How to remove vinyl hull ID numbers? #6706
05/02/02 09:57 PM
05/02/02 09:57 PM
DHO Offline OP
DHO  Offline OP
Howdy Catpeople,
I need to replace the 3 inch high vinyl hull ID numbers on my TheMightyHobie18. They are stuck on there pretty badly. I don't want to use a razor blade to scrape it because it would damage the gel coat. Is acetone safe to use?
Re: How to remove vinyl hull ID numbers? [Re: DHO] #6707
05/02/02 10:10 PM
05/02/02 10:10 PM
Newport, RI
wildtsail Offline
wildtsail  Offline
Newport, RI
Heat the letters up with a heat gun or hairdryer and peel them off. Don't heat it up too much or with the heat source too close or the gellcoat will be damaged. If there is still glue residue left after they come off, scrub it with something such as MEK, just be sure to wash it off.
-Todd
Re: How to remove vinyl hull ID numbers? [Re: DHO] #6708
05/03/02 09:28 AM
05/03/02 09:28 AM
Gulf Coast
tami Offline
tami  Offline
Gulf Coast
The guys in the vinyl grafix business use acetone.
Take a cloth, dampen it liberally with acetone, hold the cloth over the number. DON'T smear the cloth about, but if it does smear, that will wipe off with acetone also.
In any case, the vinyl will draw up and then it will peel easily. Wipe any remaining glue or smear residue with acetone.
sea ya!
0 registered members (), 506 guests, and 54 spiders.
