| Re: HomeTrax wheel hubs??
[Re: Mary]
#61420 11/28/05 09:20 AM 11/28/05 09:20 AM |
Posts: 306 St. Louis, MO | It is generally a good idea to avoid lubrication in beach wheel bearings. It will attaract sand and wear down the bearing surface quicker. Plus, it would be just one more thing to have to maintain.
Nick
Current Boat Looking for one
[Re: jeeperman]
#61422 11/29/05 08:46 AM 11/29/05 08:46 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Check with ATV wheel suppliers. The early Honda ATC three wheelers used a completely rubber rear tire. No wheel. The tire had a steel tube that was vulcianized to the tire. If you've ever seen a original set of Cat Trax you'll know what I'm talking about. All Cat Trax did was find the right size alum. axle,add the right dia. delrin bearings, washers on the ends to hold the delrin in place.
The problem with this system was the steel tube, add salt water and.....
As it turned out Honda's idea wasn't that good and they stopped using that tire. I don't know who was making that tire but they stopped making it cause there was no demand for it. However people that had these bikes needed some way to put tires on their bikes so someone came out with the wheel you see on the new style Cat Trax.
So look at atv suppliers. You might even check with a Honda dealer. If it's not a Honda part you might learn where they would order it from.
[Re: Captain_Dave]
#61424 11/29/05 01:49 PM 11/29/05 01:49 PM |
Posts: 306 St. Louis, MO | I do have a full machine shop at my disposal. What do people think these plastic hubs are worth? I could be persuaded to manufacture these if I can cover my costs.
Nick
[Re: hobienick]
#61425 11/29/05 02:31 PM 11/29/05 02:31 PM |
Posts: 1,187 38.912, -95.37 | Ahh...the good old 55 gallon detergent drum Sorry for hijacking the hub thread Dave.
[Re: CaptJulian]
#61429 11/29/05 02:57 PM 11/29/05 02:57 PM |
Posts: 1,187 38.912, -95.37 | CaptJulian, Sand is not a commodity in these parts, so we have little to no experience with it, which I know is bugging the hell out of all the beach launchers.
Captain Dave, One last shot and then I'm done. I say, "Hubs?...we don't need no stinking Hubs!" Not unless your planning on speeds in excess of 20 mph. How about using schedule 80 PVC between the wheels and PVC connectors (2 1/2" electrical size will fit your wheels) and a length of galvanized conduit inside, pinned in place with S/S bolts. With a little paint or inhibitor here and there will be relatively rust free.
[Re: _flatlander_]
#61430 11/29/05 03:10 PM 11/29/05 03:10 PM |
Posts: 306 St. Louis, MO | I think I know why Capt Dave wants to use the hubs. He would like to be able to use wheels that are made for hubs. Instead of hubs maybe we should call them adaptors? Am I getting your messge Dave? Is Captain Julian in Massachusettes? If so, it's about time you got on this forum
Nick
[Re: hobienick]
#61431 11/29/05 03:45 PM 11/29/05 03:45 PM |
Joined: Apr 2005 Posts: 292 Ontario, Canada Captain_Dave OP
Posts: 292 Ontario, Canada | You`ve got it now Nick. But, hubs are hubs. Rims and wheels are a separate deal. The proper name for what I need is "hub" - not to be confused with a rim or a wheel. Any search for a "hub" will illustrate what I need - only I want it in plastic. Steel hubs are heavy, made of metal and have metal bearings. Even a cheap metal hub is made to support many, many hundreds of pounds more than a set of catrax requires - not to mention the corrosion factor.
Flatlander,
You are correct about the hubs regarding the speed issue. However, I already have some nice wheels (which I want to use) and what I need is a 4-bolt hub to attach my wheels (with 4-bolt rims) to an appropriate axle. I do not believe your design will allow a 4-bolt rim to be secured to an axle. Plus, it all sounds a little heavier than necessary. I will be using aluminum for my axle.
Dave
[Re: Captain_Dave]
#61432 11/29/05 04:19 PM 11/29/05 04:19 PM |
Posts: 306 St. Louis, MO | Dave,
I already have a simple plastic hub design that will be easy to install on an aluminum hollow shaft or pipe. If you are interested send me a PM and maybe we can work something out. I would need some dimentions but it could be done fairly easily.
Nick
[Re: Captain_Dave]
#61436 12/04/05 08:01 PM 12/04/05 08:01 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | You`ve got it now Nick. But, hubs are hubs. Rims and wheels are a separate deal. The proper name for what I need is "hub" - not to be confused with a rim or a wheel. Any search for a "hub" will illustrate what I need - only I want it in plastic. Steel hubs are heavy, made of metal and have metal bearings. Even a cheap metal hub is made to support many, many hundreds of pounds more than a set of catrax requires - not to mention the corrosion factor. The nice thing about the wheel I'm talking about is, it is the wheel and the hub complete with bearing surface. Alloy, no rust.
[Re: catman]
#61437 12/08/05 01:13 PM 12/08/05 01:13 PM | Anonymous
| Anonymous
Unregistered | This article will explain how to make the wheels. VERY simple, don't need fancy hubs. They work great, just don't drill the extra holes. Use some silicone around washers and connectors. If you have questions call me. http://www.geocities.com/mec_coleman/tip13.htmDoug Snell 281-326-2702 dsnell4@houston.rr.com | | |
2,532
guests, and 429
