| Re: Mooring a Hobie
[Re: niko11709]
#6632 04/29/02 08:27 AM 04/29/02 08:27 AM |
Posts: 283 | I would not recommend mooring a Hobie. If a good wind comes along, you may come back to a capsized boat, on top of the fact that it's not good for your boat bottom.
Here in MN, we keep our boats on the water on a rack made of 2 X 6's or 2 X 4's. Would the water be too deep where you are to do that?
All you have to do is make an 8 x 8 foot box, put a dock post in each corner, shove your boat up on that, tie down, and you're done!
I built a much more elaborate rack, which I really like, but it really isn't necessary for a bullet proof Hobie 16. put some carpet on there where your hulls go, and you won't scratch it all up.
Pardon my ignorance, but where is "LI"?
Good luck!
Tim J.
Tim D. Johnson
Hobie 20 #690
Bald Eagle Yacht Club, Fleet 52
www.beyc.org | | | Re: Mooring a Hobie
[Re: niko11709]
#6634 04/29/02 10:32 AM 04/29/02 10:32 AM |
Joined: Jul 2001 Posts: 397 Burlington, Vermont USA Kevin Rose
Posts: 397 Burlington, Vermont USA | Any boat that is going to be kept in the water (fresh or salt) will need bottom paint. Without it, water will get into the gelcoat/hull and eventually show as blisters (and a waterlogged hull). Bottom paint provides the sealant to keep the water out.
Kevin Rose
N6.0na #215
Lake Champlain (New England's "west coast")
Burlington, Vermont
| | | Re: Mooring a Hobie
[Re: Kevin Rose]
#6635 04/29/02 01:21 PM 04/29/02 01:21 PM |
Posts: 251 beaufort, sc | uh, my experience with lead sleds is that bottom paint is very porous and does not seal fiberglass. an epoxy barrier coat is usually applied onto bare fiberglass bottoms to prevent blistering and then bottom paint is applied to prevent fouling.
marsh hawk
| | | Re: Mooring a Hobie
[Re: dannyb9]
#6636 04/29/02 01:38 PM 04/29/02 01:38 PM |
Posts: 397 Burlington, Vermont USA | You're right, I lumped the two step process of barrier coat/bottom paint under the term "bottom paint"
Kevin Rose
N6.0na #215
Burlington, Vermont
| | | Re: Mooring a Hobie
[Re: Kevin Rose]
#6637 04/29/02 08:00 PM 04/29/02 08:00 PM | Anonymous
| Anonymous
Unregistered | I would do everything I could to get the boat on the beach and tried down. We had T storms a couple of weeks ago with wind gust up to 45mph and this will happen all summer in the LI area. I also think your rigging will take a pounding if you have any boat traffic or wind chop. So if your boat has not capsized it will most likely be dismasted when you return. Bottom paint is very slow and belongs on a powerboat not a beach cat. | | | Re: Mooring a Hobie
[Re: Sailortect]
#6640 05/03/02 11:50 AM 05/03/02 11:50 AM |
Posts: 591 Bradenton, FL | I'd go as far as to put the mast-step pin in while it's moored to keep the mast from rotating all the time. What will you do about air expansion inside the hulls? On shore we leave the hull plugs, and maybe even a hatch in each hull, open to let the hot air escape instead of pressurizing things. Even so the condensation is a pain when trying to keep things reasonably dry.
Hobie 14T
| | | Re: Mooring a Hobie
[Re: niko11709]
#6641 05/09/02 04:22 PM 05/09/02 04:22 PM |
Joined: Jun 2001 Posts: 292 Long Island, NY Ed Norris
Posts: 292 Long Island, NY | Even better!
Bring your new hobie down to Field 7 at Heckshire state park. There you'll meet an avid bunch of cat sailors who will cheerfully take you out sailing, teach you the hundred little tricks of hobie sailing, take you out "yahooing" across Great South Bay out on the wire etc. And Great South Bay has 12-17 kts any sunny afternoon all season long.... fun sails, picnic on Democrat point, Lobsterfest, you name it.
Email me and let me know when you're coming down, I'll arrange to meet you or have guys on hand to show you the ropes!
Ed Norris
Sail Fast,
Ed Norris
1,991
guests, and 398
