| T4.9 righting #6127 04/09/02 08:25 AM 04/09/02 08:25 AM | Anonymous OP
| Anonymous OP
Unregistered | This was my second T4.9 capsize, both solo and I could not get it up (no pun) either time. I was very successful righting the old N5.2 and just didn’t think this would be an issue with the 4.9. The first capsize, I failed to uncleat the main, so I chocked it up to that and poor technique. This time I completely blew the main and traveller and the spin was out of the water. The boat was oriented mast to wind, so the wind was blowing directly on the tramp. Even then no luck. The boat really wanted to move while putting some heat on the righting line. I’m about 190 lbs and have the “Hawaiian” style righting system supplied with the boat. So why? Three ideas. The ratio of the hull weight to the rig weight is much lower affecting righting characteristics? Poor technique? “Hawaiian” style righting system plus narrow boat? The boat is a few inches shy of 8 ft and the Hawaiian style righting system attaches to the front beam inboard side of hulls. I was able to right the old N5.2 but had to “stack the deck” a bit in my favor. I either needed the wind blowing directly on the tramp , or the boat pointed nearly head to wind to get air under the sail. I typically did not uncleat the main or traveller. Perhaps sheeting/travelling the sail in to allow water to run off but also allowing air to get under. So, first I’ll try an “over the top” righting line, outboard of the hull, then if that doesn’t work, I’ll go for the “pole”… Happy sailing! | | | Re: T4.9 righting #6130 04/09/02 11:00 AM 04/09/02 11:00 AM | Anonymous OP
| Anonymous OP
Unregistered | Hi Dave,
I'll add one more thing to what's already been said. Assuming you're not turtled - to get the boat oriented properly with respect to the wind, move your weight towards the front of the boat until the bow just starts to go under - the sterns will swing around until the wind is hitting somewhere between the bows and the mast. Then move your weight aft a bit and lean back on the righting line. The wind will get under the main and right the boat for you. At 160lb I've been able to right the boat by myself with a 15-20MPH breeze. I still need to get around to capsizing in lighter air to make sure I can still right it by myself w/o problems
Kenn Newbury | | | Re: T4.9 righting #6131 04/09/02 11:41 AM 04/09/02 11:41 AM |
The spi must be retracted and stuffed before attempting to right the boat. Sometimes you can right it with the spi still set but most of the times it will totally prevent you from getting anywhere.
Next, if you trurtled and you have the standard AHPC mast THAN you probabky had water in the mastsection. The AHPC mast is not sealed and there are gapping whole at the hounds.
I found when sailing skiffs which use much the same hound system that these boat are rightable but they take a bit time to let the water run out of the mast.
Best then is too hook yourself to the righting line with your trapeze. Righting line must go over the hull to make hanging on it more comfortable. lift the mast just a little bit and wait for the water to run out. The boat will slowly lift more and more. VERY slowly depending on the water it has shed. Climb a little higher in the rope and get the rest of the water out and once it is out and you can feel that very well. continue with the righting technic. May take 30 to 40 secs to complete this whole sequence.
Better = sealed mast.
If this was not the case => turtle and standard AHPC mast then forget what I wrote.
| | | Re: T4.9 righting
[Re: Wouter]
#6132 04/09/02 12:30 PM 04/09/02 12:30 PM | Anonymous OP
| Anonymous OP
Unregistered | Wouter-
I'm replying to the turtle question from the other thread here to try to keep the topics separated. No the boat did not go turtle. Both times I've capsized, I've been over for quite a while and the boat showed no tendency to turtle. I believe the AHPC mast is sealed. Mine has what appears to be some high density, closed cell spray type foam oozing out of some of the penetrations. DCS | | | Re: T4.9 righting #6133 04/09/02 12:36 PM 04/09/02 12:36 PM | Anonymous OP
| Anonymous OP
Unregistered | Dave,
One more thing I just remembered . . .
