Low Profile Jib Blocks #72561
04/11/06 10:12 PM
04/11/06 10:12 PM
Roanoke, VA
mattp Offline OP
mattp  Offline OP
Roanoke, VA
I have a 1988 H16 with a jib that is most likely several years older. Since I have raked the mast back to where I can sheet the main block to block, I am not able to sheet in the jib near far enough to trim the jib for sailing close hauled. I seem to need either a new jib with a different cut or some low profile jib blocks or all three. Can anyone recommend a low profile jib car setup? I see components in the Hobie catalog (ie. Trentec Jib Traveler Cars) but I can't figure out the rest of the system. Are the newer jibs cut with a higher clew to eleviate this problem?
(Insert Witty Signature Here) 1988 H16
Re: Low Profile Jib Blocks [Re: mattp] #72562
04/11/06 10:34 PM
04/11/06 10:34 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Take a look at the fifth message in this thread.
http://www.catsailor.com/forums/sho...ew=collapsed&sb=5&o=&fpart=1
You can get the clew relocated so you have some adjustment.
US Sail Level 2 Instructor
US Sail Level 3 Coach
0 registered members (), 639 guests, and 38 spiders.
