Page 1 of 4 1 2 3 4
Towing #67054
02/17/06 09:13 PM
02/17/06 09:13 PM
PTP Offline OP
PTP  Offline OP
Got a quick question for all. Given the recent discussion of MPG, etc. I want to know some opinions.
I have a Subaru 2001 Forrester... something like 170hp, manual trans. Has about 75k miles on it.
I am going to go to Key Largo (about 700 mi) and tow my 6.0. I have towed the boat locally (27 miles, the longest) without any problems. Any reason I should think the car won't make it? I could borrow a friends Dodge pickup but even though the Subaru gets relatively pathetic MPG (24 or so), the Dodge would certainly get worse.
Should I go with the Subaru.. and if so, is there anything I should look out for?
Re: Towing [Re: PTP] #67055
02/17/06 09:40 PM
02/17/06 09:40 PM
Andrew Offline
Andrew  Offline
I'd not worry...make sure your tires are aired up and don't try to set any land speed records and you should be fine.
Re: Towing [Re: Andrew] #67056
02/17/06 09:49 PM
02/17/06 09:49 PM
Don't think you will have any trouble. If it lugs just go to a lower gear.
Doug
Re: Towing [Re: PTP] #67057
02/17/06 10:02 PM
02/17/06 10:02 PM
you're towing capacity (for a 2001 Forester) is 2000 lbs. You're perfectly fine. At the very WORST your 6.0 and trailer weigh 1100 pounds...that is if you've added a bunch of steel and extended your trailer tongue 8' I weighed mine when my 6.0 was on it and my trailer is a rediculously large portion of that 1100 lb equation.
Re: Towing [Re: Jake] #67058
02/18/06 06:30 AM
02/18/06 06:30 AM
YOu will have no problems with the Forester!
I haul my 17 around with an Impreza (ok it's got 208BHP) but it's lighter!
You will hardly notive the drop in MPG; I find mine is similar as driveing without towing as I go slower with the boat on the back
Re: Towing [Re: scooby_simon] #67059
02/18/06 08:09 AM
02/18/06 08:09 AM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
The Suburu will be fine. What condition is the trailer in? Tires, wheels, bearings, etc.? Nothing cuts a trip short like a frozen trailer axle.
t
Re: Towing [Re: PTP] #67060
02/18/06 11:16 AM
02/18/06 11:16 AM
Yes, be careful to downshift (as Doug mentioned) when the engine "loads" up (on a grade). The 5th gear in your transmission is less than 1:1, smaller than the lower gears and very easy to overheat, under a load, and be destroyed. Most automatic transmissions vehicles recommend not using overdrive for towing anything, regardless of the vehicles towing capacity. The same thing will hold true for a manual transmission vehicle. Speaking from personal experience.
Re: Towing [Re: _flatlander_] #67061
02/18/06 12:16 PM
02/18/06 12:16 PM
PTP Offline OP
PTP  Offline OP
Thanks for everyone's input. As for the trailer- I just spent serious cash to replace the tongue, the tires/rims and springs so they had better be ok!
I sort of consider it this way- as Jake said.. the entire wieght of the trailer/boat probably doesn't exceed 1000lbs. Then I think of 3 "big" dudes in the back seat (not comfy, but car should handle it ok) and it is almost equivalent.
Re: Towing [Re: PTP] #67062
02/18/06 01:11 PM
02/18/06 01:11 PM
Replacing tires/rims and springs is great. But don't foreget to check bearings. Lockup would be a bitch on the road!!
Doug
Re: Towing [Re: ] #67063
02/18/06 03:12 PM
02/18/06 03:12 PM
PTP Offline OP
PTP  Offline OP
replaced the bearings also.. so all should be good.
Re: Towing [Re: scooby_simon] #67064
02/18/06 04:27 PM
02/18/06 04:27 PM
Dublin, Ireland
Dermot Offline
Dermot  Offline
Dublin, Ireland
I've just towed my new Spitfire 350 miles home with a 2.0 litre Legacy - no problem. I've also towed a Dart Hawk F18 on a heavy tilt trailer - also no problem.
