| Righting system (size of bag needed??) #65410 01/24/06 05:33 PM 01/24/06 05:33 PM |
Joined: Jan 2006 Posts: 23 Bjärred, Sweden Pontus_Lofgren OP
Posts: 23 Bjärred, Sweden | I have a Hobie 16 and I weigh 176 lbs. I have read on the forum that a bag is needed to right the Hobie when capsized. The question is: -Hobie have 2 different sizes of bags, one with capacity 88 lbs, the other one 250 lbs, which one do you think I need given my body weight?
Stealth F16
NED 535
| | | Re: Righting system (size of bag needed??)
[Re: Pontus_Lofgren]
#65413 01/24/06 10:23 PM 01/24/06 10:23 PM |
Joined: Jul 2004 Posts: 125 Clinton, Mississippi rattlenhum
Posts: 125 Clinton, Mississippi | I respectfully (but heartily) disagree with the resposes above. I, too, am about 175 lbs and have righted my Hobie 16 several times solo...without bag or assistance. But those were in ideal conditions....relatively flat water and big wind. I've also been in conditions where there's no way I could have righted it solo without the larger bag.....big waves and lighter (~8kt) wind...alone and a mile or so offshore in the Gulf of Mexico. Many people will tell you that if there's enough wind to dump you then there's enough wind to right solo. However, this doesn't account for situations where a malfunction (trap unhooks or trap line breaks, for example), a lapse in judgement (aka stupidity), or even a rogue gust (that you won't see for the rest of the day) causes you to flip. Believe me (but don't ask how I know all this), when your out there alone and drifting toward the rocks on shore, you'll be glad you had the larger bag!
I got the big bag and practiced with it in NO wind....I can just barely right the boat in such conditions, but knowing it's possible is worth a lot. If you're gonna go bag...go BIG!
Jerome Vaughan Hobie 16 Clinton, Mississippi USA
P.S. to Tom: It was nice to meet you and sail with you guys at Cat Caper. Hope to see you again on the water somewhere this year!
[Re: sailingreach]
#65416 01/24/06 11:58 PM 01/24/06 11:58 PM |
Posts: 5,582 “an island in the Pacifi... | Kinda the same thing with me. The first time I had to right the boat by myself, I had a non-swimmer along who freaked out and did a death grip on a passing canoe. I got the boat up and had to peal her off the canoe. That was the first AND last time I ever took someone out who couldn't swim.
US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Righting system (size of bag needed??)
[Re: hobie1616]
#65417 01/25/06 10:32 AM 01/25/06 10:32 AM |
Posts: 1,121 Eastern NC, USA | I am not a H16 sailor, but it seems as though 250 lbs should right a H16 in most conditions. If you need an additional 220 lbs of ballast to right the boat, then I would think something else is wrong. A couple of things to think about: main downhaul loosened, main sheet released, traveler released and most importantly - is the mast sealed at the top? A leaky mast head will certainly cause righting problems. Am I way off base in my assumption that this amount of weight should be sufficient?
Jerome, could this be your problem? Cat Caper was a good time. I have a new boat coming in March. If I had to pick between Slip-to-Ship or Island Hop - which should it be?
Tom | | | Re: Righting system (size of bag needed??)
[Re: tshan]
#65418 01/25/06 11:35 AM 01/25/06 11:35 AM |
Posts: 306 St. Louis, MO | I weight about 250 lbs and sailed my H16 solo all the time. I have found that in light wind conditions I could right the boat, but it took time.
I think the best solution is to buy the big bag. That way if you need the weight you will have it. You can always decrease the amount of water in the bag as needed. The ease of this will depend on how you rig it.
Nick
Current Boat Looking for one
[Re: tshan]
#65422 01/25/06 06:38 PM 01/25/06 06:38 PM |
Posts: 125 Clinton, Mississippi | I am not a H16 sailor, but it seems as though 250 lbs should right a H16 in most conditions. If you need an additional 220 lbs of ballast to right the boat, then I would think something else is wrong. A couple of things to think about: main downhaul loosened, main sheet released, traveler released and most importantly - is the mast sealed at the top? A leaky mast head will certainly cause righting problems. Am I way off base in my assumption that this amount of weight should be sufficient? Excellent points, but I'm certain none of these are my problem. Perhaps it's not the weight but rather that I'm too damn short! Seriously, though, I think the key is "in most conditions". I probably could right my H-16 solo most of the time with the smaller bag. However, I sail solo in the Gulf, in winter, etc. a lot when there's no one close to help out, and I think one should be able to right solo reasonably quickly every time.....your boat or your life could possibly be at stake. If I had to pick between Slip-to-Ship or Island Hop - which should it be? Slip To Ship....definitely! Better weather (especially if you're camping), better wind probabilities, and better turnout. It's typically much hotter for Island Hop but still a blast. I'll do my best to attend both, but won't plan on being able to camp for Island Hop. See you there! Jerome
1,986
guests, and 437
