Traveler repair #71080
04/02/06 03:39 PM
04/02/06 03:39 PM
WidDunesDavid Offline OP
I ripped the traveler from the track on a nasty jibe. I have a replacement but can't feed it into either end of the track. Suggestions??
Tks,
Re: Traveler repair [Re: WidDunesDavid] #71081
04/02/06 03:52 PM
04/02/06 03:52 PM
Err, perhaps you can elaborate on why you can't make the car enter on the track? E.g. what boat do you have and specifically what is the problem.. (we always love photos btw.)
Re: Traveler repair [Re: Rolf_Nilsen] #71082
04/02/06 03:59 PM
04/02/06 03:59 PM
I have a H-16, 83. trying to replace the main traveler car. The track is so close at the corners I can't slide the new traveler on to the track. I thought about cutting back about an half inch of track, insert traveler then put a screw in the end to keep the travelr fro slideing out. There must be a better way.
Re: Traveler repair [Re: WidDunesDavid] #71083
04/02/06 04:08 PM
04/02/06 04:08 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
You'll have to drill out the pop rivits that hold the track to the crossbar. Take just enough out so you can lift the track to slide the new car in.
Make sure you've got the right pop rivits to replace the drilled out ones.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Traveler repair [Re: WidDunesDavid] #71084
04/02/06 05:36 PM
04/02/06 05:36 PM
Branford, CT
rhodysail Offline
rhodysail  Offline
Branford, CT
After you replace the traveler car be sure to tie a knot in the traveler line to prevent the car from smashing into the corner casting on wild jibes.
Re: Traveler repair [Re: rhodysail] #71085
04/02/06 06:17 PM
04/02/06 06:17 PM
hobie1616 Offline
hobie1616  Offline
Or, hook one arm around the main sheets or hold them with a hand to control the speed of the boom swinging across the boat.
Don't EVER let the boom swing across the boat unrestrained. Otherwise, you'll bust up equipment (traveler car!!) and/or kill your crew.
Re: Traveler repair [Re: hobie1616] #71086
04/02/06 09:24 PM
04/02/06 09:24 PM
And go into a gybe with as much speed as possible - the boat will gybe much less violently.
0 registered members (), 2,488 guests, and 346 spiders.
Yesterday at 10:10 AM
