| Gibing Dagger Boards? #62754 12/12/05 08:40 AM 12/12/05 08:40 AM |
Joined: Sep 2004 Posts: 126 southern Ontario Twister OP
Posts: 126 southern Ontario | I was looking at the list of changes to the new F18 Infusion on the nacra.ca website. I noticed 2 things. Fistly, it has gibing dagerboards. What are these? Maybe sailing the boardless darts I am out of the board technology loop. Secondly it is said to have canted hulls. I thought the F18's had tried that with the Inter 18's and had gotten away from the canted hulls? Any thaugts? In comparison most of the newer F16's (Blade) do not have canted hulls, or do they? cheers Ryan Dart 18
Ryan Dart 18 #4860
| | | Re: Gibing Dagger Boards?
[Re: Twister]
#62758 12/12/05 02:59 PM 12/12/05 02:59 PM |
Joined: Mar 2002 Posts: 984 2017 F18 Americas Site Dan_Delave
Posts: 984 2017 F18 Americas Site | Where does it say in the F18 rules that gybing daggerboards are not legal? This is from the rules. B.1.4. DAGGERBOARDS AND RUDDERS The platform shall be equipped with a pair of rudders and, if fitted, a pair of daggerboard or centerboards. The dagger board boxes and the rudders have to be in the vertical plan of the hulls. The daggerboard or centerboards and rudders may be made using epoxy resin. Carbon may be used for the construction of daggerboard, centerboards or rudder blades. All underwater appendages must be symmetrical. After sailing the new boat with and without gybing boards it did not seem enough difference in performance. I thought that Pete decided not to use them on the boat. The hulls are canted to allow the daggerboards to be canted. I would say about 4 degrees. This means that they have two molds for the boat one for starboard and one for port. Dan | | | Re: Gibing Dagger Boards?
[Re: Twister]
#62760 12/12/05 07:32 PM 12/12/05 07:32 PM |
Mystere Twister (F18) came out with gybing boards. However no catamaran has yet proven that gybing boards are advantagious. On monohulls (only one board to worry about) it is sometimes used.
Canted ? Most F18's have done away with hull canting. There doesn't seem to be to much performance gain if any. Non-canted hulls are cheaper to produce (need only one mould) This is one reason why current F16's don't have canted hulls. With the F18 world champion boat of the last years being non-canted designs : Tiger and Cirrus F18's and to top 20 being dominated by non-canted designs. One can have a good argument of whu canted hulls are not needed.
436
guests, and 52
