Home building a small cat #69226
03/14/06 10:14 PM
03/14/06 10:14 PM
Alain Offline OP
Alain  Offline OP
Hi,
I'm planning to build a small cat, aroud 16'. The goal is to get experience with boat building using wood and maybe later to build a large cat for cruising. This first one is to be use by family and to have fun sailing with correct performances.
Anyone have suggestions on a design or personnal experience with wooden boat home building. I already find the Quattro 16 by Woods Design and the Fast Twin by Hartley Boats.
All information on thoses design performances or on other design will be welcome.
Thanks in advance.
Alain
Montreal, Canada
Re: Home building a small cat [Re: Alain] #69227
03/14/06 10:26 PM
03/14/06 10:26 PM
Alain:
There are usually some boat plan books on EBay. May want to look there.
Doug Snell
Hobie 71
www.tcdyc.com
Re: Home building a small cat [Re: Alain] #69228
03/14/06 10:45 PM
03/14/06 10:45 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Although it's quite a bit bigger you might gain some valuable info at http://www.rotkat.com/ .
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Home building a small cat [Re: Alain] #69229
03/14/06 11:00 PM
03/14/06 11:00 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
Contact Phill Brander about plans for his new F-16 Blade design. I have had a chance to check them out and he offers an excellent plan package, very complete and detailed. If you are going to go to all the trouble of building your own boat, why not go for the latest and greatest? No sense building an older design that is already obsolete when a cutting edge design is available.
Bob
Re: Home building a small cat [Re: Seeker] #69230
03/14/06 11:25 PM
03/14/06 11:25 PM
Bob:
Want to see a kick butt new boat, I have some photos of the new MCM Formula 28 from the Britain Boat Show they sent to me. Send me a email link. dsnell4 at houston dot rr dot com.
Doug Snell
Hobie 17
www.tcdyc.com
Re: Home building a small cat [Re: ] #69231
03/15/06 02:01 AM
03/15/06 02:01 AM
I would forget about the Quattro, it's outdated and the plan set is not really great. There are some things in there you will be scratching your head about (at least I did) if you are on your first boat. Resale vale will be low compared to a Blade.
If I was to build today, even for family use, I would have done a Blade. Cost might be a little bit higher, but so will resale value. Have a look at http://www.bladecatamarans.com, and then get in touch with Phill Brander.
I dont know how good practice building a small plywood cat will be for a larger project. Unless you intend to do a plywood or strip planked project of course. If the design you think about is a composite project, you would be better off building some test panels to get used to the various building techniques and then following a well documented set of building instructions like Farriers.
Re: Home building a small cat [Re: Alain] #69232
03/15/06 03:19 AM
03/15/06 03:19 AM
Israel
Erez Offline
Erez  Offline
Israel
Erez Ben Shoham http://www.cat-sail.co.il
Re: Home building a small cat [Re: Rolf_Nilsen] #69233
03/15/06 05:29 AM
03/15/06 05:29 AM
Alain,
I think Rolf gives best advice.
I understand that Phill Brander is also working on a 28 foot cruiser/racer design based on his early Blade catamaran designs. I personally expect this to be a tortured ply design as well (maybe with an external layer of glass). This might of be of interest to you later.
In this line of thinking building the smaller timber-epoxy Blade F16 may well be a good test case before starting on the timber epoxy 28 footer.
Otherwise, when looking for a simper project then ask Phill about the Blade 14 and see what he says.
Just an idea.
Re: Home building a small cat [Re: Alain] #69234
03/15/06 05:52 AM
03/15/06 05:52 AM
Hi,
I'm planning to build a small cat, aroud 16'. The goal is to get experience with boat building using wood and maybe later to build a large cat for cruising. . .
All information on thoses design performances or on other design will be welcome. . .
Here's the Grandaddy of them all:
http://www.wharram.com/
A very good plan to consider; especially if you have no experience is:
http://www.wharram.com/ctrek_photos/hitia17.shtml
The Wharram designs will seem obsolete to most people, I happen to disagree.
You should be aware that I am in the process of buying a Phil Brander design, the Blade F16, and that I own a Wharram Tiki 21, which I bought.
Good luck and keep us informed. You will find a HUGE amount of knowledge and experience here.
Re: Home building a small cat [Re: Alain] #69235
03/15/06 07:24 AM
03/15/06 07:24 AM
Regardless of the plan you choose, this site shows the building process and includes a cost sheet, in Euros.
