use fiberglass cloth tape and epoxy resin. flip the boat over.clean and sand the area to be repaired. lay on the fg tape, use masking tape on the ends to hold it in place. brush just enough resin onto the cloth to wet out the area you want to cover, the part where the gel coat has rubbed off, be neat and avoid excess resin, wipe off any runs. trim off the excess cloth after the resin sets with a razor knife and sandpaper. repeat if you think it needs oo be thicker. recoat with one or two more coats of resin -let each coat start to harden before recoating -until the cloth becomes slick. remember to clean off any drips and runs before they set up to save a bunch of sanding. sand and fair, paint , et voila!
