| Re: Capricorn info
[Re: F18OxJ]
#67549 02/21/06 11:52 PM 02/21/06 11:52 PM |
Posts: 1,669 Melbourne, Australia | It looks like I might have an opportunity to purchase a Capricorn here in the US soon so I'm wondering if there are any current Capricorn owners out there who would be willing to share their experiences with the boat.
I currently sail a Tiger and I'm curious about some of the differences between the boats: 1) How does the rudder feel? Is it light and sensitive like the Tornado for example or is it 'heavier' feel like the Tiger? More like a Tigers, little bit lighter though...... Not even close to a good set T rudders but not hard to fit Marstrom rudders to it though. 2) Are the hulls more prone to pitchpoling downwind? The Capricorn will get up and semi plain down wind and gives you the false confidence that you can push it harder than you realy can. Push it to hard and you loose the nose up attitude of the boat..... It will crash down off the plain sort off like a foil moth crashing down off it's foils, and may lead to a nose dive. Once you learn this characteristic and learn the limits of it.... It is a sweet a$$ ride downwind. 3) How is the tramp attached to the hulls? Is it an overlapping design like on the Tiger or is it more like the Nacra for example?
Track at the front beam, rear beam it is lashed whilst the sides run through slots molded in the hulls..... Very stiff tramp. Not as stiff as a Marstrom tramp (but what other cat is) however makes the Hobie tramp look like a soggy hanky. Final conclusion....... Not even close to a Marstrom T but as far as F-18s go, I rate it above the Tiger in both performance and quality of finish. One negative I have though but this is also common with the NACRA and Tigers...... The boat is finished of with crap fittings and ropes. When you buy a Capricor, Tiger or Nacra...... Replace all fittings with Harken and replace all ropes with decent stuff. Replace this stuff on a Capricorn and you will have a quality boat. | | | Re: Capricorn info
[Re: Tornado_ALIVE]
#67550 02/22/06 09:19 AM 02/22/06 09:19 AM |
Posts: 12,310 South Carolina | T - my Nacra F18 was completely fitted with Harken from the factory. Besides changing some rigging and replacing a couple of lines, the only hardware I replaced were the two idler spin sheet blocks at the shrouds with ratchematics to match the other two that were already supplied on the front beam.
Jake Kohl | | | Re: Capricorn info
#67552 02/22/06 03:05 PM 02/22/06 03:05 PM |
Posts: 1,203 uk | i agree jake, Performance don't use anything else but harken,I have never had to change any fitting. The UK Nacra dealer used to count up the Harken fittings on the boat and add up their list price value and tell people at the boat shows how cheap the rest of the boat must be!
| | | Re: Capricorn info
[Re: TedZ]
#67554 02/22/06 09:17 PM 02/22/06 09:17 PM |
Joined: Mar 2002 Posts: 984 2017 F18 Americas Site Dan_Delave
Posts: 984 2017 F18 Americas Site | Dan Did you sail the production version with the new mast & sails or the prototype Fusion using the old Nacra F18 mast? My understanding is that the prototype was 25lbs heavy. Ted  Ted: That is exactly right. I sailed the 25 lbs over boat. The first production boat was only sailed one day when they called it a success. It sailed better than the prototype and they had all the pieces where they wanted them. I was at the Yacht Club when they sailed out of there for that occasion. The pictures that I posted in the Formula 18 forum where from that day. Later, Dan | | | Re: Capricorn info
[Re: Tornado_ALIVE]
#67556 02/23/06 08:46 AM 02/23/06 08:46 AM |
Posts: 81 | Thanks T. That's great info. I don't mind changing fittings and lines as I'm used to doing that on the Tiger. My Tiger is currently setup more like a Tornado anyway. I did hear that they made some block and cleat changes for the 2006 models. I'll have to make sure I get those and I'll ask about better lines as well. I really like the way the Tornado steers and feels. You get so much more feedback from the boat. That is what got me thinking about a better F18. Dan, Sounds like sailing it could be a blast. I'm very tempted about going for it. There is an opportunity to get a great deal and I could have the boat in March. My thinking on the Nacra is that it is going to take them a couple of iterations to work the kinks out anyway. Plus why not go for the 'real thing'. | | | Re: Capricorn info
[Re: Tornado699]
#67562 02/23/06 11:32 AM 02/23/06 11:32 AM |
Posts: 984 2017 F18 Americas Site | Why don't you just keep sailing a boat that steers nice and goes very fast. Probably because it is hard to find a big fleet to sail against and Ollie is really good in big fleet sailing. I know that he was able to sail the T in Florida recently with a lot of boats, but how often does that happen? Another concern is set up time (a couple of hours) and travelling (with the boat sideways). Ollie, we are all interested in the "great deal" you got. If you do not want to mention the exact amount can you hint about the percent discount from say a $15,000 boat? Sly huh? You may know by now that there are some manufacturing delays for the Infusion. The June time frame for the U.S. to finally get boats is kind of up in the air now, with that. Certainly the Capricorn is an interesting boat and has created a stir with its performance. I cannot imagine that it would lose any more value than any other Formula 18 in the States if you decided to sell it. Maybe with the scarcity it would be quicker to sell. In the end it is just the hulls you are buying because everything else can be replaced with equipment we already have available. What I mean to say is you will not be left in the learch because the manufacturer cannot get you parts quickly, just use whatever we use on the Hobies or Nacras for replacements. Later, Dan | | | Re: Capricorn info
[Re: Tornado699]
#67567 02/23/06 10:04 PM 02/23/06 10:04 PM |
Posts: 81 | Why don't you just keep sailing a boat that steers nice and goes very fast. Tornado699, I would love to keep sailing it, but I think the owner is getting anxious to get it back. Could you talk to him about letting me keep it for good? | | |
11,633
guests, and 380
