| Re: 5.8 lowering main
[Re: GeoffS]
#65598 08/03/06 10:23 AM 08/03/06 10:23 AM |
Joined: Jun 2006 Posts: 35 Charlottesville, VA sruffner
Posts: 35 Charlottesville, VA | Jake - Yeah, actually, the sail will not slide down nor move up without a pretty good amount of force on it. I am starting to think this may be the root of my issues though. I can pull it down by hand, I just use the downhaul line to do so. I think it may be time to try to agressively clean the luff and perhaps check the rope for shrinkage - if the luff rope has shrunk too much, I can see the tape bunching up in such a way that it is "thicker" than will move easily in the mast. I may resolve my issues altogether by getting the sail to move smoothly and easily in the track. I'll search the forum archives for threads on sail cleaning and luff rope shrinkage.
DaveW - I am going to run the sail up the mast to see where things are tight, and to see that I've got the correct clearances on things. The hook is off to one side slightly already, but I will consider bending it, and check that the offset in the aussie ring tilts the ring the right way to help move away from the hood when the mast is rotated.
GeoffS - Heh, yeah, I grew up here, but didn't go to St. Anne's, but went to VES and then UVa. I live in the neighborhood between St. Anne's and UVa. There really isn't anywhere here, but the Chesapeake Bay is only a two hour drive which I don't mind. I will try your suggestion on the boom. Thanks! | | | Re: 5.8 lowering main
[Re: peterbro1]
#65599 08/04/06 02:21 PM 08/04/06 02:21 PM |
Posts: 851 US Western Continental Shelf | Tie the back end of the main halyard to the top of the ring where the front end of the halyard attaches. Now you have a loop like a drapery pull cord. When it is time to remove the ring from the hook, pull on the lazy end of the halyard to bring the top of the ring back and away from the hook.
GARY
Santa Monica Bay Mystere 6.0 "Whisk" <--- R.I.P. | | | Re: 5.8 lowering main
[Re: hobiegary]
#65601 08/07/06 07:01 AM 08/07/06 07:01 AM |
Joined: Mar 2005 Posts: 2,074 Northfield,NH USA bullswan
Posts: 2,074 Northfield,NH USA | ME Too. Does anyone have a picture of the "make the knot come out the back of the ring". I am stuck with a mental block on this topic. Anyone else wish there was an "emergency blow!!" type of release that could be done under extreme conditions when you just have to get the main down AFAP (as fast as possible)? That would be great. A quick release clip that could be done even with the sail under load. Has anyone thought of how that could be done?
Greg
The nice part about being a pessimist is that you are constantly being either proven right or pleasantly surprised. - George Will "It's not that liberals aren't smart, it's just that so much of what they know isn't so" -Ronald Reagan | | |
2,528
guests, and 606