Sorry, it's in Italian.
http://www.macchinedagiardino.com/hitia/
Re: Home building a small cat [Re: Alain] #69236
03/15/06 01:29 PM
03/15/06 01:29 PM
Alain Offline OP
Alain  Offline OP
Thank you all for that information.
The blade seems to be a really nice design and if, for a similar cost, I can build a hi-tech cat, sure I will do. That's exactly the kind of boat I was looking for my test. Many large Cats are also builds from striped plank or ply design, so it will be very good for me to see if I can manage a good result with a small one before starting a big one. Anyway the big one is for a live aboard project in about 10 years from here, so I have some time to play on the water before.
I have already checked the WHARRAM designs for the large cat, but the Hitia 17 is not what I’m looking for right now. But you’re right, they’re designs for large cat are very interesting.
Anyone haves an idea of the price range it can cost me to build a blade 16 using plywood? I don’t need all hi-tech parts as I don’t plan to race with it.
Thanks again to all of you. I really appreciate.
Alain
Re: Home building a small cat [Re: Alain] #69237
03/15/06 01:34 PM
03/15/06 01:34 PM
Alain Offline OP
Alain  Offline OP
And also, how many hours are to be planned to finish the boat ?
Thanks
Alain
Re: Home building a small cat [Re: Alain] #69238
03/15/06 01:59 PM
03/15/06 01:59 PM
Queue Wouter! (he home-built a very similar boat - the Taipan 4.9)
Re: Home building a small cat [Re: Jake] #69239
03/15/06 02:16 PM
03/15/06 02:16 PM
Atlanta
bvining Offline
bvining  Offline
Atlanta
Does Phil Brander sell his plans? Or provide more detailed decriptions on his builds? His web site has great pictures, but some commentary plus some plans and you'd have a great resource to building a nice boat.
Wouter, how did you do it?
Bill
Re: Home building a small cat [Re: bvining] #69240
03/15/06 02:30 PM
03/15/06 02:30 PM
Catsailor had a write up om the Blade build. You may want to ask Mary or Rick for a back issue.
Doug Snell
Re: Home building a small cat [Re: bvining] #69241
03/15/06 02:34 PM
03/15/06 02:34 PM
Not meaning to speak for Phill here, but yes, plans for plywood construction are available.
Re: Home building a small cat [Re: Rolf_Nilsen] #69242
03/15/06 02:56 PM
03/15/06 02:56 PM
Alain, I think you will be surprised by the price when you add all fittings and rigging together. Marine equipment is very expensive (I personally feel that somebody are doing a x3 on their profits somewhere in the chain). Building the hulls are not to expensive, 4 sheets of 4mm quality marine-ply, some epoxy, cedar, glass and carbon. The real cost is in all fittings, blocks, sails, cleats, rigging, mast, lines, tiller etc. etc. Phill can probably give you some numbers in AUS$ if you contact him.
If you are on a tight budget (I guess you are, since you want to homebuild instead of buying?), my best advice to cut costs is to find a derelict beachcat locally which you can pick up for a song. Strip it for all fittings, blocks, rudders, pintles, rudderheads, rig, tiller, crossbeams etc. that you can use, and you have saved a lot of money. Do _NOT_ fix that old beachcat, just strip it and go ahead with your building, if building is what you want to do. Look around clubs and you will probably find something lying in the bushes.
I would seriously try to get a Superwing mast section for your Blade if you decide to build however. I think that makes a lot of the boats "feel".
Re: Home building a small cat [Re: Rolf_Nilsen] #69243
03/15/06 03:12 PM
03/15/06 03:12 PM
Wharram says 250 hours to build Hitia 17, 400 hours to build Tiki 21. Those are quotes for people with "some" skill with tools.
Your guess is as good as mine as to building time for the Blade.
Incidentally, I had estimated $4,000 U.S. to build the Tiki. That's wooden mast, no sails, no trailer.
Re: Home building a small cat [Re: Jake] #69244
03/16/06 05:32 AM
03/16/06 05:32 AM
Yes HELLO, here I am !
But seriously, a quick run down of the points raised :
My Taipan F16 (same building method, just a different hull design), fully fitted (Pentex Main, Pentex jib, spinnaker, snuffer), some carbon goodies, race ready and competitive finally came out at about 12.000 Euro's.
However, just like Rolf wrote by far the biggest part of the costs are the fittings and custom things like competitive sails etc.
