| Re: Towing
[Re: Mary]
#67115 02/23/06 05:58 PM 02/23/06 05:58 PM |
Posts: 3,348 | | | | Re: Towing
[Re: hobienick]
#67117 02/24/06 01:57 PM 02/24/06 01:57 PM |
Posts: 1,200 Vancouver, BC | The best part about these is there are no welds. the whole thing is bolted togeather. To alay any concerns about that, I use a heavier grade version of the extruded aluminum to build machine tools and customized automation equipment frames. As long as the bolts are the torqued correctly they are not coming loose. This bolted extrusion is what lends itself so well to attaching extra stuff the the traielr frame without having to drill holes in it. These are the primary reasons we chose to go with alloy for our Tilt trailer build. Welding alloy will ruin the tempering and create a lose of strength ~50% in the heated region. Welds typically fail before the section does, the opposite of a steel weld. We also went with a Torflex suspension axle...no springs to rust out! Been running it for 2 years now...done 2 trips to Houston & back (~3000 miles each trip). Here's a webpage with more details on the design: Tornado Tilt Trailer Build
| | | Re: Towing
[Re: Tornado]
#67118 02/24/06 04:28 PM 02/24/06 04:28 PM |
Posts: 805 Gainesville, FL 32607 USA | Trailex lifetime? My 1978 Trailex is under my new A cat. It has seen 28 years of regular racing (TheMightyHobie18 and H20) and STILL looks GOOOOD despite salty spray and beach-drift mist. Note- it was always washed on Sunday night after each of many ocean regattas. And my back says- thank you very much!  PS: I towed it with a Hobie 18 to the lake a couple of times with my 40 horse VW Karmann Ghia- 53 mph on the straight!
| | | Re: Towing
[Re: dacarls]
#67119 02/27/06 11:23 AM 02/27/06 11:23 AM |
Posts: 306 St. Louis, MO | I have seen Trailex trailers outlast the boats they tow. When I bought it I was told to expect at least 50 years out of it if I took care of it. I will have to replace the wheels, bearings, springs, and axel before I do anything to the frame.
Nick
Current Boat Looking for one
2,100
guests, and 208
