Taipan rudder system #63746
01/01/06 10:21 PM
01/01/06 10:21 PM
Thailand
Buccaneer Offline OP
Thailand
Is it possible to add another hole to the Taipan rudder system so can adjust for operation in shallow water?
I've got a shallow reef (about 500mm) that I need to travel daily to get out to the deep water.
Happy holidays!
Re: Taipan rudder system [Re: Buccaneer] #63747
01/01/06 11:28 PM
01/01/06 11:28 PM
Depending on the type of rudder stock (19X19 al tube, casting or carbon) there may not be a lot of support to the rudder.
Letting the leeward rudder trail and hold the windward one down partially with both tiller and rod in hand may encourage you to take it a little easier and ensure your rudders are not overloaded.
But essentially in answer to your question. Yes you could.
(I they are carbon stocks I'd also add another stainless plate for the hole.)
Re: Taipan rudder system [Re: phill] #63748
01/03/06 02:21 AM
01/03/06 02:21 AM
Thailand
Thailand
Thanks Phill,
Of the three the carbon looks to be the best candidate because it's straight. The casting style bends down towards the hulls and the al tube bends up? Do you think it would work on all three? I presume the stainless plate for the hole would be critical.
Happy holidays!
Re: Taipan rudder system [Re: Buccaneer] #63749
01/04/06 01:15 PM
01/04/06 01:15 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Won't you find it hard to steer with the blades pivoted up even a small amount? Why not just leave the lock down rod out of the tiller arm hole and strap it along the arm with a bungie or velcro? If am inpact occurs, the rudder will put up quite easily.
BTW, I've hit a few marine sunfish (~3'x3', slow moving, surface loving beast) doing 20kts on my Tornado. The AHPC taipan rudders popped up beautifully everytime, no damage to blade or release system (but I think the fish didn't fair quite so well ). I really liked that setup...simple, reliable, low cost, light. My new boat came with the Marstrom system stocks. While thay also use a lock down arm, there are a lot of little springs/rollers involved and they do not hold up at all when you hit something. Might try to modify the stock to be more like the AHPC's.
Mike.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
One possible alternative [Re: Buccaneer] #63750
01/04/06 01:56 PM
01/04/06 01:56 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
A pivoting dagger rudder could be your ideal solution.
See attached.
Luiz
Luiz
Re: One possible alternative [Re: Luiz] #63751
01/04/06 03:35 PM
01/04/06 03:35 PM
What will happen when your rudder is not fully down and you hit an underwater object ?
I rest my case.
Re: One possible alternative [Re: Wouter] #63752
01/05/06 11:27 AM
01/05/06 11:27 AM
Thailand
Thailand
Why what will happen?
Thanks
Re: One possible alternative [Re: Wouter] #63753
01/05/06 04:26 PM
01/05/06 04:26 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
If this is a major concern, then another solution is the system used in the F33, where the entire cassette pivots. This system seems to be more complex, more expensive and heavie, though.
Luiz
Re: One possible alternative [Re: Luiz] #63754
01/06/06 07:34 AM
01/06/06 07:34 AM
To be honest,
I don't understand what the others are looking for, the new AHPC stocks are just fine. It is not a problem sailing with them unlocked over a shallow. 500 mtr ? Not a problem. I do 250 mtr or slightly more when I traverse the surf and I'm doing alright; so I don't see how 500 mtr can be a problem.
But indeed your suggestion would be a solution.
Re: One possible alternative [Re: Wouter] #63755
01/06/06 09:03 AM
01/06/06 09:03 AM
Use the force Luke....steer with your sails until deep enough to use rudders.
Re: One possible alternative [Re: Luiz] #63756
01/06/06 10:37 PM
01/06/06 10:37 PM
maui
jollyrodgers Offline
maui
so, is the idea that there wouldn't be much weather helm w/ the rudder 1/2 down in the dagger possition?
if it works like that and you need more control than pulling the jib in too tight and luffing the main with rudders dragging behind gives, it sounds like a great idea.
Re: One possible alternative [Re: jollyrodgers] #63757
01/07/06 04:00 PM
01/07/06 04:00 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
Exactly. Plus you may use only part of the rudder when racing in light conditions or downwind to reduce drag.
Luiz
Re: One possible alternative [Re: Wouter] #63758
01/12/06 02:57 AM
01/12/06 02:57 AM
Thailand
Thailand
Ok maybe not necessary in most cases. But it seems it would be better then converting over to a bungee system.
To be honest,
0 registered members (), 256 guests, and 42 spiders.
