising Mast Solo
[Re: hrtsailor]
#60900 11/16/05 10:07 PM 11/16/05 10:07 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | If you are raising the mast on an H-16 you don't need a winch or any other device. I am 71 years old and raise my mast solo with no trouble at all. I tie a line to the jib halyard (just to extend it a few feet) and tie it to the bridle. I put a simple tripod at the rear to hold the mast off the traveler track. I then just raise the mast, lean into it as I reach down and undo the jib halyard, pull the halyard tight to hold the mast up, and re-cleat it. Then I get down and fasten the forestay. Howard, I guess the point here is the need to simply and safely raise-lower the mast no matter the boat. I'm sure it would help open our world to more people. The one thing about the H-16 when raising it by yourself is the trap wire shock cords. Since they are free to float around under the tramp they wind up at the back as you start to raise. So not only are you raising the mast weight you wind up having to deal with the shock cord trying to pull it back down. Plus they tend to get caught on stuff. So before you start, get something to hold the shock cords around or in front of the shrouds. Again, my drawing is not accurate. The base strut was more vertical. So when it was cranked up the whole thing was almost straight up. Jake I'm not sure if that would work as easy. I think yours lifting closer to the base would have more load on it and the chock would have to slide a greater distance on the mast and pivot to maintain side control of the mast. Also the spreaders might get in the way as the chock slides up the mast. Looks like it will chuck pumpkins though. I'm a big believer in towing the boat backwards. For those removing your rudders anyway then why not? It's just easier to raise the mast. I know some people are afraid they'll drop it on their car. With this system that problem is almost eliminated. Jack, your set-up works good, however you have set up and haul that stuff around with you.
[Re: Redtwin]
#60901 11/16/05 10:28 PM 11/16/05 10:28 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Howard, This is how I used to step the mast of my Apollo 16. This method works very well. I wasn't sure how it would work on a beachcat because the mast is much heavier. Has anyone else used the jib halyard? This seems to me to be the easiest and doesn't require any additional equipment, blocks, or lines. One issue I have with my Nacra 5.2 is that the mast does not have any way for me to capture the bottom (foot) of the mast. There is no place for me to lock it; no pin, no holes or anything. It just sits on the ball. So when I am raising the mast, I have to have someone, who is very brave, hold down the base of the mast until I get it to about 45 degrees. When I am lowering the mast, the very brave person holds it down until I get it to about 30 degrees and then it always pops out. If I have not gotten far enough back, the masthead drops hard. Luckily, I do this on the beach so it lands in the sand. Any ideas short of going out and buying a new base for my mast?
-Rob V. Panama City Nacra 5.2 Rob, some Mystere's use line to hold the base in place. They have a pad eye on the front of the mast near the base and two more on the main beam on either side of the base. The line is tied to one eye on the beam,passed through the eye on the mast and then to the other eye on the beam. This holds the base in place. The first couple times I used this set up I was nervous becaused I always had the pin on other boats but it does work good. I'll get you a PIC if you like. But, instead of drilling 6 more holes in you boat, how much is a base for your mast?
[Re: hrtsailor]
#60902 11/16/05 10:29 PM 11/16/05 10:29 PM |
Joined: Apr 2005 Posts: 473 Panama City, Florida Redtwin
Posts: 473 Panama City, Florida | The Apollo 16 is a monohull with a much lighter mast. I actually used the furling jib to hold the mast up. I would apply some downhaul to the jibwire and then connect the forestay. I think I could easily do it with the Nacra if it wasn't for the base not being locked down.
Jake, Somehow, my simple brain is not grasping how the drawings in previous posts are going to lift the mast. It seems to me they are just going to pull the mast lower. How is the lift created? I see the directional arrow showing which way the line goes, but it seems to just tighten the mast down.
-Rob V. Rob V.
Nacra 5.2
Panama City | | | Re: Raising Mast Solo
[Re: hrtsailor]
#60907 11/17/05 08:51 AM 11/17/05 08:51 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Howard, I understand what your saying. This topic comes up alot and while most people I've seen don't use anything, if there was some simple and easy way I think more people would use it. Like beach wheels.