I think I payed about 3000 Euro's to have the hulls build, painted and beamed. The other part is all the rest, like carbon rudders etc. I bought as good as everything new
So indeed just buying an old second hand catamaran and stripping it for parts will go a very long way to cuts costs. I expect you could then have the boat sailing for 5000 to 6000 Euro's. Note that not all secondhand available designs will be suitable. Check with us before buying.
Yes, he has sold quite a few already actually. He charges 250 Aus$ for them = about 160 Euro's. I feel this is too inexpensive for the work he has done on the design and the building plans, but he wants it this way.
The plans he sells are detailed instructions on how to build you own hulls and boat. Nearly step by step instructions. So it is more then just plans (blue print). The instructions sold actually explain the building method and best practice approaches of how to do more detailed stuff. It is the most elaborate set of plans I ever seen. It contains explanatory pics of the various building stage. In addition he has a large collection of building pics of all his builds. He has a builders forum that you are invited to and where you can get help on details if so required. Phill gives active support while building and he is very accessible for any questions you may have. I think this to be lightyears ahead of other building plans including those for the Taipan F16 that I used. I think Phill should charge more for this level of support, but ...
Anyway; if support is a deciding factor then look no further.
I used the AHPC Taipan F16 plans (200 Euro;s I believe) and I received a huge amount of help from (again) Phill Brander. This was before Phill finished his Blade design; otherwise I would have chosen to do the Blade design. I got alot of help from various friends and such. What else can I say here ?
About the same time I imagine, but building the Blade will always be more complex then building a Wharram design; I'm sure of that. However the Blade hulls do look 10 times better as a result. I appreciate the wharram design but they always look rather crude to me.
Quite a lot. I think It took me another year to fully complete the boat but I didn;t spend to much time per week on it then. However the finishing up of the boat is a big portion added to the building time just the same.
I think in general one should expect to spend two years from scratch to fully completing the race ready boats that is fully fitted.
To these answers I would like to add that you don't need to make a FULLY fitted boat if you don't want to. If saving time and cost is important then just forget about the jib and spinnaker setups, this will save at least 2000 Euro's (maybe more) and a good amount of building time. You can skim on other parts as well. You can decide to build your own mainsail etc and that will save another 700 Euro's at least. And so on. But this things will take extra building time. It will be a trade-off.
It will never be really cheap. Quality stuff just costs and in such a corrosive and abusive environment like the sea you really do want to have quality stuff. However I don't really expect any more crude designs to be alot cheaper.
One of the biggest advantages of building the Blade F16 is that you have an active class to support you and keep you motivated. Probably this will also help resale value later on.
Personally I would take up Rolf on his advice and try getting a superwing mast for the boat. It is really halve the feel of the boat and mine was bought and shipped to Netherlands from Australia for 880 Euro's; I don't think that to be to expensive knowing what other dealors ask for their masts (2000 - 3000 Euro's)
If you really want to cut cost then Pieter Saarberg overhere (very close to me) still has a few older aluminium A-cat masts he wants to sell. These will not be really competitive in the A-cat class or F16 class but they will definately be good enough for recreational sailing. Here you see how important an active class around a design is. By using the network you can arrange for alot of stuff and support.
Good luck !
Re: Home building a small cat [Re: Wouter] #69245
03/16/06 06:25 AM
03/16/06 06:25 AM
Wharrams are a completely different concept than the Blade (or Taipan or similar). The lashings and other things Wharram use fits the concept/philosophy behind his boats very well.
One point about boatbuilding. The first boat is always slow to build, as you are learning how to use new tools, materials, techniques etc. The second project usually goes much faster, and the third a little bit faster than the second again. What kind of background and what kind of personality you have also influences building time. I think it was Ian Farrier who wrote that a cabinet maker would use horrendously long time on completing a boat, but it would be a floating cabinet (beautiful). A plumber on the other hand would build a structurally sound boat on half the time. Joinery under the floorpanels would not be as beautiful as the one from the cabinet makers tough.
Like I said earlier, if you want to learn how to use plywood and epoxy, building a Blade is a good project. If you fear that this project is too large/expensive, build a plywood kayak first instead so you can find out wether homebuilding is for you. http://www.clcboats.com/ sells comprehensive plan sets and their book "The New Kayak Shop" explains what you need to know about plywood stitch and glue construction.
0 registered members (), 330 guests, and 50 spiders.
