| Re: Carbon superwing masts on F16's?
[Re: rbj]
#63375 12/23/05 08:26 PM 12/23/05 08:26 PM |
Posts: 9,582 North-West Europe | Although I've also read these are readily available on A-cats, unless I've missed it, I have yet to see them available on any F16 (understanding that the carbon mast on the stealth is not a superwing mast).
Well, the Stealth carbon mast is special in its own right, with a tapered top section and it is a breeze to right. But you are right in the sense that we haven't seen a carbon mast in the F16 class yet with a crossection profile as used by the A-cats and the (alu) Superwing mast. So what's the story here - are they now available (or are they perhaps rumored or expected to soon be available)?
Pretty much if you lay down the money for one then you can have one. I think it is safe for me to say that we'll see a second commercially available F16 carbon mast (with A-cat cross section) being introduced in the foreseeable future. I know a certain supplier has indicated looking into it. That is all I'm allowed to say at this moment, I think. Since the aluminum superwings are so good, what will be the benefit of a carbon mast? I would guess it might be a little lighter and maybe the stiffness could be tuned for sailor weight and/or desired mainsail luff shape, but would that be worth the extra cost?
The carbon mast would certainly be lighter, probably by some 3 to 4 kg overall not more. This is because the F16 rules has rule that limits weight reduction on the mast section. This is done to keep alu and carbon masts in the same performance ballpark and to garantee seaworthyness of the design. Having said this, I'm told by carbon mast builders that the F16 rule is pretty decent for carbon masts. They can be build lighter still but the min weight in the F16 rules is a pretty good average for a dependable mast without going overboard. The builders like this as well, it levels the playing field a little bit and gives customers protection against special (disposable) masts. It is considered a good compromise. My personal opinion is that a carbon mast can be made to suit any crew set/crew weight/sailing style and in that sense it is attractive. The lighterweight will make the boat feel more stable and make righting singlehandedly a breeze. Having said this I expect the alu mast to be a better compromise for crews who switch between doublehanded sailing and singlehanded sailing often. It is also a very attractive option moneywise and it will hold up better to things like UV-degradation and outdoors storage. I regard the alu version to be pretty capable already and in that way I don't expect that much difference between the masts. I always understand that a full sail can always be made flatter by bending a mast (alu rig) but that a stiff/flat rig (carbon) can never be made fuller (using only normal trim controls). In this sense I feel that an alu mast has a larger range of usage (2-up to 1-up and back). So in summary I don't think one is per se better then another; it all dependents on your way of sailing and the configurations your are exepect to sail in the most. I would bet they would be less durable, both to damage and UV.
But the new carbon mast are quite developped in this respect by now; indeed alu last forever, but I don't think carbon is comparable to say 10 years ago anymore. Wouter
[Re: Wouter]
#63376 12/23/05 10:59 PM 12/23/05 10:59 PM | Anonymous
| Anonymous
Unregistered | Hey I know I haven't been posting much lately, but you seem to have forgotten F16 altered has been using Carbon A class section mast for over a year. It is a OZ built second hand A class mast, which I put Cedar timber cross ways up the inside covered with epoxy glue. This has made it bullet proof and brought it up to F16 min. wieght. I believe second hand A class Carbon masts are certainly a option for the individual F16 sailor, especialy as some are now considered to heavy or stiff for A's and anything other than a Fibrefoam is considered not good enough in OZ for most A sailors, meaning there are some second hand ones around. Saarbergs (European made) and Applied Composites (OZ made as used on Altered) are the non popular ones I have heard of. There is also a modified Taipan 5.7 getting around with what looks like a A class section carbon mast on it, I think it was built in Sydney. If it is strong enough for the 5.7 it would certainly handle a F16. Regards Gary. | | | Re: Carbon superwing masts on F16's?
[Re: ]
#63377 12/24/05 04:27 AM 12/24/05 04:27 AM |
Posts: 3,528 Looking for a Job, I got credi... | My personal opinion is that a carbon mast can be made to suit any crew set/crew weight/sailing style and in that sense it is attractive. The lighterweight will make the boat feel more stable and make righting singlehandedly a breeze. Yes, agree. When speccing a carbon mast, you can work out the bend charicteristics you want and then get it built into the actual construction. A "whippy" top to allow some automatic gust response when the appropiate amount of weight is out on the wire so allowing you to have less work to do when it's gusty etc. But it will mean that people need to understand this when buying a 2nd hand boat with a carbon stick - if it was sailed by fat bloke(s) then the mast will be too stiff for think bloke(s) and visa-versa.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Carbon superwing masts on F16's?
