Capricorn info #67548
02/21/06 11:29 PM
02/21/06 11:29 PM
F18OxJ Offline OP
F18OxJ  Offline OP
It looks like I might have an opportunity to purchase a Capricorn here in the US soon so I'm wondering if there are any current Capricorn owners out there who would be willing to share their experiences with the boat.
I currently sail a Tiger and I'm curious about some of the differences between the boats:
1) How does the rudder feel? Is it light and sensitive like the Tornado for example or is it 'heavier' feel like the Tiger?
2) Are the hulls more prone to pitchpoling downwind?
3) How is the tramp attached to the hulls? Is it an overlapping design like on the Tiger or is it more like the Nacra for example?
Any information, positive or negative about your experience with the boat would be greatly appreciated. If you don't want to post it here you are welcome to PM me and I'll send you my email address.
Cheers,
Olli
Re: Capricorn info [Re: F18OxJ] #67549
02/21/06 11:52 PM
02/21/06 11:52 PM
Tornado_ALIVE Offline
More like a Tigers, little bit lighter though...... Not even close to a good set T rudders but not hard to fit Marstrom rudders to it though.
The Capricorn will get up and semi plain down wind and gives you the false confidence that you can push it harder than you realy can. Push it to hard and you loose the nose up attitude of the boat..... It will crash down off the plain sort off like a foil moth crashing down off it's foils, and may lead to a nose dive. Once you learn this characteristic and learn the limits of it.... It is a sweet a$$ ride downwind.
Track at the front beam, rear beam it is lashed whilst the sides run through slots molded in the hulls..... Very stiff tramp. Not as stiff as a Marstrom tramp (but what other cat is) however makes the Hobie tramp look like a soggy hanky.
Final conclusion....... Not even close to a Marstrom T but as far as F-18s go, I rate it above the Tiger in both performance and quality of finish.
One negative I have though but this is also common with the NACRA and Tigers...... The boat is finished of with crap fittings and ropes. When you buy a Capricor, Tiger or Nacra...... Replace all fittings with Harken and replace all ropes with decent stuff.
Replace this stuff on a Capricorn and you will have a quality boat.
Re: Capricorn info [Re: Tornado_ALIVE] #67550
02/22/06 09:19 AM
02/22/06 09:19 AM
T - my Nacra F18 was completely fitted with Harken from the factory. Besides changing some rigging and replacing a couple of lines, the only hardware I replaced were the two idler spin sheet blocks at the shrouds with ratchematics to match the other two that were already supplied on the front beam.
Re: Capricorn info [Re: Jake] #67551
02/22/06 02:31 PM
02/22/06 02:31 PM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
Ollie:
Just get it and sail! The new Nacra Infusion is an answer to the Capricorn. You will not be able to get it in the US probably till about June though. That is if you did not deposit for an Alter Cup boat.
I think that the Infusion is fun to sail. A little weird to weather compared to the Tiger. The Tiger will track a bit better. Heavy rudders I had as well, until I did a lot of tweaking on the Tiger. The Infusion is a bit loosy goosy on the helm. This makes is so easy to turn that one may over steer it. Must keep your disipline.
Downwind it is really fun. The Tiger tracks a bit too much I think downwind making you really pay attention to keeping the boat going in the same direction and changing it very slowly. There is truely a planing feel to the Infusion downwind. It feels as though it is on a plane or wants to get there. It will also hold a lot more crew weight as the hulls are very bouyant.
I say go for the Capricorn and we will see how it works in Illinois.
Hope you sell your boat to someone really interested in performing in the Formula 18 Racing. Good Luck, and say hi to Kelly.
Later,
Dan
Re: Capricorn info [Re: Jake] #67552
02/22/06 03:05 PM
02/22/06 03:05 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
i agree jake, Performance don't use anything else but harken,I have never had to change any fitting.
The UK Nacra dealer used to count up the Harken fittings on the boat and add up their list price value and tell people at the boat shows how cheap the rest of the boat must be!
