| Re: solo righting
[Re: woodsskiier]
#640 05/11/02 11:23 AM 05/11/02 11:23 AM | Anonymous
| Anonymous
Unregistered | Hi, I am working on a "paddle" that doubles as a lever for solo righting to get my weight out away from the hulls for increased leverage. Tests on land work easily and well. Will send pix if you want to....also doubles as a paddle, if you ever need on and it stows neatly under the rear tramp lacing.
Nigel
H14
A_over_T
| | | Re: SoloRighting
[Re: cowboy68]
#644 07/07/06 07:57 AM 07/07/06 07:57 AM |
Posts: 152 Central Texas | I think the soloright is no longer available. The idea is great and works well. I think Hobiegarry does not mind if you build your own based on his idea. A portion (in my case the upper 1/2) of a windsurfing mast with a laminated paddle area works well for me. Search the forum - I remember I posted pic's.
Patrick
Patrick, Hobie 16 '85
| | | Re: SoloRighting
[Re: yoh]
#645 07/10/06 07:04 PM 07/10/06 07:04 PM |
Joined: Jun 2006 Posts: 98 Santa Fe, New Mexico, USA WillLints
Posts: 98 Santa Fe, New Mexico, USA | Patrick, solo righting thread was started in '01 and the attachments don't work. can you be more specific about searching for the pictures that you've posted? i've mostly soloed my H16 since '99 and i've gotten to where i can usually get the turtle half over by walking to the stern with righting line, on the leeward hull. the bow comes up enough to get wind under the tramp and then i start walking foreward as she roles around. But from there it's the big bucket and or the shroud extenders. the extenders work well but being solo you can't get them back to the same hole they were in when you left shore because you are still in the heavy air which blew you over and working on the lee side of the boat.
Will_Lints one-up, Blade 706, epoxy bottoms
| | | Re: SoloRighting
[Re: WillLints]
#646 07/11/06 11:14 PM 07/11/06 11:14 PM |
Posts: 152 Central Texas | http://www.catsailor.com/forums/showflat...=true#Post41920Check this link - I posted some pics there - click the "attachment" in the thread. The cat in the pictures is not an essential part of the set up. I have only encountered a few turtles and fixed them exactly the way you described them. On windy days (15 mph and more) I do not need the pole - then I can actually righten the hobie just with the line. On milder days (10 mph and less) I have trouble getting the thing vertical. This is what I have the pole for. Some guys here on the forum might argue that on the mild days I should not capsize <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> Patrick
| | | Re: SoloRighting
[Re: yoh]
#647 07/13/06 09:15 PM 07/13/06 09:15 PM |
Posts: 98 Santa Fe, New Mexico, USA | Thanks Patrick, i'm still a little slow on this idea. Do you install the device as outlined in the text and then use the pole to walk out on, thus giving the solo sailor a big boost in leverage?
| | | Re: SoloRighting
[Re: WillLints]
#648 07/14/06 08:13 AM 07/14/06 08:13 AM |
Posts: 152 Central Texas | Yop! Some day I might try to ave someone take pix while in action.
Patrick
20,179
guests, and 445
