Jib/f14 #63450
12/23/05 08:55 PM
12/23/05 08:55 PM
stags209 Offline OP
stags209  Offline OP
Is it possible to take a hobie 14 jib and put it on the wave. If so, i think the wave could compete against the hobie 14's. With a trapeze and the hooter it will probaly crush it considering rick beat hobie 16's with it.
Re: Jib/f14 [Re: stags209] #63451
12/24/05 10:07 AM
12/24/05 10:07 AM
RickWhite Offline
RickWhite  Offline
There just doesn't seem to be enough room for a jib with the present layout of the Wave. The mast is so far forward and that only leaves room for a sliver of a jib. I had one made and it is pretty useless. On DPN you would take a big hit and gain very little speed.
Even on the H14, the jib is not that much help.., although it does make the boat tack faster and easier.
Rick
Rick White
www.onlinemarinestore.com
Re: Jib/f14 [Re: RickWhite] #63452
01/13/06 04:06 PM
01/13/06 04:06 PM
Norfolk, VA
Dan Berger Offline
Dan Berger  Offline
Norfolk, VA
I agree, the jib doesn't help much and it kills you on handicap. However, it is a hundred times easier to tack. I'm faster on my 14 uni than the Turbo guys and I correct over them to boot.
If you want a big performance boost and if you want to sail with the F14s, get one of Rick's hooters. He has the system worked out for the Wave.
Dan Berger
Norfolk, VA
A Cat USA139
Supercat 15
Re: Jib/f14 [Re: Dan Berger] #63453
01/13/06 10:27 PM
01/13/06 10:27 PM
stags209 Offline OP
stags209  Offline OP
Thanks, i know abotu the hooter, but im to short on money. Hey Rick, maybe you can give me a hooter kit ofr free, and i can test it out a bit more, lets say, a year or so.....
0 registered members (), 2,851 guests, and 90 spiders.
