H21 SC center boards #66160
02/04/06 04:42 PM
02/04/06 04:42 PM
Tom5p5 Offline OP
Tom5p5  Offline OP
Its time to replace the lines on the centerboard on my Sport Cruiser.
Is it possible to do the job from the topside? Any tricks avail to avoid pulling the whole board out, would be appreciated.
Thanks.
Re: H21 SC center boards [Re: Tom5p5] #66161
02/04/06 06:34 PM
02/04/06 06:34 PM
California
mmiller Offline
mmiller  Offline
California
You have to lower the board down out of the well to replace the lines. The following tech piece is on the Hobie Cat Support pages. It is showing a spring replacement, but same idea for the lines:
Hobie 21 Centerboard springs and lines
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: H21 SC center boards [Re: Tom5p5] #66162
02/05/06 10:45 AM
02/05/06 10:45 AM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
- Untie or cut the knot in the handle. Remove the handle.
- Attach (stitch or tape) the old rope to the new one where the handle was. You may do without this step, but it will make your life easier.
- Heel the boat so that the hull you are working at lifts about 3 or 4 ft.
- Lower the CB until you can reach the lifting rope from the bottom. The spring will keep the CB from falling.
- Pull the old rope from the bottom, cut the stitch/tape and tie the new rope to the CB as before.
Repeat for the other side.
Two tips: make thin and neat tail finishes in the new rope before changing and use very low stretch line.
I never did it in the water, but I guess it is feasible in shallow water as well as in dry ground.
Luiz
Re: H21 SC center boards [Re: Luiz] #66163
02/05/06 06:50 PM
02/05/06 06:50 PM
Tom5p5 Offline OP
Tom5p5  Offline OP
Thats great. Thanks.
Re: H21 SC center boards [Re: Tom5p5] #66164
02/06/06 09:25 AM
02/06/06 09:25 AM
I must say that the H21/H17 centerboard system is great to use, but a pain in the butt to maintain. Those damm boards gave me fits with my H17....
When its working, its great... don't have to worry about sandbars! Unfortunately, I could never keep the wells from leaking, or the boards from breaking.
Re: H21 SC center boards [Re: MauganN20] #66165
02/06/06 10:27 AM
02/06/06 10:27 AM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
...or the ropes to wear too fast.
Luiz
0 registered members (), 188 guests, and 47 spiders.
