| Re: Dart Squaretop?
[Re: pitchpoledave]
#73440 04/25/06 11:45 AM 04/25/06 11:45 AM | Anonymous
| Anonymous
Unregistered | I have a squaretop on my Hobie 17 and I love it. You will see a BIG difference in light air. You can move good even it a light breeze.
Doug | | | Re: Dart Squaretop?
[Re: Headhunter]
#73441 04/25/06 12:03 PM 04/25/06 12:03 PM |
Posts: 126 southern Ontario | A few people have tried the squaretop. Another option to getting them made, is to buy used from the UK. There are LOTS of good used sails as it is a huge class in Europe. The cost of shipping is not bad if you do not ship the battens over. Check out www.dart18.com
Ryan Dart 18 #4860
| | | Re: Dart Squaretop?
[Re: pitchpoledave]
#73442 04/25/06 12:42 PM 04/25/06 12:42 PM |
Posts: 915 Dublin, Ireland | See attached pic. The boat is also widened to 8.5' and also has a much larger jib and bridal foil like the Nacras. Also the rudders have been raked under the boat. The boat really sails nicely and is very competitive. That looks a really nice job. Did you fit the stronger forestay chainplates, fitted on newer Darts ? The originals have been known to fail. The foil will help to spread the load anyway. Headhunter: You may not get an answer to your query on the UK Dart 18 website. There are very few modifications made to Dart 18s in the UK, as any changes would hugely devalue the boat. The Dart 18 is a very strict one design class and they always say "If it did not come with the boat when new, it is not allowed", but that should not matter where there is no class racing - like in Florida. I know that the Canadians have quite a few Darts and fitted spinnakers to some a few years ago. http://www.dartcatamaran.ca/
Dermot Catapult 265
| | | Re: Dart Squaretop?
[Re: Dermot]
#73443 04/25/06 01:17 PM 04/25/06 01:17 PM |
Posts: 91 Dunedin, FL | Thanks for all the responses thus far. I actually found a UK based agent who sells Dart 18 square tops for the Dutch sailmaker, Landenberger. Prices are competitive, the sail plan looks strong, and they can build in a variety of materials. Check it out - http://www.cat-bitz.co.uk/They also have dart rudder rebuild kits (thank god). The only thing I don't know is what (if anything) this will do to my portsmith rating. | | | Re: Dart Squaretop?
[Re: Dan_Delave]
#73445 04/25/06 06:08 PM 04/25/06 06:08 PM |
Posts: 3,528 Looking for a Job, I got credi... | and watch mast fall down - remember it is an unsupported mast (no diamonds) and so (from info gained from the UK fleet) you have to be VERY carefull in anything over about a F3 ! Or if the mast does not fall down, you swim - the D18 has very fine / deep section up front and the rudders are not great - I would not fancy the chances of bearing off in time with a big gust Not a good plan IMO
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Dart Squaretop?
[Re: scooby_simon]
#73446 04/25/06 06:47 PM 04/25/06 06:47 PM |
Posts: 915 Dublin, Ireland | and watch mast fall down - remember it is an unsupported mast (no diamonds) and so (from info gained from the UK fleet) you have to be VERY carefull in anything over about a F3 ! Or if the mast does not fall down, you swim - the D18 has very fine / deep section up front and the rudders are not great - I would not fancy the chances of bearing off in time with a big gust Not a good plan IMO The spinnaker that was designed for the Dart 18 is only 12.9 sq. M, because of the unsupported mast section. Also I agree that, if the bows go down, the shallow rudders loose grip very quickly. Maybe a spinnaker is not the best idea. The Class certainly rejected it after trying it for a while. Still, that Dart with the squaretop looks good. I have had quite a few dealings with Andy Morse at Cat-Bitz and he is always very helpful.
Dermot Catapult 265
| | | Re: Dart Squaretop?
[Re: pitchpoledave]
#73448 04/26/06 08:58 AM 04/26/06 08:58 AM |
Posts: 915 Dublin, Ireland | It's not my boat, so I can't say for sure what he has for the chainplates. I am fairly sure that the heavier bow chainplates were introduced at the same time as the spinnaker. I think that there was a pair supplied with the spinnaker kit (about 1997 ?) and have been on all Dart 18s since then. I have also seen sidestay chainplates with cracks. They should be checked regularly on older Darts.
Dermot Catapult 265
2,497
guests, and 327