[Re: scooby_simon]
#63378 12/24/05 03:58 PM 12/24/05 03:58 PM |
Posts: 186 | Thanks, guys, for your feedback. Good points all. I had forgotten about your carbon rig, Gary, sorry! Wouter, you got at one of the issues I was hoping someone would address, which is that I suspected that carbon rigs may have a slightly more limited range even if they can be more precisely tuned for one specific set of conditions. But I'm not sure if that necessarily has to be true. Even though I'm under the impression that carbon overall is stiffer than aluminum in general, I would think that the overall characteristics of the aluminum mast (range) could be duplicated in carbon, but maybe the cost would negate the benefit of the lighter weight. Specifically, I'm thinking in terms of wall architecture, not only fiber thickness/direction but also reinformcents/ribbing etc analagous to what was done on the aluminum extrusion.
It's interesting that in windsurfing, where virtually all the masts are carbon, the entry level models are 50% or 75% carbon whereas the premium masts are 100%. The best racing masts are 100% prepreg. The lower carbon content masts are good, but you can feel a difference in the higher end masts, both in weight (especially for really big sails) but also in "dynamic response", ie, twisting off of the tip in gusts or when pumping for example.
My last question is: if a one were to buy a carbon mast tuned for one's weight, when sailing it vs an aluminum mast, what would one feel as the key differences; especially, how would the two rigs compare a) as wind strength increased and one needed to depower, and b) in very gusty weather?
Jerry | | | Re: Carbon superwing masts on F16's?
[Re: phill]
#63380 12/25/05 05:27 PM 12/25/05 05:27 PM |
Posts: 6,049 Sebring, Florida. | Phil, the Inter 20 carbon masts are all painted white for protection. Obviously this adds weight but how much?
I was concerned when I first got my Jav 2, with it's black carbon mast, because I live in Florida and leave the mast up on the boat in my backyard (lake front) all summer. I was surprised some times on a hot day, I would touch the mast and it was not all that hot, not nearly as hot as what a black peice of metal would be in direct summer Florida sun (most black cars get up to 140 degrees F. in the direct sun)
So, how big a deal would it be to paint the carbon mast white? That would give it some scratch protection as well. You sure don't see any black carbon A cats sailing around.
Blade F16 #777
[Re: phill]
#63384 12/26/05 04:21 PM 12/26/05 04:21 PM |
Posts: 6,049 Sebring, Florida. | I'm sure the I20 mast would be lighter if left black but they offer a warrenty. On a side note, the Corsair F28 C masts are all white and most other carbon masts and hulls are white. I don't know if it's paint or gelcoat.
Blade F16 #777
| | | Re: BIM 16
[Re: Wouter]
#63386 12/27/05 01:00 AM 12/27/05 01:00 AM |
Joined: Jan 2004 Posts: 196 Arkansas, USA CaptainKirt
Posts: 196 Arkansas, USA | Wouter- Don't forget the original BIM 16 here in the US had a RIBA CF mast derived from their A cat CF mast, and that was way back in the origination days and the reason we did not "outlaw" CF at that time-
Kirt Taipan 4.9 US159
Kirt Simmons Taipan, Flyer
[Re: phill]
#63387 12/27/05 09:09 AM 12/27/05 09:09 AM |
Posts: 548 MERRITTISLAND, FL |
I'd be interested to find out how they make the I20 masts considering they feel the need to paint them.
Phill, I am not sure about the new sections, but the Omohundro masts were made on a male mandrel, and if you chipped off the paint you were looking at a significant amount of fairing compound. The paint was primarily a quick way to dress it up. M | | | Re: Hull infusion process
[Re: phill]
#63391 12/27/05 10:37 PM 12/27/05 10:37 PM |
Joined: Jun 2001 Posts: 342 Lake Murray, SC,USA Cary Palmer
Posts: 342 Lake Murray, SC,USA | My personal view is that for hull construction Infusion is the way to go when considering, cost,quality and controlling quality as well as ease of construction. Just the way I see it.
Phil: Is that the whole idea behind the new Nacra Infusion? I know they redesigned the hulls, but is the name from the change in a hull laminating/layup process? What in nonengineeerspeak, is that process and the difference between those type of hulls and what is currently being produced? Hate asking you the question, but since it came up I felt I oughta take the opportunity. Especially awkward question since the Nacra Infusion Hull shape seems a pretty close visual clone of your Blade-18 design. Just my impression. Cary
CARY ACAT XJ Special C&C 24
11,722
guests, and 268
