Page 4 of 4 1 2 3 4
Re: Towing [Re: Mary] #67114
02/23/06 05:57 PM
02/23/06 05:57 PM
Nice thing about it is that you can also carry furniture and mattresses and all sorts of other stuff on it.
Re: Towing [Re: Mary] #67115
02/23/06 05:58 PM
02/23/06 05:58 PM
Thanks Mary.
Re: Towing [Re: Mary] #67116
02/23/06 06:09 PM
02/23/06 06:09 PM
Another thing I like about the flatbed concept is that if you have cradles on there for your boat and you miss the cradles when you are putting the boat on the trailer, you don't have to worry about it being damaged by the metal superstructure of the trailer. If it misses the cradles, it just goes onto a nice soft carpeted flat surface. And there are no sharp metal things for it to get damaged by when you slide it on or off the trailer.
Re: Towing [Re: hobienick] #67117
02/24/06 01:57 PM
02/24/06 01:57 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
The best part about these is there are no welds. the whole thing is bolted togeather. To alay any concerns about that, I use a heavier grade version of the extruded aluminum to build machine tools and customized automation equipment frames. As long as the bolts are the torqued correctly they are not coming loose. This bolted extrusion is what lends itself so well to attaching extra stuff the the traielr frame without having to drill holes in it.
These are the primary reasons we chose to go with alloy for our Tilt trailer build. Welding alloy will ruin the tempering and create a lose of strength ~50% in the heated region. Welds typically fail before the section does, the opposite of a steel weld.
We also went with a Torflex suspension axle...no springs to rust out!
Been running it for 2 years now...done 2 trips to Houston & back (~3000 miles each trip).
Here's a webpage with more details on the design:
Tornado Tilt Trailer Build
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Towing [Re: Tornado] #67118
02/24/06 04:28 PM
02/24/06 04:28 PM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
Trailex lifetime? My 1978 Trailex is under my new A cat. It has seen 28 years of regular racing (TheMightyHobie18 and H20) and STILL looks GOOOOD despite salty spray and beach-drift mist. Note- it was always washed on Sunday night after each of many ocean regattas. And my back says- thank you very much!
PS: I towed it with a Hobie 18 to the lake a couple of times with my 40 horse VW Karmann Ghia- 53 mph on the straight!
Dacarls:
Re: Towing [Re: dacarls] #67119
02/27/06 11:23 AM
02/27/06 11:23 AM
St. Louis, MO
hobienick Offline
hobienick  Offline
St. Louis, MO
I have seen Trailex trailers outlast the boats they tow. When I bought it I was told to expect at least 50 years out of it if I took care of it. I will have to replace the wheels, bearings, springs, and axel before I do anything to the frame.
Nick
Current Boat
Looking for one
Previous Boats
'84 H16
'82 H18 Magnum
'74 Pearson 30
St. Louis, MO
Page 4 of 4 1 2 3 4
0 registered members (), 413 guests, and 1,287 spiders.