Re: Capricorn info [Re: TEAMVMG] #67553
02/22/06 03:22 PM
02/22/06 03:22 PM
TedZ Offline
TedZ  Offline
Dan
Did you sail the production version with the new mast & sails or the prototype Fusion using the old Nacra F18 mast?
My understanding is that the prototype was 25lbs heavy.
Ted
Re: Capricorn info [Re: TedZ] #67554
02/22/06 09:17 PM
02/22/06 09:17 PM
Dan_Delave Offline
Dan_Delave  Offline
Dan
Ted
Ted: That is exactly right. I sailed the 25 lbs over boat. The first production boat was only sailed one day when they called it a success. It sailed better than the prototype and they had all the pieces where they wanted them. I was at the Yacht Club when they sailed out of there for that occasion. The pictures that I posted in the Formula 18 forum where from that day.
Later,
Dan
Re: Capricorn info [Re: Dan_Delave] #67555
02/23/06 04:05 AM
02/23/06 04:05 AM
The fittings I had to change or plan to change on my boat are....
* Spinnaker halyard swivel cleat - cleat only from Ronstan to Harken.
* floating pully between spin halyard and tack line - currently Ronstan... Blew this pully up after modifing the system a bit. Fixed the problem and is now OK. We ran the same pully on the T for 4 years and had no trouble though.
* Spin sheet rachets from Holt which are crap..... both on the T and Capricorn we trie them and they blew up on the first outing each time. We now have Ronstan ones which did the job on the T and now the F-18. I believe Goodall supplies these now. Harken ones are better though.
* Spinnaker halyard and tack lines are absolute crap rope.... Replace these as soon as you get the new boat or ask Goodall to put some decent stuff on it. Likewise with the downhaul.
** All other ropes and fittings ar OK. Rudders are not too bad...... Just does not compare to a good Marstrom T. AHPC, I believe are using mostly Harken stuff on the boat now with some Ronstan here and there. Just let Goodall know you want your boat fitted out with Harken and you will have no problem.
Re: Capricorn info [Re: Tornado_ALIVE] #67556
02/23/06 08:46 AM
02/23/06 08:46 AM
F18OxJ Offline OP
F18OxJ  Offline OP
Thanks T. That's great info. I don't mind changing fittings and lines as I'm used to doing that on the Tiger. My Tiger is currently setup more like a Tornado anyway. I did hear that they made some block and cleat changes for the 2006 models. I'll have to make sure I get those and I'll ask about better lines as well.
I really like the way the Tornado steers and feels. You get so much more feedback from the boat. That is what got me thinking about a better F18.
Dan, Sounds like sailing it could be a blast. I'm very tempted about going for it. There is an opportunity to get a great deal and I could have the boat in March. My thinking on the Nacra is that it is going to take them a couple of iterations to work the kinks out anyway. Plus why not go for the 'real thing'.
Re: Capricorn info [Re: F18OxJ] #67557
02/23/06 09:10 AM
02/23/06 09:10 AM
You are obviously importing new...... Are you doing this privately or is somebody now importing them.
Also, AHPC has or soon will have a new rudder blade for the Capricorn to replace the old Taipan 5.7 blade that is currently used. I am not going to get them..... Looking at either a set of Marstrom T rudders or look into making some stocks up for a set of Marstrom 20 rudders.
Re: Capricorn info [Re: Tornado_ALIVE] #67558
02/23/06 09:47 AM
02/23/06 09:47 AM
F18OxJ Offline OP
F18OxJ  Offline OP
I'm not importing them, but looks like there is going to be an importer/dealer bringing a few here to the US and they offered a great deal if I prebuy one to help them fill a container.
Yeah, I heard that about the rudders. I've been waiting to hear when the new ones will be available. Switching to Marstrom rudders sounds like a great idea. Let me know how that works for you.
