Re: Hobie 18/F18 conversion [Re: flumpmaster] #73375
04/25/06 12:08 PM
04/25/06 12:08 PM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
A used windsurf mast works well for a pole. Vectran works for rigging it (use shackles instead of clevis pins where the bridles attach to the hull and you can tie off to these).
Instead of rigging the stays for the pole to the bridle tangs, consider drilling a small hole in each bow lip, run the vectran into those and dead end them there. Gives a little better angle to suppor the mast. Pics are of a windsurfer mast pole rig, sail is old-style SX spin, boatis regular 18.
Re: Hobie 18/F18 conversion [Re: Keith] #73376
04/25/06 12:10 PM
04/25/06 12:10 PM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
Another pic, with sail up during mock up.
Re: Hobie 18/F18 conversion [Re: Keith] #73377
04/25/06 12:23 PM
04/25/06 12:23 PM
I don't know much about a Dacron squaretop, but I have a Pentex on my Hobie 17 and in a puff the boat just MOVES!! It does not stretch at all. I noticed a REAL big difference in light air. The extra area up top really make it move in light wind.
Good luck.
Doug
Re: Hobie 18/F18 conversion [Re: Keith] #73378
04/25/06 12:40 PM
04/25/06 12:40 PM
Graham, NC
WindyHillF20 Offline OP
Graham, NC
Keith, I have the black glass rudders that came out in the mid '80s. Saw some carbon epos at my dealer, they're bad butt. Are the black ones no good? I thought the white plastic ones were the junk.
Re: Hobie 18/F18 conversion [Re: WindyHillF20] #73379
04/25/06 01:08 PM
04/25/06 01:08 PM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
I've seen the molded pastic ones come in both white and black. If your rudders are glass or better you're ok. It's the molded ones that suck. If you can deflect the tip of the rudder with your hand, you've got the molded ones. You can also look at them and tell.
Re: Hobie 18/F18 conversion [Re: Keith] #73380
04/25/06 01:33 PM
04/25/06 01:33 PM
Keith,
You're exactly right. Firm believer in "no rake" for the 18. We actually asked for a third hand during setup to jam the forestay deeper in the bridle.
Back when there were only a few 20's and now, only a few 18's in combined starts is my reference for the 18 vs. 20 upwind. Granted the nut on the tiller has a lot to do with those results...then and now.
DO the anything but plastic, not sure there is that marked an improvement from fiberglass to EPO.
Re: Hobie 18/F18 conversion [Re: _flatlander_] #73381
04/25/06 03:43 PM
04/25/06 03:43 PM
Wilmington,NC
Dlennard Offline
Dlennard  Offline
Wilmington,NC
I have a tiger black pole and snuffer with a Skip Elliott bag. I will sell it for 265.00 and will give Rick ten dollars for an add.
Re: Hobie 18/F18 conversion [Re: Dlennard] #73382
04/25/06 03:54 PM
04/25/06 03:54 PM
Graham, NC
Graham, NC
Dave, I'll take it. My e-mail is [email][email protected].[/email] Let me know how to pay and pick-up. Dan, if the spin can be cut down I'll take it as well. Not sure if it can or if its worth it. Please e-mail me also.
Re: Hobie 18/F18 conversion [Re: WindyHillF20] #73383
04/25/06 07:35 PM
04/25/06 07:35 PM
SE Pa. or Chesapeak Bay
HMurphey Offline
HMurphey  Offline
I"ve been reading this thread and have a few comments. I've had a Hobie 18mag since 1985 and a P-19 since 91'. In 1999 I converted the P-19 into a "mx" with a new set of "square topped" main and oversized jib. I also at this time added a Nacra 6.0 bow foil because of concerns of bow loading and deflection. I installed a spinnacker purchasing a used 25sq m Tornado spinnacker in 2003 for the P-19mx. Please note that this is a flat cut spin, in the mono world I think it would be called a jennacker.
1) The Hobie 18 is the best all-round beach/race cat. It is almost indestructable and has all the adjustment of the 20'speed machines. It is an extremely versitile platform.
2)The Hobie 18 was Killed by the "One-Design" mantra of the NAHCA. The NAAHCA held their meetings for rule changes at the 16 Nationals ,so with out any 18 sailors present the H16 sailors voted down any changes or up-grades including changing the class wieght limit to 315lbs so as to give heavier weighted teams a different platform to race on.(Question to Hobie: Does it make marketing sense to have these two classes @ the same weight?? competing for sales. I quess you wanted to kill it.) The only upgrades to the boat have been, jib pigtails for the jibsheets and a increase in the downhaul purchase.
3) Keith is on the right track and so is Mike. Their suggestions are spot on. But Keith, you got the best set of West Coast Catamoran sails I'd seen in many years and you had a solid mast. I haven't seen another set near as good since then. I've only heard horror stories since then of poorly constructed over-priced junk that has to be re-cut/re-sewed.
4)Lengthen you jib track: the jib track is availible for little cost along with traveler cars (ref: layline, APS). This will give you adjustment fore/aft for the spin sheet. This adjustment is good if you are buying used spins. Also in light air you furl the jib, move the spin sheet aft far as possible and you have a BIG jib to scoop and accelerate the airflow on the back-side of the main when beating to weather.
5) I started with a fiberglass 15' wind-surfer mast as a spin pole, I liked the tappered look vs the pipe/plumbing look, but had some issues. First I had to cut it down to 14'. Using the scrap "but end" and a piece of a broken Hot Stick I constructed a Dolphin striker for the pole. Because of the bow foil I have a very small window for setting my pole hieght, its lashed to the underside of the foil and deflected w/ the dolphin-strker to set the tip hieght. I used spectra/vectra/deneema basically as discribed in the other postings, tip of pole to tip of bow, middle of pole to shackles at bridle tang and for the dolphin-striker. Now here was the problem, upon the first sail the pole did "the egyption". It stayed in column port/starb but it deflected under compression every time we hit a wave, doing a sine wave curve in the vertical axis. (it was awesume and scarary at the same time. So it was back to the beach for some West Epoxy and CARBON FIBER!!! So here is the advise; start with a Carbon fiber mast!!!
Now at this time I am starting to put my Hobie-18 back together so I can race with my 12 year old niece. (I bounce her head first into mast from the wire last year on the 19mx w/o spin in a micro-burst. This was/is not a good thing to do!)(Know and remember your limits and know when to quit!!!) The 19mx is just a little too powerful for us above 10kts of winds yet. But the H-18 needs a new set of sails, so I priced a new set from West Coast....$1300.00.... and I have very little confidence that they will be correct!!! I'll most likely have to have them recut/resewed at some added cost! This is extremely upsetting to me that I'll pay that much money and get an sub-standard product. Since I race mostly "open" events I would like to see a vertical-cut, racing-dacron, fat-head/square-top keeping the sq-ft of the sail plan the same. (This will minimize the portsmith correction) Is there anyone out there with the same thoughts???
Hope my ideas have helped.
0 registered members (), 374 guests, and 282 spiders.
