| Hobie 20 Jib System #6842 05/06/02 09:59 PM 05/06/02 09:59 PM |
Posts: 283 | I'm finally putting my boat together for the upcoming summer, and thought I'd revisit the jib system I'm using.
Last year, I replaced that annoying, crew knee eating wire that the jibsheet blocks ride along with spectra line. It works OK, but I'm still not sure I really like it, as it is hard to get it nice and tight, and it tends to get chafed up pretty bad.
Anyone have any thoughts on what a good plan B might be?
Thanks,
Tim J.
Tim D. Johnson
Hobie 20 #690
Bald Eagle Yacht Club, Fleet 52
www.beyc.org | | | Re: Hobie 20 Jib System
[Re: Matt M]
#6844 05/07/02 08:30 PM 05/07/02 08:30 PM | Anonymous
| Anonymous
Unregistered | Matt,
Your recommendation sounds great. What city & state is Select Sail and Sport located in? Do they have a web site?
Thanks
Jon
H20, TheMightyHobie18
SHBCC
[Re: hobie541]
#6845 05/07/02 10:28 PM 05/07/02 10:28 PM |
Posts: 1,911 South Florida & the Keys | Hey Tim,
I understand about the webbing and stainless rings mentioned in a previous post, very similar to the Tornado System....Only issue is,,,Can you adjust on any point of sail with out loding sail shape or jib?....
Stick with the spectra. I have another idea to put tension on the line although I dont think it has to be "real tight" you can slide the cars forward an inch or so to make up for the slack
capiche?
Eric
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: Hobie 20 Jib System
[Re: arbo06]
#6846 05/07/02 11:00 PM 05/07/02 11:00 PM |
Posts: 283 | Yeah, I don't know Eric, I'm just a little disinchanted with the whole thing.
Seems like a lot of screwing around either way. You're either fighting the spectra system, or your having to figure out before you're on the water what to do about which ring to put it on, or whatever.
Not sure what I'll end up deciding on this one.
Sea ya,
Tim
Tim D. Johnson
Hobie 20 #690
[Re: hobie541]
#6847 05/09/02 07:15 AM 05/09/02 07:15 AM |
Posts: 1,911 South Florida & the Keys | The wire works the way it is supposed to, I put a peice of rubber tubing over the center section of the cable that doesn't get used and that keeps the crew "somewhat" happy.
I am de-rigging my 20 now to get ready for paint. I can't wait, its gonna be "teal" with a teal tramp.
Eric
[Re: arbo06]
#6848 05/09/02 07:58 PM 05/09/02 07:58 PM |
Posts: 96 Racine, Wisconsin | Out of curiosity.... how much is the paint job costing you?
Paul Scott Bartelt
2001 NACRA 6.0 NA #546
| | | Re: Hobie 20 Jib System #6849 05/10/02 09:25 AM 05/10/02 09:25 AM |
Posts: 548 MERRITTISLAND, FL | Jon, The web site is www.selectsail.com They have a kit made ready to go. You do have to make a decision on which ring to use but it is easy to change even on the water, and you still have the same fore and aft adjustment that you always had. I find that I end up setting the fore and aft position per the mast rake before we leave the beach, and the inbord adjustment is set also and only changed to depower when the wind is really honking, so the clips work great. Matt | | | Re: Hobie 20 Jib System
[Re: Matt M]
#6850 05/10/02 10:59 AM 05/10/02 10:59 AM |
Posts: 1,911 South Florida & the Keys | hi Jon, I'm doing it myself, materials are $178.00.
2 quarts Awlgrip, 2 quarts catalyst, and a quart of thinner.
A couple rolls of #220 for the palm sander and a tube of dupont 5200 for reassmbly.
My neighbor is a marine mechanic and got the mateials through his acount. If you don't have a connection you will pay 30-35% more
[Re: hobie541]
#6851 05/11/02 09:21 PM 05/11/02 09:21 PM |
Posts: 1,449 | Tim,
The Taipan had a similar system.
Now all Taipan jibs sheet from eyelets in the tramp.
Some people have two or 3 eylets each side for adjustment but rarely if ever use the adjustments.
Find the right place for mast rake and jib shape and one eylet will do.
Simple , easy, clean and it works.
[Re: phill]
#6852 05/12/02 11:39 AM 05/12/02 11:39 AM | Anonymous
| Anonymous
Unregistered | Hi Matt,
Thanks for the web site info.
Jon
H20, TheMightyHobie18 | | |
450
guests, and 35
