P19 roller furling #72377
04/10/06 04:06 PM
04/10/06 04:06 PM
Coral Gables, Fl
ferminj Offline OP
ferminj  Offline OP
Coral Gables, Fl
I am modifying my P19 and installing a TheMightyHobie18 roller furling unit. At the same time I'll replace forestay (upper & lower) and bridle wires. Now due to the roller furler the bridle wire will need to be shortened and same with either the forestay or the upper. As I would like to keep the option to use the new rigging without the furler unit would it be better to keep original length on bridle and forestay and just shorten the uppper?. This will result in a little more mast rake with the furling unit which perhaps can be compensated with a shorter upper. Any help will be appreciated.
Re: P19 roller furling [Re: ferminj] #72378
04/10/06 04:09 PM
04/10/06 04:09 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
You'd be better off posting in the general discussion area. You'll get a better response there.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: P19 roller furling [Re: ferminj] #72379
04/10/06 04:20 PM
04/10/06 04:20 PM
California
mmiller Offline
mmiller  Offline
California
Make one set of bridles to fit the furler and have the tack at the standard P19 height. I think I would make a second set of bridle wires so the jib tack is at the same height when not using the furler. Leave the forestay and pigtail alone.
If the lower forestay has a fork on the bottom, you can attach to the furler adjuster plate or a 7 hole adjuster when not using the drum.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: P19 roller furling [Re: mmiller] #72380
04/11/06 09:24 AM
04/11/06 09:24 AM
Coral Gables, Fl
ferminj Offline OP
ferminj  Offline OP
Coral Gables, Fl
Thanks, I dont know how I got my post on the wrong board.
0 registered members (), 240 guests, and 45 spiders.