Forgive me for assuming but I'm guessing you've been doing this for a while. Compare that to someone 70 that has never done it but wants to. If raising the mast is the only thing that keeps that person on the beach then...
A young lady that sails off the causeway here raises her's with no help. Then there was this guy about 50 who could not get the mast past his head. It was ugly. I know he had a good time sailing but I havent'seen him again and that's a shame.
#60908 11/17/05 08:52 AM 11/17/05 08:52 AM |
Posts: 324 South Florida | Jake, that doesn't look like it would work. The winch end seems so short compared to the mast end, and the mast end being so close to the base seems like it would be a huge amount of weight to push up. I think 2" tubing would bend pretty soon. Plus it you go past the point shown on your diagram the mast would start dropping again. I know my Hobie 18 mast would not go up this way. It seems like you would need more leverage on the pulling end and more thickness on the pushing end.
Fred F
(ex Hobie 18)
[Re: SOMA]
#60909 11/17/05 08:59 AM 11/17/05 08:59 AM |
Posts: 324 South Florida | Actually, if the strap could go over a roller on the short end, then over an extension of the mast support in the center and then attach to the mast end, so that the strap is pulling up on the tube (like cranes) then I could see it being supported much better.
Fred F
(ex Hobie 18)
#60910 11/17/05 09:26 AM 11/17/05 09:26 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Jake, I think there would be a large difference on the mast base. Yours is trying to lift the mast off the base before the mast raises. The other system is more like lifting the mast from the top.
Hey, I just had a thought. How about drilling a small hole in the mast and dropping in a small purple pill???
[Re: Redtwin]
#60911 11/17/05 09:26 AM 11/17/05 09:26 AM |
Posts: 778 Houston | One issue I have with my Nacra 5.2 is that the mast does not have any way for me to capture the bottom (foot) of the mast. There is no place for me to lock it; no pin, no holes or anything. It just sits on the ball. So when I am raising the mast, I have to have someone, who is very brave, hold down the base of the mast until I get it to about 45 degrees. When I am lowering the mast, the very brave person holds it down until I get it to about 30 degrees and then it always pops out. If I have not gotten far enough back, the masthead drops hard. Luckily, I do this on the beach so it lands in the sand. Any ideas short of going out and buying a new base for my mast? The easiest way to handle this is to 1)loop bungees under the front cross beam and attach them to the diamond wire. Use heavy bungee (like the black rubber ones) and make sure they are tight. 2) Tie your trap lines to the front beam. The trap lines have the same pivot point as the mast so they will stay tight as the mast moves. This works like a charm on my Marstrom | | | Re: Raising Mast Solo
[Re: Redtwin]
#60913 11/17/05 11:35 AM 11/17/05 11:35 AM |
Posts: 371 Michigan, USA | Rob,
I have seen someone tie a line from the diamond wires or around the downhaul blocks on the mast down to the dolphin striker to keep the mast base in place and on the ball while raising and lowering the mast.
Les Gallagher
[Re: hrtsailor]
#60914 11/17/05 01:06 PM 11/17/05 01:06 PM |
Posts: 306 St. Louis, MO | I agree with Howard. I know he and I discussed this topic earlier this year. Listen to him. An H16 mast doesn't weigh that much. I too have stepped one solo using the method he described.
On the heavier masts you may need some help, but not on the H16.
Nick
Current Boat Looking for one
[Re: jmhoying]
#60918 11/17/05 06:27 PM 11/17/05 06:27 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Jack, keep in mind my boat is towed backwards so there no added turning it around.
I should have the disc with PIC of the working model tomorrow.
Howard your right, some people have strange ideas how to get things done and the guy you mention should be up for a Rube Goldberg award.
Jake, keeping in mind they both lift the mast to about the same height, I still think the other one will work better. I might spend some time messing around with both ideas. I have a friend who's quite the fabricator and I'll talk him about making a couple mock ups and have a closer look.
16,262
guests, and 1,190