At Jim's suggestion, I used some expanding foam (buy it in a spray can at the hardware store) to put a plug in the mast where the diamonds are attached to the mast. I also drilled a small hole a little above the cunningham hardware and put a foam plug there (closed the hole up with a rivet) - hopefully this will allow us to right the boat from the turtled position. I also tried to seal any rivets/fittings above the lower plug I just described. It probably sounds like I'm paranoid, but I learned the hard way w/ our H-18 just how tough (impossible) it can be to right a cat w/ water in the mast.
Kenn | | | spray foam to seal mast #6134 04/09/02 01:29 PM 04/09/02 01:29 PM |
Posts: 851 US Western Continental Shelf | Ken,
I wish I knew where to buy some 'closed cell' spray in foam in a can. However, I suggest that you spray a test piece of your foam soak it in water for a day or two. I have found that the spray foam from the hardware store will absorb water and become heavy. Just a heads up for you.
Santa Monica Bay Mystere 6.0 "Whisk" <--- R.I.P. | | | Re: T4.9 righting
[Re: phill]
#6137 04/09/02 04:41 PM 04/09/02 04:41 PM | Anonymous OP
| Anonymous OP
Unregistered | Phill- Your response begs the question, do the Aluminum T4.9 masts come from AHPC sealed? I thought I read this somewhere in the literature, and my mast sure acts like it is sealed.
Thanks for all the great response on my quetions/adventures. I sure am having fun with this new boat!
Another unrelated question. How come there is not much Australian participation on this forum. I would think you guys have a huge wealth of info on the 4.9. Do you use other bulletin boards to swap info? I understand you guys don't race Taipans with the spin, but don't lots of guys fly them for fun? Just curious. DCS | | | A very neat trick !
[Re: phill]
#6139 04/10/02 05:30 AM 04/10/02 05:30 AM |
A very neat trick !
Do you mind if I make another Tech article on and put it onto the F16 website ? Looks like a very good problem to make such an article on.
WOuter
| | | Re: T4.9 righting
[Re: Berthos]
#6141 04/10/02 10:57 AM 04/10/02 10:57 AM | Anonymous OP
| Anonymous OP
Unregistered | Thanks again to all. Kenn and Chuck, you guys are both using the righting system supplied with the boat, the line that attaches to the front crossbar inboard of the hull? Or are you using an "over the top" line?
Kenn- Nice sail number! It is kinda weird to pull up a pic of somebody else and see the number that was once on your boat! Also, how do you like the EO snuffer. Are there some real advantages/disadvantages when compared to the Guck. Those seem to be the only two "off the shelf" options. I should probably start this on a new thread. DCS | | | Re: T4.9 righting #6142 04/10/02 12:07 PM 04/10/02 12:07 PM | Anonymous OP
| Anonymous OP
Yes, I'm using the 'stock' righting system - though I replaced the original line with one that's a little longer. We used the 'over the top' (line tied to dolphin striker) on our TheMightyHobie18. I think the only advantage to 'over the top' (assuming you haven't turtled) is that you don't need as strong a grip on the righting line when you lean out. The righting moment is the same, but the line tension is a little higher with the stock system. I like the idea that's been brought up to hook into the righting line with your trap harness.
The EO snuffer functions very well (launch and retrieval are quick and easy), but it is pretty ugly IMO. I chose it because bag launching just isn't an option for us, and the skunk wasn't out back when I bought the EO snuffer. I'm not sure what I would do if I were making the decision now. The EO snuffer is less $, but doesn't look as slick. In the conditions we had at SF, I didn't feel like it was slowing us down or keeping us from pointing relative to the other T4.9s (the others were skunkin' or bag launching). However, many of us are new to the boat, and this was just one set of sailing conditions - not a very objective test. Windage/pointing issues seem to provide the strongest arguments in favor of the skunk (I've heard the weight placement argument, but don't feel that it has much merit).
Kenn Newbury | | |
320
guests, and 35
