looking for a little help... #68316
03/01/06 09:25 PM
03/01/06 09:25 PM
shaggy_g Offline OP
shaggy_g  Offline OP
Hi, I'm looking to purchase my first cat. The boat I'm most interested in is a lightly used (fresh water only) 1998 Hobie 16. I received the attached pic from the seller and I'm wondering if you think I should be concerned about how low the boat is sitting in the water. Obviously, there are 4 people on board but two appear to be kids. Thanks in advance for your help.
Re: looking for a little help... [Re: shaggy_g] #68317
03/01/06 10:12 PM
03/01/06 10:12 PM
North Carolina
hrtsailor Offline
hrtsailor  Offline
North Carolina
You might want to ask him for another picture but it seems to me there are 3 people near the rear rail and there is obviously no wind. At least two are adults and the third is big for a child. I don't think it is too low for that weight. I can almost sink the stern of one hull when I go back to latch the rudder by myself.
Howard
Re: looking for a little help... [Re: shaggy_g] #68318
03/01/06 10:46 PM
03/01/06 10:46 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
I'd go with Howard's response but you should give the entire boat a good look over. Pull the drain plugs and tip the boat up to see if any water comes out. Examine the keels for excessive wear. Look for fiberglass showing through.
Check the decks for soft spots especially just in front of the crossbar.
After that check for general wear and tear on rigging and the sails.
What's the asking price?
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: looking for a little help... [Re: hobie1616] #68319
03/02/06 01:08 AM
03/02/06 01:08 AM
N
newbiesailor Offline
N
i think the boat looks ok, i reccomend taking a peak at this here http://www.cs.rochester.edu/u/jag/adventures/hobie16check.html
things to look for... one other things to check is when you push down on the bow of one hull, it should remain very rigid and not twist or flex, another thing i found helpful was checking the boat value on nada.com
if possible, try and get him to take you out, rig it, and sail with him, it can tell a ton about the owner and boat
hobies are great boats, i bought mine just last summer
Re: looking for a little help... [Re: shaggy_g] #68320
03/02/06 08:53 AM
03/02/06 08:53 AM
Virginia USA
CMerrell Offline
CMerrell  Offline
Virginia USA
The boat is okay. There is 350-400 lbs. of crew weight from the shrouds aft.
Looks like they are trying to sail backwards or, possibly, tack. Main traveller is to windward with the sheet slack, jib traveller is outboard, rudders are centered.
If you are new to cat sailing, recommend you invest in Rick White's book or videos.
Re: looking for a little help... [Re: hobie1616] #68321
03/02/06 10:44 AM
03/02/06 10:44 AM
shaggy_g Offline OP
shaggy_g  Offline OP
Hello and thank you all for your valuable feedback... you've been very helpful. I intent to perform a thorough review of the entire boat, rigging and trailer. I've already ordered the assembly manual from Hobie and I will look into Rick White's publications. The current owner is asking $4600 for the boat and trailer. Any thoughts on the price?
Re: looking for a little help... [Re: shaggy_g] #68322
03/02/06 02:24 PM
03/02/06 02:24 PM
St. Louis, MO
hobienick Offline
hobienick  Offline
St. Louis, MO
If everything is in good shape (including the trailer) the asking price is probably reasonable. For a comparison I sold my '86 H16 on a junky trailer with new sails, new standing and running rigging, new platic rudders, a few nice upgrades, etc. for $2300. That was three years ago in Massachusettes.
Nick
Current Boat
Looking for one
Previous Boats
'84 H16
'82 H18 Magnum
'74 Pearson 30
St. Louis, MO
Re: looking for a little help... [Re: hobienick] #68323
03/02/06 03:13 PM
03/02/06 03:13 PM
Syracuse,N.Y
pbisesi Offline
pbisesi  Offline
Syracuse,N.Y
What type of trailer? What type of rudders? Does it have the double trapeze setup(can't tell in the picture). What type of tiller? (Hotstick?).
With race rudders, double trapeze, hot stick, decent sails and steel trailer it is good price. Trailex then very good price. Without the above I would offer less.
Pat Bisesi Fleet 204
Re: looking for a little help... [Re: pbisesi] #68324
03/02/06 04:47 PM
03/02/06 04:47 PM
shaggy_g Offline OP
shaggy_g  Offline OP
Owner has trapeze wires (never been used). No hotstick tiller and has standard rudders. Aluminum trailer appears to be in great shape (see attached pic). Thanks.
Re: looking for a little help... [Re: shaggy_g] #68325
03/02/06 05:27 PM
03/02/06 05:27 PM
St. Louis, MO
hobienick Offline
hobienick  Offline
St. Louis, MO
The trailex trailer and boat box alone are worth about $1300. If the extras are nice and (as before) everything is in good shape, the price seems good. You should try to knock off a few hundred if you can. The worst that can happen is you pay asking price. Good luck to you.
Nick
Current Boat
Looking for one
Previous Boats
'84 H16
'82 H18 Magnum
'74 Pearson 30
St. Louis, MO
Re: looking for a little help... [Re: hobienick] #68326
03/02/06 10:54 PM
03/02/06 10:54 PM
Syracuse,N.Y
pbisesi Offline
pbisesi  Offline
Syracuse,N.Y
Looks like a good deal. Trailex new is around $1600. The box new is like $400. Get a good set of rudders and your set.
The race rudders make a huge differance.
0 registered members (), 264 guests, and 34 spiders.
Yesterday at 09:43 PM
