| safety and tuning #70459 03/28/06 08:22 AM 03/28/06 08:22 AM |
Posts: 3,348 | There were some questions on another thread r/t weather helm, and a lot of interest in safety. Since I will soon be sailing a spinnaker boat and don't know a thing about them, I thought I'd ask for help. Are there any really stupid mistakes beginners make that can cost money or drown the initiate (me)? | | | Re: safety and tuning
[Re: fin.]
#70460 03/28/06 08:28 AM 03/28/06 08:28 AM |
Posts: 12,310 South Carolina | don't ever let full pressure off the mainsheet while flying the kite in heavy air.
Jake Kohl | | | Re: safety and tuning
#70461 03/28/06 08:42 AM 03/28/06 08:42 AM |
Posts: 3,528 Looking for a Job, I got credi... | don't ever let much pressure off the mainsheet while flying the kite in heavy air. If you do, the mast falls down. Also let the downhaul off when the Kite goes up.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: safety and tuning
[Re: scooby_simon]
#70462 03/28/06 09:03 AM 03/28/06 09:03 AM |
Posts: 12,310 South Carolina | what he said (i.e. what I meant)
#70463 03/28/06 09:58 AM 03/28/06 09:58 AM | Anonymous
| Anonymous
Unregistered | Pete: You should always have a small amount of weather helm. It is VERY dangerous not to. Doug Snell Hobie 17 www.tcdyc.com | | | Re: safety and tuning
[Re: fin.]
#70465 03/28/06 10:29 AM 03/28/06 10:29 AM | Anonymous
| Anonymous
Unregistered | If you pop a shute with a loose main, get ready to buy a new mast!!!! | | | Re: safety and tuning
[Re: fin.]
#70466 03/28/06 10:32 AM 03/28/06 10:32 AM |
Joined: Mar 2005 Posts: 2,074 Northfield,NH USA bullswan
Posts: 2,074 Northfield,NH USA | Doug, your point about weather helm is well taken. Jake/Scooby, you're trying to tell me the mainsheet is like a back stay? It hadn't even entered my mind. Pete, It wouldn't have entered my mind either but I watched it happen one day last summer. It makes sense when you think about it. It also makes a GREAT DEAL OF SENSE for you to ask these guys these questions before you get out there. Good for you! I'd really appreciate you keeping us up to date with how it goes when you finally get it going. That is my next step and I'd like to learn from you. Did you think about Rick's Hooter-sail first or just go right to the spin? Greg
The nice part about being a pessimist is that you are constantly being either proven right or pleasantly surprised. - George Will "It's not that liberals aren't smart, it's just that so much of what they know isn't so" -Ronald Reagan | | | Re: safety and tuning
[Re: fin.]
#70467 03/28/06 10:43 AM 03/28/06 10:43 AM |
Posts: 1,382 Essex, UK | You should always have a small amount of weather helm. That's all very well upwind etc. but you'll find that with the kite up, your small amount of weather helm will have swapped to lee helm. If you try and dial this out, you'll have waaayyy too much weather helm upwind (very hard work and slow). Keeping one or both boards down can help to keep the boat tracking downwind even with this lee helm but you need to balance this with the extra drag and the potential for a pitchpole. I found that the Blade tolerates the boards being down very well (they're much shallower than the Stealth boards) and the boat is quite tolerant of burying anyway. With regard to the mainsheet/backstay thing: that's exactly what the leech of the main is doing, acting as a backstay. Downwind with spin up, you sheet in the main so that it is pretty tight (but not upwind block-to-block tight) and then play the traveller. Don't let the traveller out too far though because although it won't break the mast, it will power up in a gust rather than being stalled and can then promote a bow bury or pitchpole. Keeping the mainsheet on and your mast rotated 90 degs prevents you breaking your mast from the very high point load at the top of the mast generated by the spinnaker.
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: safety and tuning
[Re: bullswan]
#70468 03/28/06 10:53 AM 03/28/06 10:53 AM | Anonymous
| Anonymous
Unregistered | Guys: I am green here, but don't you want a little lee helm downwind? Aren't you suppose to fall off when a gust hits? Does anyone know if you can put a spinnaker on a Nacra 4.5? I am getting one for Ashleigh (grand daughter) and would like to learn spinnaker myself. Doug Snell Hobie 17 www.tcdyc.com | | | Re: safety and tuning
[Re: fin.]
#70470 03/28/06 12:02 PM 03/28/06 12:02 PM |
Posts: 2,921 Michigan | Pete, I went through the same thing recently- trying to figure out a spin without either a) scaring myself to death b) killing myself or crew c) doing serious damage to the boat. After our first run I feel much more comfortable with the spin and how the boat can take it. I am very aware of the status of the mainsheet when the spin goes up. I tighten it (perhas too much) and let the traveler out a foot or so and then let go of the rope. As for the downhaul, I believe people let this out so as to descrease the compression on the mast, but I think leaving some on also helps to stabilize that axis of themast. Seems like a scary thing to do - to not hold onto the mainsheet- and if your crew is flying the spin and you feel like you need to hang on to something so you feel like you have some control- grab the traveller line. However, you will likely be surprised- as I was- how you just balance the boat with the tiller. If you feel a puff you bear off slightly and all is well. After a while it doesn't feel odd not always holding the mainsheet.
[Re: Jalani]
#70473 03/28/06 12:50 PM 03/28/06 12:50 PM |
Posts: 3,348 | | | | Re: safety and tuning
[Re: fin.]
#70474 03/28/06 01:03 PM 03/28/06 01:03 PM |
Posts: 14 Saipan | Hello all, i have a question that falls into this catagory, when hiking out where does one put the slack end of the main sheet, i am costantly throwing it back up on the tramp but it always manages to fall back in the water, then i waste time and concentration pulling it back up and throwing it back onto the tramp. any suggestions? regards again, Darrell
my wife is a princess therefore I must be a prince
[Re: PTP]
#70475 03/28/06 01:11 PM 03/28/06 01:11 PM |
Posts: 12,310 South Carolina | With the spinny flying, I always keep the traveler line in my hand to depower when necessary. I've also never been that concerned about letting the traveler go to the end of the track (stopper knot on the traveler line). Just last weekend we had a nasty windshift on the course that left us double trapped tight reaching with the chute in a lumpy breeze to get to A mark. The traveler was critical to us being able to get there without having to bear away off our lay line. There's nothin like trapping on the stern while your crew is trapping at the rear beam on an I20 with the kite up.
[Re: catmech]
#70477 03/28/06 01:14 PM 03/28/06 01:14 PM |
On the upwind wind have you crew hold the excess line with a loop of about 3 to 4 feet between you two. Agree that when the crew feels a pull on the sheet that he lets go of a few extra loops.
feels scary at first but with soon feel comfortable.
Next step is too have the crew sheet the mainsail while the skipper steers and does the jib or traveller.
[Re: ]
#70478 03/28/06 01:17 PM 03/28/06 01:17 PM |
A little leehelm under spi is good. In effect this brings you to the safety zone (downwind) when you drop the tiller and do some other very important stuff. Weatherhelm under spi onlu makes bearing down harder and slower, something you don't want under spi.
N4.5 with spi, I don't see why not. Just make it a small one.
22,040
guests, and 505
