| Re: H21 SC center boards
[Re: Tom5p5]
#66162 02/05/06 10:45 AM 02/05/06 10:45 AM |
Posts: 1,307 Asuncion, Paraguay | - Untie or cut the knot in the handle. Remove the handle. - Attach (stitch or tape) the old rope to the new one where the handle was. You may do without this step, but it will make your life easier. - Heel the boat so that the hull you are working at lifts about 3 or 4 ft. - Lower the CB until you can reach the lifting rope from the bottom. The spring will keep the CB from falling. - Pull the old rope from the bottom, cut the stitch/tape and tie the new rope to the CB as before.
Repeat for the other side.
Two tips: make thin and neat tail finishes in the new rope before changing and use very low stretch line.
I never did it in the water, but I guess it is feasible in shallow water as well as in dry ground.
Luiz
[Re: Luiz]
#66163 02/05/06 06:50 PM 02/05/06 06:50 PM |
Posts: 6 | | | | Re: H21 SC center boards
[Re: MauganN20]
#66165 02/06/06 10:27 AM 02/06/06 10:27 AM |
Posts: 1,307 Asuncion, Paraguay | I must say that the H21/H17 centerboard system is great to use, but a pain in the butt to maintain. Those damm boards gave me fits with my H17....
When its working, its great... don't have to worry about sandbars! Unfortunately, I could never keep the wells from leaking, or the boards from breaking. ...or the ropes to wear too fast.
Luiz
1 registered members (nutsy),
529
guests, and 74
Mod | | Forums26 Topics22,406 Posts267,061 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
