| Re: H16 Trampoline
[Re: atrobbins]
#66953 02/16/06 07:41 AM 02/16/06 07:41 AM |
Posts: 1,884 Detroit, MI | Keep an eye on eBay - they come up fairly frequently. You can also check out the Hobie Community Forums: Hobie Forums | | | Re: H16 Trampoline
[Re: mbounds]
#66954 02/16/06 10:09 AM 02/16/06 10:09 AM |
Posts: 35 Portland, ME | I have an original for you! It is from my '78 H16 and I just replaced it last summer. The Tramp is one of the Yellow vinyl ones, it's pretty faded out, but there are no holes and all the grommets are in place, the boat was used pretty lightly from the time it was purchased. I can send pictures this weekend if you are interested... I wouldn't want much for it.
jrg
Hobie 16
| | | Re: H16 Trampoline
[Re: jrg]
#66956 02/18/06 12:42 AM 02/18/06 12:42 AM |
Posts: 493 Minnesota | If he doesn't take the tramp, I just might! My yellow tramp is threatening to tear at the rear bolt slide.
Use the private message function and suggest a price with further details on the condition.
| | | Re: H16 Trampoline
[Re: Sunvista]
#66960 02/24/06 03:38 PM 02/24/06 03:38 PM |
Posts: 35 Portland, ME | I'm with you on the bungee. I tried it last summer and I was not at all happy with it. The only thing that kept me from changing it out was the time it took me to do it. I think the boat was "loose" as a result of it and the tramp wasn't really that much more comfortable. That's how I really feel, in case you were curious...  jrg
Hobie 16
| | | Re: H16 Trampoline
[Re: jrg]
#66961 02/27/06 11:05 AM 02/27/06 11:05 AM |
Posts: 306 St. Louis, MO | I like Dacron for tramp lacing. It seems to require the least amount of retensioning from all of the materials I've tried. You could use expensive line like Yale Cordage, but I found the Dacron to be the best compromise between price and streachiness.
Nick
Current Boat Looking for one
| | | Re: H16 Trampoline
[Re: hrtsailor]
#66964 02/27/06 07:01 PM 02/27/06 07:01 PM |
Posts: 1,252 California | they had doubled the number of grommets which obviously is going to double the tension on the tramp The additional grommets actually allow you to disperse the load over more grommets. This helps to prevent grommets from pulling out. | | | Re: H16 Trampoline
[Re: RickWhite]
#66966 03/31/06 02:24 AM 03/31/06 02:24 AM |
Posts: 14 Saipan | I have a prindle 16, I'm also looking for a tramp, I like the tramp on the newer hobie 16's the really bright blue mesh type, is this available anywhere for a prindle 16????
thanks
my wife is a princess therefore I must be a prince
6,094
guests, and 656
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online7,274 45 minutes ago | | |
