| Re: Blade
[Re: Mirjam]
#67659 12/04/06 11:38 AM 12/04/06 11:38 AM |
Posts: 9,582 North-West Europe | Mirjam,
Welcome to the class and forum, indeed.
And let me extent this welcome by inviting you to the Zandvoort F16 event, Global Challenge, 12-19 aug 2007.
They are expecting a few boats from all over the worlds and it will be a bonanza for sailors new to the F16 class and boats. You'll learn heaps in those days, more then you can discover yourself in 1 to 2 seasons of sailing. There will be several other newbie crews/sailors at the event, so you certainly won't be alone.
| | | Re: Blade
[Re: VIRUSCAT]
#67661 12/05/06 04:46 AM 12/05/06 04:46 AM |
I'm very aware of aluminium daggerboards and rudderboards. Indeed I've seen them on Mattia catamarans and even Topcat catamarans.
For the F16's these were indeed never seriously considered. It was easy enough to get foam/fibre boards.
| | | Re: Blade
[Re: VIRUSCAT]
#67663 12/12/06 06:46 AM 12/12/06 06:46 AM |
Posts: 9,582 North-West Europe | Emanuele, another question, can you give me some info about the mast profile (alu) used in F16 (Taipan and Blade)e.g. dimensions and weight? Is it the same of the Capricon F18?
Not the same as the capricorn mast. 150mm x 63mm and, about 1.65 kg per meter. It is however a true wingmast, in fact that exteriour profile is as good as the same the carbon A-cat masts. Wouter
| | | Re: Blade
[Re: Wouter]
#67664 12/12/06 12:53 PM 12/12/06 12:53 PM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | Emanuele; If you are going to sail solo I would definately consider a Carbon Mast. They are alot easier to right after a capsize. (See the numerous posts regarding righting a Blade single handed) You shouldn't need pillow cases, trash bags etc. MP*MULTIHULLS | | | Re: Blade
[Re: VIRUSCAT]
#67667 12/13/06 05:57 AM 12/13/06 05:57 AM |
Posts: 9,582 North-West Europe | Viruscat, I'm looking for the Blade plans but the real problem is the time to build it.
A good alternative is to buy the hulls and finish the cat up yourself from there. That is a considerable savings in time and also still allows you to fune-tune all the important things to personal preference. Wouter
399
guests, and 47
