Jib flutter #6863
05/07/02 10:26 AM
05/07/02 10:26 AM
Fort Loramie, Ohio
jmhoying Offline OP
jmhoying  Offline OP
Fort Loramie, Ohio
I rigged my Prindle 18 for a roller furling jib. The stock jib has two 10" batten in it which had to be removed to make it furl properly. I now have some slight flutter at certain speeds. I did expect this somewhat. I checked the cut of the leech and it is straight. Do I need to have this recut or is there another method to change the shape of the sail? If I have it recut, how much curve should there be in the leech?
Thanks,
Jack Hoying
Fort Loramie, Ohio
Prindle 18 #1645
jmhoying at bright.net
http://www.bright.net/~jmhoying
Re: Jib flutter [Re: jmhoying] #6864
05/07/02 11:01 AM
05/07/02 11:01 AM
Sorry, can't help you with your question, but I was interested in your roller furling jib. I have a Prindle 18 with no jib battens. I've been considering a roller furling jib. What did you use? Was price reasonable? Are you happy with your system other than flutter problem?
Re: Jib flutter [Re: jmhoying] #6865
05/07/02 11:11 AM
05/07/02 11:11 AM
beaufort, sc
dannyb9 Offline
dannyb9  Offline
beaufort, sc
i had this problem when i converted my h16. i was able to correct it by hoisting the jib higher. this changes the angle of the jib sheet and increases tension on the leech.
marsh hawk
Re: Jib flutter #6866
05/07/02 11:11 AM
05/07/02 11:11 AM
Fort Loramie, Ohio
jmhoying Offline OP
jmhoying  Offline OP
Fort Loramie, Ohio
Danno,
I used a used Hobie 18 furler and had a new shroud and pigtail made. You'll also need an upper swivel. The jib is tied permanetely to the forestay. If you are a recreational sailor, like me, once you have a boat with a furling jib, you will hate to sail a boat without one. It's great to launch, take a break, depower, etc.
Check some photos that I have on my webpage:
Jack Hoying
Fort Loramie, Ohio
Prindle 18 #1645
Re: Jib flutter [Re: jmhoying] #6867
05/07/02 11:47 AM
05/07/02 11:47 AM
I have a rolling furly thing on my Supercat 17's jib - sometimes it flutters under a decent wind, but if I TIGHTEN the jib line it tends to make it stop.
SId sends
Re: Jib flutter [Re: jmhoying] #6868
05/07/02 11:51 AM
05/07/02 11:51 AM
Jim,
A lot of the roller furling boats place their jib battons at an angle and nearly vertical so that they are parallel with the forstay and will roll with the jib when furling. It is likely that you will be able to place them at about a 15 to 30 degree angle and still be able to furl the jib. I would use sail repair tape to test the placements of the battens for furler compatability and anti flutter.
Re: Jib flutter [Re: jmhoying] #6869
05/07/02 06:08 PM
05/07/02 06:08 PM
Mike Fahle Offline
Mike Fahle  Offline
Hi Jim, You have two choices. You can have a small amount of leech from head to clew cut out of the sail in a crescent shape so that the unsupported material that is fluttering is removed (this is called leech hollow by sailmakers) or you can use battens to support the leech that are oriented parallel to the luff so that they line up when the sail is furled. They must be parallel, though so that the battens due not twist and deform when they are furled. They also need to be longer than the previous battens to get into the body of the sail that provides the support they need for the leech. Any sailmaker should be able to do either of these jobs for you for a reasonable cost. FWIW, for the small amount of extra sail area you keep with the battens, I would recommend going the simpler route and just use the leech hollow method. This is what the Hobie 18 jib looks like, for example. Hope this helps!
Mike Fahle
Re: Jib flutter [Re: Mike Fahle] #6870
05/07/02 06:20 PM
05/07/02 06:20 PM
San Diego, CA
whitecaps Offline
whitecaps  Offline
San Diego, CA
Hi Jim - I started on a P16, very similar to your P18. I now have an I20, which comes stock with the jib battens parallel to the forestay (about a 45 deg. angle to the leech). They roll up into a very small cylinder, which is how we store the boat (with a protective jib snorkel-cover). This way works well for us, and I suggest you try it. The leech hollow method also sounds interesting.
Sail fast and have fun,
Alan Thompson
I20 - San Diego
Re: Jib flutter - Randy sez... [Re: whitecaps] #6871
05/09/02 10:56 AM
05/09/02 10:56 AM
Long Island, NY
Ed Norris Offline
Ed Norris  Offline
Long Island, NY
I just discussed this question while ordering my new set of sails from Randy Smyth. Randy sez...
1. Harken's "rolling Battens" are okay for a fully battened jib, but with those short 10 inch battens, the roll-able ones don't smoothely roll up, stick out and generally act uncivilized when you furl.
2. He recommended the parallel-to-the-luff aproach, not mentioning a hollow leach. This was for a new sail, perhaps his advice would have been different for an existing sail. I'm going that route.
I can't wait for my new sails.
Sail Fast, Ed Norris
jib snorkel-cover [Re: whitecaps] #6872
05/09/02 11:37 AM
05/09/02 11:37 AM
Maryland, USA
PRagen Offline
PRagen  Offline
Maryland, USA
Slightly Off topic
Alan mentioned a protective jib snorkel-cover. I store my Nacra, with roller furling, mast up and would like to keep the jib on and rolled. (I love the roller furling, but at least on my boat with the furling, getting the jib on is the hardest part of the rigging)
Can anyone comment on the snorkel covers from Murrays (p65 of 2001 catalog). Good/Bad?
Does anyone have another source for snorkel covers?
Has anyone made their own?
Thanks in advance.
Patrick Ragen
Taipan 4.9 USA 274
Re: jib snorkel-cover [Re: PRagen] #6873
05/09/02 11:54 AM
05/09/02 11:54 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
I have one I got through the Hobie catalog for my 18. I can't imagine much variation in design - it's just a long piece of Sunbrella with a long zipper, and grommets at either end to secure it. I thought about making my own, but I figured once I bought the cloth, zipper, and did the sewing, it was more cost-effective to just buy one.
I used it for awhile, it's pretty nice and easy to use. Once I got a new jib, however, I've been removing the sail each time instead of leaving it furled on the boat.
Re: jib snorkel-cover [Re: PRagen] #6874
05/09/02 02:01 PM
05/09/02 02:01 PM
San Diego, CA
whitecaps Offline
whitecaps  Offline
San Diego, CA
I got mine with the boat from Ron Lane at http://www.fastlanesailing.com in San Diego. He has them made locally out of high-quality Sunbrella fabric. All of the I20's here have these covers for the jib, with almost all having similar ones for the tramp. They are very nice and I wouldn't get a cheaper one.
I don't know anything about the Murray's ones.
Alan Thompson
I20 - San Diego
0 registered members (), 264 guests, and 34 spiders.
Yesterday at 09:43 PM