Re: Capricorn info [Re: Tornado_ALIVE] #67559
02/23/06 10:30 AM
02/23/06 10:30 AM
Houston
carlbohannon Offline
Houston
A big portion of the Marstom Tornados steering feel is the STIFF Carbon tiller cross bar. On my boat:
The carbon tiller crossbar is steering with 2 fingers.
The Aluminum/Carbon tiller crossbar is steering with 3 fingers
The old Aluminum tiller crossbar is steering with 1 hand.
(I have all 3 and tried them).
Is the F18 restricted to aluminum for the tiller cross bar?
Re: Capricorn info [Re: F18OxJ] #67560
02/23/06 10:55 AM
02/23/06 10:55 AM
Tornado699 Offline
Tornado699  Offline
Why don't you just keep sailing a boat that steers nice
and goes very fast.
Matt
P.S.
Have a nice day sanding!
Re: Capricorn info [Re: F18OxJ] #67561
02/23/06 11:24 AM
02/23/06 11:24 AM
Tornado699 Offline
Tornado699  Offline
Hi,
New to this web forum would love some info about the Capricorn, sounds really kool.
Is there a dealer in the US yet?
What is the Capricorn Web page?
Thanks Matt
Re: Capricorn info [Re: Tornado699] #67562
02/23/06 11:32 AM
02/23/06 11:32 AM
Dan_Delave Offline
Dan_Delave  Offline
and goes very fast.
Probably because it is hard to find a big fleet to sail against and Ollie is really good in big fleet sailing. I know that he was able to sail the T in Florida recently with a lot of boats, but how often does that happen? Another concern is set up time (a couple of hours) and travelling (with the boat sideways).
Ollie, we are all interested in the "great deal" you got. If you do not want to mention the exact amount can you hint about the percent discount from say a $15,000 boat? Sly huh?
You may know by now that there are some manufacturing delays for the Infusion. The June time frame for the U.S. to finally get boats is kind of up in the air now, with that. Certainly the Capricorn is an interesting boat and has created a stir with its performance. I cannot imagine that it would lose any more value than any other Formula 18 in the States if you decided to sell it. Maybe with the scarcity it would be quicker to sell. In the end it is just the hulls you are buying because everything else can be replaced with equipment we already have available. What I mean to say is you will not be left in the learch because the manufacturer cannot get you parts quickly, just use whatever we use on the Hobies or Nacras for replacements.
Later,
Dan
Re: Capricorn info [Re: Dan_Delave] #67563
02/23/06 11:51 AM
02/23/06 11:51 AM
Wilmington,NC
Dlennard Offline
Dlennard  Offline
Wilmington,NC
The prices I heard were around 18,000 US dollars and I thought that there would not be too many sailors wanting to spend that much money. Maybe they are going to drop the price to get some Capricorns in the US.
Re: Capricorn info [Re: Dan_Delave] #67564
02/23/06 11:51 AM
02/23/06 11:51 AM
Dan_Delave Offline
Dan_Delave  Offline
Tornado669:
Try here: Capricorn Information
Re: Capricorn info [Re: Dan_Delave] #67565
02/23/06 12:04 PM
02/23/06 12:04 PM
Tornado699 Offline
Tornado699  Offline
Thanks Dan I will take a look.
Matt
Re: Capricorn info [Re: Tornado699] #67566
02/23/06 09:50 PM
02/23/06 09:50 PM
F18OxJ Offline OP
F18OxJ  Offline OP
Hi Dan. I'm not supposed to give out specifics yet because I don't thing the deal has been completely finalized, but let's just say that the price is well in the ballpark of a new Tiger.
Also, this is not some special deal just for me - I think it would be available to anyone interested in a Capricorn or the A-cat if they are willing to prebuy the boat (as long as there is room in the container).
Email me if you want more details about the deal.
Re: Capricorn info [Re: Tornado699] #67567
02/23/06 10:04 PM
02/23/06 10:04 PM
F18OxJ Offline OP
F18OxJ  Offline OP
and goes very fast.
Tornado699, I would love to keep sailing it, but I think the owner is getting anxious to get it back. Could you talk to him about letting me keep it for good?
