| Re: Advice on Hobie 16 hull repair
[Re: stevegarlick]
#65502 01/27/06 09:19 AM 01/27/06 09:19 AM |
Posts: 1,187 38.912, -95.37 | It somewhat depends on what year your boat is. For instance 1979's had some serious delamination problems and would not be worth the effort to repair and you'd be better off with a replacement.
How did this happen? Describe or post pictures of the damage. That would help in advising the best remedy. 1979 highlight serious
[Re: hrtsailor]
#65504 01/27/06 10:57 AM 01/27/06 10:57 AM |
Posts: 152 Central Texas | delamination issues are not limited to '79 models. Plenty of the old boats have soft hulls. It sounds like your boat is damaged in an area where a good amount of forces work on the hull anyway. From the little I have read I would not recommen to repair. Post some pix for a better assessment. Patrick
Patrick, Hobie 16 '85
[Re: jmhoying]
#65514 01/28/06 10:36 AM 01/28/06 10:36 AM |
Posts: 2,921 Michigan | I think it could be fixed... but I think the key is to over-build the shroud attachment to distribute the load further down into the hull. But yes, it won't be pretty unless you are a perfectionist (and I am not... as you will soon see pics of my trailer box). Ah, what do you have to lose? Get some west system, some fiberglas cloth and go crazy.
[Re: PTP]
#65517 01/30/06 03:13 PM 01/30/06 03:13 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | I don't think your going to be able to repair that by glassing though a couple of ports. If I was going to even try that repair I would do it by cutting a hole or slot in the inside hull large enough to actually be able to work on it. I notice the foam blocks there so they would have to be removed to do the work.
The other thing's I would consider would be pulling the cap, making the repairs and reinstalling it or glue it together good enough to make a mold of the deck and then make your own part.
If you are able to fix this hull you might want to add a small port to the other side and glass the deck to the hull in that area. Good luck.
[Re: catman]
#65518 02/03/06 11:48 AM 02/03/06 11:48 AM |
Posts: 152 Central Texas | I do not know what a used Hobie sells for in your area... from my experience here in TX parting out and finding a replacement would be the way to go. If you decide to repair... I would try to remove the deck in one piece. Make the repairs to hull and deck separately. This will be still pretty difficult since in most areas you will deal with a sandwich made from composite material and a layer of foam. At least you will have space to work on the part from both sides. You will also be able to use a power sander to prep areas that would be otherwise not accessible. I would not try to make a mold and recreate the deck as a whole (to difficult for most people to build such a piece as a sandwich composite construction). Once deck and hull have been repaired just epoxy them back together. You could use a longer piece of stainless steel to create an anker for the shroud to spread the load over a larger area. Good luck.
Patrick
2,948
guests, and 224
