Mast Lock / Boot ??? #72749
04/15/06 01:31 PM
04/15/06 01:31 PM
Does anyone know of a locking devise or rubber "boot" that will secure the mast and prevent it from turning when the catamaran is moored? Last year I used plastic zip-ties through the holes at the mast bottom to hold it but I'd like to get something quicker and more secure this year. I have an older (1988) Prindle 16.
Also, Can anyone suggest a clear algae resistant bottom paint for the hulls?
Re: Mast Lock / Boot ??? [Re: ] #72750
04/15/06 11:22 PM
04/15/06 11:22 PM
Andrew Offline
Andrew  Offline
attach your jib sheets to the mast rotator, sheet, and cleat. No recommendation on bottom paint, tho..
Re: Mast Lock / Boot ??? [Re: ] #72751
04/17/06 02:58 AM
04/17/06 02:58 AM
Palm Harbor, FL, USA
L
Lance Offline
Lance  Offline
L
Beach catamarans are generally not reccomended to keep in the water for long periods. I believe leaving your cat in the water for extended periods would lead to leaking or delamination.
Good Luck,
Lance
Taipan 5.7 USA 182
Palm Harbor, FL
Re: Mast Lock / Boot ??? [Re: Lance] #72752
04/17/06 12:39 PM
04/17/06 12:39 PM
St. Louis, MO
hobienick Offline
hobienick  Offline
St. Louis, MO
Leaving yoru beach cat in the water for long periods is not good for two reasons.
1) Normal gelcoat and epoxy paint are not truly waterproof. Over time water will get into your hulls and wreak havoc on the fiberglass sandwich. You need to use a barrier coat that is formulated to block the water penetration. Many of these also have anti-fouling additives to help with algae growth. Clear, don't know of one. White, I think I have seen one before.
2) The waves bang the heck out of your rigging. Not only does the mast rotate from stop to stop, but since your shrouds are not tight the mast will wobble around and shock load your shrouds, forestay, and all connection points. Not good for the hardware. All kinds of damage can occur over time. To prevent this you have to tension your rig so it is no longer loose. I like to tension one shroud and use the jib sheet on the mast rotator (Like John said) to tighten down the rig.
I have never left my boat sitting in water for longer than a few hours while not sialing so I have no experience with the barrier coat.
Nick
Current Boat
Looking for one
Previous Boats
'84 H16
'82 H18 Magnum
'74 Pearson 30
St. Louis, MO
Re: Mast Lock / Boot ??? [Re: hobienick] #72753
04/17/06 03:13 PM
04/17/06 03:13 PM
Lots of monohulls have blisters caused by water seeping into gelcoat. It is a common occurrence.
Re: Mast Lock / Boot ??? [Re: fin.] #72754
04/17/06 03:32 PM
04/17/06 03:32 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
The blisters are caused by water getting into the hull lay up during construction. The resulting blisters are like an aneurism in that they start from the inside.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Mast Lock / Boot ??? [Re: hobie1616] #72755
04/17/06 03:46 PM
04/17/06 03:46 PM
I'm really skeptical! You're gonna have to persuade me.
It's not that I can't be wrong, I want to be sure.
Re: Mast Lock / Boot ??? [Re: fin.] #72756
04/17/06 03:52 PM
04/17/06 03:52 PM
This is not something I know a lot about, but I have some questions..
I know older constructions buildt with chopper guns or chopped strand mat and polyester have osmosis problems, but I tought the risk of osmosis (and hence blisters) was negligible with woven mats and epoxy. As far as I understand osmosis on boats, the ends of the glassfibers need to be exposed for the water to enter, and chopped fibers are especially bad in that regard (not to mention the inconsistency of the fiber layout).
Delamination due to humidity in the laminate? How does this really work? When the matrix is bonded to the distance material, how is the bond destroyed by humidity? Decomposition of the distance material?
If mooring the boat is enough to let a critical amount of humidity trough to the core by diffusion (or is there something else at play), what about letting a small amount of water stay in the hulls while on land/storage? Or even worse, letting water/humidity stay in the hulls, closing all ventilation and letting the sun heat the hulls?
Re: Mast Lock / Boot ??? [Re: Rolf_Nilsen] #72757
04/17/06 04:01 PM
04/17/06 04:01 PM
I will admit I have only seen gel coat blisters on boats 15-20 years old.
Maybe the problem has decreased with improved practices.
Re: Mast Lock / Boot ??? [Re: fin.] #72758
04/17/06 06:01 PM
04/17/06 06:01 PM
Read this.
"Fiberglass Blisters - Explanation, Diagnosis and Repair"
Hartoft Marine Survey, Ltd., Annapolis, MD
Re: Mast Lock / Boot ??? [Re: mbounds] #72759
04/17/06 06:20 PM
04/17/06 06:20 PM
Thanks Matt.
Re: Mast Lock / Boot ??? [Re: fin.] #72760
04/17/06 06:40 PM
04/17/06 06:40 PM
Dublin, Ireland
Dermot Offline
Dermot  Offline
Dublin, Ireland
[quote The resulting blisters are like an aneurism in that they start from the inside.
[/quote]
PAINFULL
Dermot
Catapult 265
Re: Mast Lock / Boot ??? [Re: Dermot] #72761
04/17/06 07:22 PM
04/17/06 07:22 PM
hobie1616 Offline
hobie1616  Offline
PAINFULL [/quote]It's the same as someone having a stroke caused by a blood vessel bursting or a toothy little alien coming out of your chest.
0 registered members (), 2,796 guests, and 637 spiders.
Yesterday at 10:10 AM
