| Re: looking for a little help...
[Re: shaggy_g]
#68318 03/01/06 10:46 PM 03/01/06 10:46 PM |
Posts: 5,582 “an island in the Pacifi... | I'd go with Howard's response but you should give the entire boat a good look over. Pull the drain plugs and tip the boat up to see if any water comes out. Examine the keels for excessive wear. Look for fiberglass showing through.
Check the decks for soft spots especially just in front of the crossbar.
After that check for general wear and tear on rigging and the sails.
What's the asking price? US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: looking for a little help...
[Re: hobie1616]
#68319 03/02/06 01:08 AM 03/02/06 01:08 AM |
Posts: 110 | i think the boat looks ok, i reccomend taking a peak at this here http://www.cs.rochester.edu/u/jag/adventures/hobie16check.htmlthings to look for... one other things to check is when you push down on the bow of one hull, it should remain very rigid and not twist or flex, another thing i found helpful was checking the boat value on nada.com if possible, try and get him to take you out, rig it, and sail with him, it can tell a ton about the owner and boat hobies are great boats, i bought mine just last summer | | | Re: looking for a little help...
[Re: shaggy_g]
#68320 03/02/06 08:53 AM 03/02/06 08:53 AM |
Posts: 206 Virginia USA | The boat is okay. There is 350-400 lbs. of crew weight from the shrouds aft. Looks like they are trying to sail backwards or, possibly, tack.  Main traveller is to windward with the sheet slack, jib traveller is outboard, rudders are centered. If you are new to cat sailing, recommend you invest in Rick White's book or videos. | | | Re: looking for a little help...
[Re: shaggy_g]
#68322 03/02/06 02:24 PM 03/02/06 02:24 PM |
Posts: 306 St. Louis, MO | If everything is in good shape (including the trailer) the asking price is probably reasonable. For a comparison I sold my '86 H16 on a junky trailer with new sails, new standing and running rigging, new platic rudders, a few nice upgrades, etc. for $2300. That was three years ago in Massachusettes.
Nick
Current Boat Looking for one
[Re: hobienick]
#68323 03/02/06 03:13 PM 03/02/06 03:13 PM |
Posts: 393 Syracuse,N.Y | What type of trailer? What type of rudders? Does it have the double trapeze setup(can't tell in the picture). What type of tiller? (Hotstick?). With race rudders, double trapeze, hot stick, decent sails and steel trailer it is good price. Trailex then very good price. Without the above I would offer less.
Pat Bisesi
Fleet 204
[Re: shaggy_g]
#68325 03/02/06 05:27 PM 03/02/06 05:27 PM |
Posts: 306 St. Louis, MO | The trailex trailer and boat box alone are worth about $1300. If the extras are nice and (as before) everything is in good shape, the price seems good. You should try to knock off a few hundred if you can. The worst that can happen is you pay asking price. Good luck to you.
Nick
[Re: hobienick]
#68326 03/02/06 10:54 PM 03/02/06 10:54 PM |
Posts: 393 Syracuse,N.Y | Looks like a good deal. Trailex new is around $1600. The box new is like $400. Get a good set of rudders and your set. The race rudders make a huge differance.
Pat Bisesi
Fleet 204
3,695
guests, and 114
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online4,027 1 hour ago | | |
