| Re: Trailer box
[Re: PTP]
#64148 01/06/06 06:28 PM 01/06/06 06:28 PM |
Posts: 744 | Somehow I have to think you are not putting your trailer in the water! I know you sail near Pcola. Do you feel the need to use a concrete boat ramp? Nobody (using this loosely) around this area does such a thing!!
Bob
| | | Re: Trailer box
[Re: PTP]
#64149 01/06/06 06:38 PM 01/06/06 06:38 PM |
Posts: 915 Dublin, Ireland | I'm sorry - I really don't mean any offence, BUT, you put your road trailer in the water ? I have never seen a catamaran road trailer in the water. I don't believe that any wheel bearings are totally waterproof. Build a box AND build a launching trolley.
Dermot Catapult 265
| | | Re: Trailer box
[Re: Dermot]
#64150 01/06/06 06:56 PM 01/06/06 06:56 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Well, powerboat trailers put everything underwater all the time when launching and retrieving their boats, and some of them trailer their boats for long distances. So, it can be done.
But beach-cat sailors normally have beach wheels, take their boat off the trailer, and launch and retrieve from the ramp (if using a ramp) using the beach wheels rather than the trailer. | | | Re: Trailer box
[Re: Mary]
#64151 01/06/06 07:17 PM 01/06/06 07:17 PM |
Posts: 2,921 Michigan | Well, I am glad I asked now! I usually don't even use the trailer (my cat is a true "beach cat" and stays on the beach for the most part) I have noticed that people don't usually put their cat trailers in the water (if they do, its only part of the way). I do have beach wheels but how do you not screw up the hulls sliding the boat off the trailer onto the wheels? I have four cradles on my trailer and I have heard you shouldn't use rollers. I guess it shouldn't be too bad. Ok... but how do you get the boat back on to the trailer? I mean, the thing isn't necessarily light As far as what mary said- I agree... trailers are made to go in the water.
| | | Re: Trailer box
[Re: mikekrantz]
#64153 01/06/06 07:59 PM 01/06/06 07:59 PM |
Posts: 1,911 South Florida & the Keys | I installed stainless steel vents fore nd aft on my box pluss added weep / drain holes to the bottom to let it breath. My trailers have never been in the water....on purpose that is.
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: Trailer box
[Re: arbo06]
#64154 01/06/06 08:01 PM 01/06/06 08:01 PM |
Posts: 2,921 Michigan | eric- how do you get your boat out of the water onto the trailer? I am sure that ARC 21s aren't the type of boat two people can lift onto a trailer.
| | | Re: Trailer box
[Re: PTP]
#64155 01/06/06 09:27 PM 01/06/06 09:27 PM |
Joined: Jun 2001 Posts: 342 Lake Murray, SC,USA Cary Palmer
Posts: 342 Lake Murray, SC,USA | would this create too much bouyancy and have the trailer possibly float when you put it in the water to load the boat? Most trailer boxes leak some. Otherwise rain would not be able to leak out. Use your trailer in Fresh water, cattrax it off in salt. Not to worry. CARY
CARY ACAT XJ Special C&C 24
| | | Re: Trailer box
[Re: Cary Palmer]
#64156 01/06/06 09:42 PM 01/06/06 09:42 PM |
Posts: 1,121 Eastern NC, USA | Ditto Zuhl. Fresh water is ok to sink the trailer, but better not try it in salt water too often.
I've always used front cradles and rear rollers (for easier off loading on a ramp in fresh water). I do add extra cushioning on the rear rollers when trailering out of the club grounds. Seems as if most of the weight is on the main beam (i.e. front cradles) when stored with the mast up.
Tom | | | Re: Trailer box
[Re: mbounds]
#64158 01/07/06 07:22 AM 01/07/06 07:22 AM |
Posts: 3,528 Looking for a Job, I got credi... | Use the launching trolly always. Simpler by far ! Build your box with breather holes in it so when you put your sails away wet (it might happen  ) they can breath for the time they stay in the box.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Trailer box
[Re: PTP]
#64160 01/07/06 08:57 AM 01/07/06 08:57 AM |
Posts: 45 Commerce Twp, MI | First...some advice. NEVER immerse your cat trailer in the water, NEVER. You are asking for trouble. Sure powerboats do, but how many times have you seen them broken down on the side of the road missing wheels, broken supports or non-functioning lights? My previous trailer was 18 years old, made of steel and had over 200,000 miles on it. It was well maintained, never put in the water and never had travel issues. My current trailer is an aluminum Trailex. You can use a ramp and back the trailer to were the rear support is just above the water. Lift your bows and the whole thing slides right off. Repeat the process for retrieval. If your having problems getting on the trailer, mount a winch on the front mast support and winch it on. Get a set of beach wheels. You can launch from anywhere (ramps too) with beach wheels and roll your boat directly into and out of the water. Regarding a sailbox... my winter project last year was to build a new water tight sailbox. I used a "shoe box" design with a removable top. The box is 12 feet long in order to accommodate a fully assembled Tiger spin pole. Since you can't get 12 foot long plywood, I used 8 foot pieces, 1/4" thick and offset laminated them together to make a 12 foot length. After the box was assembled, I glassed it with polyester resin/6 oz. glass cloth and finished with a marine grade paint. It's totally weatherproof and will last many, many years. When I die, I want to be buried in my sailbox
Tiger Sailor
| | | Re: Beach Wheels
[Re: Bob Klein]
#64163 01/07/06 02:44 PM 01/07/06 02:44 PM | Anonymous
| Anonymous
Unregistered | PTP: If you haven't bought some, here is a cheap way to make some wheels. They work GREAT on sand and flat surface, just not to good on uneven ground. Under $100 without cradles and under $200 with (unless you can make your own cradels). http://www.geocities.com/mec_coleman/tip13.htmDoug dsnell4 at houston dot rr dot com | | | Re: Trailer lights
[Re: MauganN20]
#64165 01/07/06 11:06 PM 01/07/06 11:06 PM | Anonymous
| Anonymous
Unregistered |
2,582
guests, and 492