Dermot
Catapult 265
Re: Towing [Re: PTP] #67065
02/18/06 04:28 PM
02/18/06 04:28 PM
Baton Rouge, LA
Dean Offline
Dean  Offline
Baton Rouge, LA
I have a 165hp six cylinder car that pulls 800lbs without a problem. There is not a lot of torque but it works well over a long haul. I think you will find 65mph to be the ideal speed for engine. 70 isn't a problem but the engine seems to work easier at only 5mph less.
Your biggest concern will be negotiating the kamikaze traffic on Hwy. 98 unless you head straight north to I-10 from Navarre.
Then, if you're coming south on I-75 you will have to check your rear view mirror for almost as much time as you spend looking out the windshield. Since the inside lane is going 80-85mph and the outside is bumper to bumper tractor/trailers you will have to use the middle lane which can be exciting because the middle will be populated by the frustrated tourists from the inside lane and frustrated truckers from the outside lane
Re: Towing [Re: Dean] #67066
02/18/06 04:30 PM
02/18/06 04:30 PM
PTP Offline OP
PTP  Offline OP
I drive 98 a lot so am familiar with it. I am not interested in driving my trailer at 80 mph!
What highway is the toll road everyone talks about as the best way to get down there?
Re: Towing [Re: PTP] #67067
02/19/06 09:41 AM
02/19/06 09:41 AM
if you want to save on gas, take the tramp off.
going down to tradewinds we had an F18 and an I20 double stacked and while the truck pulled them just fine, the wind resistance killed our gas milage.
Re: Towing [Re: PTP] #67068
02/19/06 11:07 AM
02/19/06 11:07 AM
Québec, Canada
CharlesLeblanc Offline
Québec, Canada
I own a 2000 Impreza wagon, 2.2L 5spd 142hp 149lb-ft
I have been towing my previous Nacra 5.7 on many long trips (300-500milles) without any problems.
The catamaran will induce a lot of drag so the car will not be fuel efficient. I was able to shift in 5th gear on the highway or on really good roads but as soon as it becomes hills I remained in 4th gear. I was doing 200-250 milles per tank
Things to look for:
Tongue weight: I found that a tongue weight of 10% is really more stable with my setup but I usually keep it to 5% to prevent to overload my rear suspension.
Trailer side:
Grease these wheels bearing, A visual inspection will tell you if the are in good shape.
Torque these wheel nuts
Put the recommended air pressure in the tires, under inflated tires will overheat
CARRY A SPARE
Inspect carefully the trailer electrical system.
Finally on long trips, binding straps will stretch and wear out. You have to stop on a regular basis to inspect and tighten everything
Charles Leblanc
Nacra 5.2
Charles Leblanc Nacra 5.2 #26
Re: Towing [Re: CharlesLeblanc] #67069
02/19/06 02:01 PM
02/19/06 02:01 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Charles Leblanc
No kidding!!!
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Towing [Re: CharlesLeblanc] #67070
02/19/06 07:12 PM
02/19/06 07:12 PM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
We used to call it the 1-10-100 mile rule. Check the trailer at 1 mile, 10 miles and every 100 miles. Check the temp of the bearings, too.
Re: Towing [Re: tshan] #67071
02/19/06 07:26 PM
02/19/06 07:26 PM
I use that too.
Usually works just fine (except I had a bearing seize this year Grr......).
Re: Towing [Re: scooby_simon] #67072
02/19/06 07:49 PM
02/19/06 07:49 PM
PTP Offline OP
PTP  Offline OP
How do you check the temp of the bearings? Just feel? (owww)
Re: Towing [Re: PTP] #67073
02/19/06 08:10 PM
02/19/06 08:10 PM
Has anyone mentioned lug nuts? Lost a few on the way back from the Keys last time.
Page 1 of 4 1 2 3 4
0 registered members (), 16,525 guests, and 861 spiders.
Most Online22,490
Yesterday at 08:14 AM
